Toyota Hilux 2016-08 Service and Repair Manual
Region: General, Europe, Australia, GCC, South Africa, Philippines
Format: HTML
Engine: 1GR-FE, 1GD-FTV, 1GD-FTV High Version, 2GD-FTV, 2GD-FTV High Version, 1KD-FTV, 2KD-FTV, 2KD-FTV High Version, 5L-E, 1TR-FE, 2TR-FE
Date:
Model: Toyota Hilux
Model Code:
INTRODUCTION
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
1GR-FE ENGINE CONTROL
1KD-FTV ENGINE CONTROL
1GD-FTV ENGINE CONTROL
2GD-FTV ENGINE CONTROL
2KD-FTV ENGINE CONTROL
5L-E ENGINE CONTROL
1TR-FE ENGINE CONTROL
2TR-FE ENGINE CONTROL
1GR-FE ENGINE MECHANICAL
1KD-FTV ENGINE MECHANICAL
1GD-FTV ENGINE MECHANICAL
2GD-FTV ENGINE MECHANICAL
2KD-FTV ENGINE MECHANICAL
5L-E ENGINE MECHANICAL
1TR-FE ENGINE MECHANICAL
2TR-FE ENGINE MECHANICAL
1GR-FE FUEL
1KD-FTV FUEL
1GD-FTV FUEL
2GD-FTV FUEL
2KD-FTV FUEL
5L-E FUEL
1TR-FE FUEL
2TR-FE FUEL
1GR-FE EMISSION CONTROL
1KD-FTV EMISSION CONTROL
1GD-FTV EMISSION CONTROL
2GD-FTV EMISSION CONTROL
2KD-FTV EMISSION CONTROL
5L-E EMISSION CONTROL
1TR-FE EMISSION CONTROL
2TR-FE EMISSION CONTROL
1GR-FE INTAKE / EXHAUST
1KD-FTV INTAKE / EXHAUST
1GD-FTV INTAKE / EXHAUST
2GD-FTV INTAKE / EXHAUST
2KD-FTV INTAKE / EXHAUST
5L-E INTAKE / EXHAUST
1TR-FE INTAKE / EXHAUST
2TR-FE INTAKE / EXHAUST
1GR-FE COOLING
1KD-FTV COOLING
1GD-FTV COOLING
2GD-FTV COOLING
2KD-FTV COOLING
5L-E COOLING
1TR-FE COOLING
2TR-FE COOLING
1GR-FE LUBRICATION
1KD-FTV LUBRICATION
1GD-FTV LUBRICATION
2GD-FTV LUBRICATION
2KD-FTV LUBRICATION
5L-E LUBRICATION
1TR-FE LUBRICATION
2TR-FE LUBRICATION
1GR-FE STARTING
1KD-FTV STARTING
1GD-FTV STARTING
2GD-FTV STARTING
2KD-FTV STARTING
5L-E STARTING
1TR-FE STARTING
2TR-FE STARTING
STOP AND START
Drivetrain
A750F AUTOMATIC TRANSMISSION / TRANSAXLE
AC60E AUTOMATIC TRANSMISSION / TRANSAXLE
AC60F AUTOMATIC TRANSMISSION / TRANSAXLE
CLUTCH
R151 MANUAL TRANSMISSION / TRANSAXLE
R151F MANUAL TRANSMISSION / TRANSAXLE
RC60 / RC61 MANUAL TRANSMISSION / TRANSAXLE
RC60F / RC61F MANUAL TRANSMISSION / TRANSAXLE
VF2CM TRANSFER / 4WD / AWD
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE PRESSURE MONITORING
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
TELEMATICS
PARK ASSIST / MONITORING
Power Source / Network
1GR-FE BATTERY / CHARGING
1KD-FTV BATTERY / CHARGING
1GD-FTV BATTERY / CHARGING
2GD-FTV BATTERY / CHARGING
2KD-FTV BATTERY / CHARGING
5L-E BATTERY / CHARGING
1TR-FE BATTERY / CHARGING
2TR-FE BATTERY / CHARGING
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
PRE-CRASH SAFETY
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
New Car Features
INTRODUCTION
SPECIFICATIONS
5L-E ENGINE CONTROL
1GR-FE FUEL
1KD-FTV FUEL
1GD-FTV FUEL
2GD-FTV FUEL
2KD-FTV FUEL
5L-E FUEL
1TR-FE FUEL
2TR-FE FUEL
1GR-FE COOLING
1KD-FTV COOLING
1GD-FTV COOLING
2GD-FTV COOLING
2KD-FTV COOLING
5L-E COOLING
1TR-FE COOLING
2TR-FE COOLING
1GR-FE LUBRICATION
1KD-FTV LUBRICATION
1GD-FTV LUBRICATION
2GD-FTV LUBRICATION
2KD-FTV LUBRICATION
5L-E LUBRICATION
1TR-FE LUBRICATION
2TR-FE LUBRICATION
1GR-FE STARTING
1KD-FTV STARTING
1GD-FTV STARTING
2GD-FTV STARTING
2KD-FTV STARTING
5L-E STARTING
1TR-FE STARTING
2TR-FE STARTING
2GD-FTV IDLING STOP CONTROL
Drivetrain
CLUTCH
RC60 MANUAL TRANSMISSION / TRANSAXLE
RC60F MANUAL TRANSMISSION / TRANSAXLE
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
TELEMATICS
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-CRASH SAFETY
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS REPAIR INTRODUCTION
TERMINAL AND CONNECTOR REPAIR
System Circuit
Drivetrain
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
Location & Routing
Engine Compartment
Instrument Panel
Body
Seat
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Seat
Overall EWD
Drivetrain
Vehicle Interior
Vehicle Exterior
Body Repair Manual
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
