Toyota Corolla & Auris 2012-2018 Service and Repair Manual
Engine: 1NR-FE, 1ZR-FE, 1ZR-FAE, 2ZR-FE, 1ND-TV
Region: General, Australia, South Africa, GCC
Model: Toyota Corolla, Auris
Format: HTML
Model Code: NRE180, ZRE18#(ZRE181,ZRE182), NDE180
Date:
INTRODUCTION
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
2ZR-FE (ENGINE CONTROL)
2ZR-FE (ENGINE MECHANICAL)
2ZR-FE (FUEL)
2ZR-FE (EMISSION CONTROL)
2ZR-FE (INTAKE / EXHAUST)
2ZR-FE (COOLING)
2ZR-FE (LUBRICATION)
2ZR-FE (STARTING)
Drivetrain
CLUTCH
EC60 (MANUAL TRANSMISSION / TRANSAXLE)
K311 (CVT)
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
PARK ASSIST / MONITORING
Power Source / Network
2ZR-FE (BATTERY / CHARGING)
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
New Car Features
INTRODUCTION
SPECIFICATIONS
2ZR-FE (FUEL)
2ZR-FE (COOLING)
2ZR-FE (STARTING)
Drivetrain
CLUTCH
K311 (CVT)
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS INTRODUCTION
WIRE HARNESS REPAIR GUIDELINES
TERMINAL AND CONNECTOR REPAIR PROCEDURES
System Circuit
Drivetrain
Vehicle Interior
Vehicle Exterior
Location & Routing
Engine Compartment
Instrument Panel
Body
Seat
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Seat
Overall EWD
Drivetrain
Vehicle Interior
Vehicle Exterior
Body Repair Manual
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
