samsmith
65
36
Norway
If you download this document, you will be lost 4400 Beer
TOYOTA PRIUS PLUG-IN HYBRID ZVW35 2009 - 2012 SERVICE & REPAIR INFORMATION MANUAL
Code:
Product Code: Toyota
Availability: In Stock
Year : 12.2009 - 04.2012
Market : All Regions
Qty :  1 CD
Toyota Prius Plug-in Hybrid Service information library 12.2009 - 04.2012
ZVW35 series
Engines:
2ZR-FXE - 1.8 L 4-cylinder 16-Valve DOHC
electric motor 60 kW
New car features
Electrical wiring diagram
Body Repair
Service data sheet
REPAIR MANUAL
Engine / Hybrid System
ENGINE CONTROL - SFI system, Ignition system, Camshaft oil control valve, Throttle body, ECM, Mass Air flow, Camshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Integration relay
HYBRID / BATTERY CONTROL - Hybrid control system, Hybrid battery system, Coolant, Hybrid vehicle converter, Inverter with converter, Electric vehicle charger assembly, Charge inlet, Charge indicator, Battery smart unit, HV battery, Water pump with motor, SUB radiator, Frame wire, Accelerator pedal sensor, Relay, HV relay assembly, Charge relay, Service plug grip, Battery blower
ENGINE MECHANICAL - Engine, Camshaft, Cylinder head gasket, Front crankshaft oil seal, Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
FUEL - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pump, Fuel tank, Fuel sender gauge assembly
EMISSION CONTROL - Emission control system, EGR valve, EGR cooler, Vacuum sensor, Canister, Purge valve, Fuel tank cap, PCV valve
INTAKE / EXHAUST - Intake system, Intake manifold, Exhaust manifold, Exhaust pipe
COOLING - Cooling system, Cooling fan system, Exhaust heat recirculation system, Coolant, Water pump, Temperature switch, Thermostat, Exhaust pipe gas control actuator, Cooling fan motor, Radiator, Relay
LUBRICATION - Lubrication system, Oil and Oil filter, Oil pressure switch, Oil pump
STARTING - Power switch
CRUISE CONTROL - Cruise control system, Cruise control main switch
Drivetrain
HYBRID TRANSMISSION / TRANSAXLE - Hybrid transaxle system, Electronic shift lever system, Hybrid vehicle transaxle, Generator cable, Motor cable, Hybrid transaxle fluid, Hybrid transaxle oil seal, Input shaft oil seal, Shift lever, Shift control actuator, TCM
DRIVE SHAFT / PROPELLER SHAFT - Drive shaft system, Front drive shaft assembly
AXLE AND DIFFERENTIAL - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle hub
ALIGNMENT / HANDLING DIAGNOSIS - Front / Rear wheel alignment
FRONT SUSPENSION - Front suspension system, Front shock absorber, Front lower suspension arm, Front lower ball joint, Front stabilizer bar, Front suspension member
REAR SUSPENSION - Rear suspension system, Rear shock absorber, Rear coil spring, Rear axle beam
TIRE / WHEEL - Tire and wheel system, Tire repair seal
BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS - Electronically controlled brake system, Front /Rear speed sensor, Yaw rate and acceleration sensor, Steering angle sensor, Brake pedal stroke sensor, Skid control buzzer
BRAKE SYSTEM- Brake system, Brake line, Brake fluid, Brake pedal, Brake booster, Brake booster pump
REAR / FRONT BRAKE - Front / Rear brake, Front / Rear brake flexible hose
PARKING BRAKE - Parking brake system, Parking brake pedal, Parking brake cable, Parking brake switch
POWER ASSIST SYSTEMS - Power steering system, Power steering ECU
STEERING COLUMN - Steering system, Steering column assembly, Steering wheel, Steering pad switch
STEERING GEAR / LINKAGE - Steering gear
Audio/Visual/Telematics
AUDIO / VIDEO - Audio and visual system, Radio receiver, Front door speaker, Rear door speaker, Instrument panel speaker, Radio antenna cord, Amplifier antenna, Stereo jack adapter assembly, Microphone, Noise filter
NAVIGATION / MULTI INFO DISPLAY - Navigation system, Navigation receiver, Navigation antenna
Power Source, Network
BATTERY / CHARGING - Battery, Battery thermometer sensor
POWER DISTRIBUTION - Main body ECU, Power management control ECU, Integration relay
NETWORKING - LIN communication system, CAN communication system
Vehicle Interior, Vehicle Exterior
DOOR LOCK, THEFT DETERRENT / KEYLESS ENTRY, LIGHTING, METER / GAUGE / DISPLAY, SUPPLEMENTAL RESTRAINT SYSTEMS, SEAT, HEATING / AIR CONDITIONING, WINDOW / GLASS, WIPER / WASHER, EXTERIOR PANELS / TRIM, DOOR / HATCH, MIRROR, HORN, AND MUCH MUCH MORE
NEW CAR FEATURES
ENGINE CONTROL, HYBRID / BATTERY CONTROL, ENGINE MECHANICAL, FUEL, EMISSION CONTROL, INTAKE / EXHAUST, COOLING, CRUISE CONTROL, LUBRICATION
Drivetrain
HYBRID TRANSMISSION / TRANSAXLE, DRIVE SHAFT / PROPELLER SHAFT, AXLE AND DIFFERENTIAL
FRONT / REAR SUSPENSION, TIRE / WHEEL
BRAKE CONTROL, BRAKE SYSTEM, FRONT / REAR BRAKE, PARKING BRAKE
POWER ASSIST SYSTEMS, STEERING COLUMN
AUDIO/ VIDEO, NAVIGATION / MULTI INFO DISPLAY
NETWORKING
DOOR LOCK, LIGHTING, METER / GAUGE / DISPLAY, SEAT, AIRBAG SYSTEM, HEATING / AIR CONDITIONING, POWER OUTLETS, WINDOW / GLASS, MIRROR,
ELECTRICAL WIRING DIAGRAMS
COOLING FAN, CRUISE CONTROL, ENGINE CONTROL, IGNITION, PLUG-IN HYBRID SYSTEM, SHIFT CONTROL SYSTEM, ABS, TRC, VSC, EPS, AUDIO, NAVIGATION, CAN, DLC3, POWER SOURCE, AIR CONDITIONER, ENTRY & START SYSTEM, SRS, HEADLIGHT, TAILLIGHT and others
BODY REPAIR
BODY PANEL REPLACEMENT, BODY DIMENSIONS, PAINT, COATING
OTHER INFORMATION
  • TOYOTA PRIUS HYBRID ZVW30 SERVICE & REPAIR 2009-2015.txt
