Toyota Innova 2011-2014 Service and Repair Manual
Engine: 2TR-FE
Date:
Region: GCC, South Africa
Format: HTML
Model: Toyota Innova
Model Code: TGN41
INTRODUCTION
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
2TR-FE ENGINE CONTROL
2TR-FE ENGINE MECHANICAL
2TR-FE FUEL
2TR-FE EMISSION CONTROL
2TR-FE INTAKE / EXHAUST
2TR-FE COOLING
2TR-FE LUBRICATION
2TR-FE STARTING
Drivetrain
A343E AUTOMATIC TRANSMISSION / TRANSAXLE
CLUTCH
R150 MANUAL TRANSMISSION / TRANSAXLE
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
PARK ASSIST / MONITORING
Power Source / Network
2TR-FE BATTERY / CHARGING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
New Car Features
INTRODUCTION
SPECIFICATIONS
2TR-FE FUEL
2TR-FE COOLING
2TR-FE LUBRICATION
2TR-FE STARTING
Drivetrain
CLUTCH
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS REPAIR INTRODUCTION
TERMINAL AND CONNECTOR REPAIR
System Circuit
Drivetrain
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
Location & Routing
Engine Compartment
Instrument Panel
Body
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Overall EWD
Drivetrain
Vehicle Interior
Vehicle Exterior
Body Repair Manual
