Toyota Highlander_Kluger 2013-2019 Service and Repair Manual
Region: Australia, Russia
Date:
Format: HTML
Model: Toyota Highlander/Kluger
Engine: 1AR-FE, 2GR-FE, 2GR-FKS
Model Code: ASU50, GSU5#(GSU50,GSU55)
INTRODUCTION
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
1AR-FE ENGINE CONTROL
2GR-FKS (ENGINE CONTROL)
1AR-FE (ENGINE MECHANICAL)
2GR-FKS (ENGINE MECHANICAL)
1AR-FE FUEL
2GR-FKS FUEL
1AR-FE EMISSION CONTROL
2GR-FKS EMISSION CONTROL
1AR-FE INTAKE / EXHAUST
2GR-FKS (INTAKE / EXHAUST)
1AR-FE COOLING
2GR-FKS (COOLING)
1AR-FE LUBRICATION
2GR-FKS LUBRICATION
1AR-FE STARTING
2GR-FKS STARTING
Drivetrain
UA80E (AUTOMATIC TRANSMISSION / TRANSAXLE)
UA80F (AUTOMATIC TRANSMISSION / TRANSAXLE)
U760E AUTOMATIC TRANSMISSION / TRANSAXLE
MF1A (TRANSFER / 4WD / AWD)
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE PRESSURE MONITORING
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
TELEMATICS
PARK ASSIST / MONITORING
Power Source / Network
1AR-FE BATTERY / CHARGING
2GR-FKS BATTERY / CHARGING
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
PRE-COLLISION
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
SLIDING ROOF / CONVERTIBLE
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
New Car Features
INTRODUCTION
SPECIFICATIONS
2GR-FKS ENGINE CONTROL
1AR-FE ENGINE MECHANICAL
2GR-FKS ENGINE MECHANICAL
1AR-FE FUEL
2GR-FKS FUEL
2GR-FKS INTAKE / EXHAUST
1AR-FE COOLING
2GR-FKS COOLING
1AR-FE LUBRICATION
2GR-FKS LUBRICATION
1AR-FE STARTING
2GR-FKS STARTING
Drivetrain
UA80E AUTOMATIC TRANSMISSION / TRANSAXLE
UA80F AUTOMATIC TRANSMISSION / TRANSAXLE
MF1A TRANSFER / 4WD / AWD
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
TELEMATICS
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-COLLISION
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS REPAIR INTRODUCTION
TERMINAL AND CONNECTOR REPAIR
System Circuit
Drivetrain
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
Location & Routing
Engine Compartment
Instrument Panel
Body
Seat
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Seat
Overall EWD
Drivetrain
Vehicle Interior
Vehicle Exterior
Body Repair Manual
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
