Toyota Yaris 2011-2018 Service and Repair Manual
Engine: 1NZ-FE, 2NZ-FE
Region: General, Australia, GCC
Date:
Model Code: NCP13#(NCP130,NCP131)
Model: Toyota Yaris
Format: HTML
INTRODUCTION
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
1NZ-FE ENGINE CONTROL
2NZ-FE ENGINE CONTROL
1NZ-FE ENGINE MECHANICAL
2NZ-FE ENGINE MECHANICAL
1NZ-FE FUEL
2NZ-FE FUEL
1NZ-FE EMISSION CONTROL
2NZ-FE EMISSION CONTROL
1NZ-FE INTAKE / EXHAUST
2NZ-FE INTAKE / EXHAUST
1NZ-FE COOLING
2NZ-FE COOLING
1NZ-FE LUBRICATION
2NZ-FE LUBRICATION
1NZ-FE STARTING
2NZ-FE STARTING
Drivetrain
U340E (AUTOMATIC TRANSMISSION / TRANSAXLE)
U441E (AUTOMATIC TRANSMISSION / TRANSAXLE)
CLUTCH
C54 MANUAL TRANSMISSION / TRANSAXLE
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
PARK ASSIST / MONITORING
Power Source / Network
1NZ-FE BATTERY / CHARGING
2NZ-FE BATTERY / CHARGING
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
PRE-CRASH SAFETY
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
New Car Features
INTRODUCTION
SPECIFICATIONS
1NZ-FE FUEL
2NZ-FE FUEL
1NZ-FE COOLING
2NZ-FE COOLING
1NZ-FE LUBRICATION
2NZ-FE LUBRICATION
1NZ-FE STARTING
2NZ-FE STARTING
Drivetrain
U340E AUTOMATIC TRANSMISSION / TRANSAXLE
U441E AUTOMATIC TRANSMISSION / TRANSAXLE
CLUTCH
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-CRASH SAFETY
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Body Repair Manual
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
