Toyota LandCruiser 70 Series 2014-2017 Service and Repair Manual
Model: Toyota LandCruiser 70 Series
Format: HTML
Date:
Model Code:
Region: General, Australia, GCC
Engine: 1GR-FE, 1HZ, 1VD-FTV
INTRODUCTION
SETUP
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
1GR-FE (ENGINE CONTROL)
1HZ (ENGINE CONTROL)
1VD-FTV (ENGINE CONTROL)
1GR-FE (ENGINE MECHANICAL)
1HZ (ENGINE MECHANICAL)
1VD-FTV (ENGINE MECHANICAL)
1GR-FE (FUEL)
1HZ (FUEL)
1VD-FTV (FUEL)
1GR-FE (EMISSION CONTROL)
1HZ (EMISSION CONTROL)
1VD-FTV (EMISSION CONTROL)
1GR-FE (INTAKE / EXHAUST)
1HZ INTAKE / EXHAUST
1VD-FTV (INTAKE / EXHAUST)
1GR-FE (COOLING)
1HZ (COOLING)
1VD-FTV (COOLING)
1GR-FE (LUBRICATION)
1HZ (LUBRICATION)
1VD-FTV (LUBRICATION)
1GR-FE (STARTING)
1HZ (STARTING)
1VD-FTV (STARTING)
Drivetrain
CLUTCH
H150F (MANUAL TRANSMISSION / TRANSAXLE)
H152F (MANUAL TRANSMISSION / TRANSAXLE)
R151F (MANUAL TRANSMISSION / TRANSAXLE)
BF1B (TRANSFER / 4WD / AWD)
HF1A (TRANSFER / 4WD / AWD)
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE PRESSURE MONITORING
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
Power Source / Network
1GR-FE (BATTERY / CHARGING)
1HZ (BATTERY / CHARGING)
1VD-FTV (BATTERY / CHARGING)
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
PRE-COLLISION
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
SLIDING ROOF / CONVERTIBLE
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
WINCH
New Car Features
INTRODUCTION
SPECIFICATIONS
1HZ ENGINE MECHANICAL
1GR-FE (FUEL)
1HZ FUEL
1VD-FTV FUEL
1GR-FE EMISSION CONTROL
1HZ EMISSION CONTROL
1GR-FE INTAKE / EXHAUST
1GR-FE (COOLING)
1HZ COOLING
1VD-FTV (COOLING)
1GR-FE LUBRICATION
1HZ LUBRICATION
1VD-FTV LUBRICATION
1GR-FE STARTING
1HZ STARTING
1VD-FTV STARTING
Drivetrain
CLUTCH
H150F MANUAL TRANSMISSION / TRANSAXLE
H152F MANUAL TRANSMISSION / TRANSAXLE
R151F MANUAL TRANSMISSION / TRANSAXLE
BF1B TRANSFER / 4WD / AWD
HF1A TRANSFER / 4WD / AWD
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-COLLISION
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
WINCH
Electrical Wiring Diagram
Introduction
INTRODUCTION
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS INTRODUCTION
WIRE HARNESS REPAIR GUIDELINES
TERMINAL AND CONNECTOR REPAIR PROCEDURES
System Circuit
Drivetrain
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
ADAS / AD
Location & Routing
Engine Compartment
Instrument Panel
Body
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Overall EWD
Drivetrain
Vehicle Interior
Vehicle Exterior
ADAS / AD
Body Repair Manual
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
DHT-toyota-landcruiser-70-series-2014-2017-service-and-repair-manual-07185124022025-1.jpg
DHT-toyota-landcruiser-70-series-2014-2017-service-and-repair-manual-07185124022025-2.jpg
DHT-toyota-landcruiser-70-series-2014-2017-service-and-repair-manual-07185124022025-3.jpg
DHT-toyota-landcruiser-70-series-2014-2017-service-and-repair-manual-07185124022025-4.jpg
