- If you download this document, you will be lost 2827 Beer
Toyota Corolla 2016 Service and Repair Manual
Region: General, GCC, Australia, Philippines, Singapore, Brazil, Argentina, Venezuela
Model Code: ZRE17#(ZRE171,ZRE172,ZRE173), ZZE172
Engine: 1ZR-FE, 1ZR-FAE, 2ZR-FE, 2ZR-FBE, 3ZR-FE, 3ZR-FBE, 1ZZ-FE
Type of Manual: Service and Repair Manual, Electrical Diagram
Format: HTML
Date:
Model: Toyota Corolla
INTRODUCTION
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
1ZR-FAE ENGINE CONTROL
1ZR-FE ENGINE CONTROL
2ZR-FBE ENGINE CONTROL
2ZR-FE ENGINE CONTROL
3ZR-FBE ENGINE CONTROL
3ZR-FE ENGINE CONTROL
1ZZ-FE ENGINE CONTROL
1ZR-FAE ENGINE MECHANICAL
1ZR-FE ENGINE MECHANICAL
2ZR-FBE ENGINE MECHANICAL
2ZR-FE ENGINE MECHANICAL
3ZR-FBE ENGINE MECHANICAL
3ZR-FE ENGINE MECHANICAL
1ZZ-FE ENGINE MECHANICAL
1ZR-FAE FUEL
1ZR-FE FUEL
2ZR-FBE FUEL
2ZR-FE FUEL
3ZR-FBE FUEL
3ZR-FE FUEL
1ZZ-FE FUEL
1ZR-FAE EMISSION CONTROL
1ZR-FE EMISSION CONTROL
2ZR-FBE EMISSION CONTROL
2ZR-FE EMISSION CONTROL
3ZR-FBE EMISSION CONTROL
3ZR-FE EMISSION CONTROL
1ZZ-FE EMISSION CONTROL
1ZR-FAE INTAKE / EXHAUST
1ZR-FE INTAKE / EXHAUST
2ZR-FBE INTAKE / EXHAUST
2ZR-FE INTAKE / EXHAUST
3ZR-FBE INTAKE / EXHAUST
3ZR-FE INTAKE / EXHAUST
1ZR-FAE COOLING
1ZR-FE COOLING
2ZR-FBE COOLING
2ZR-FE COOLING
3ZR-FBE COOLING
3ZR-FE COOLING
1ZR-FAE LUBRICATION
1ZR-FE LUBRICATION
2ZR-FBE LUBRICATION
2ZR-FE LUBRICATION
3ZR-FBE LUBRICATION
3ZR-FE LUBRICATION
1ZZ-FE LUBRICATION
1ZR-FAE STARTING
1ZR-FE STARTING
2ZR-FBE STARTING
2ZR-FE STARTING
3ZR-FBE STARTING
3ZR-FE STARTING
Drivetrain
U241E AUTOMATIC TRANSMISSION / TRANSAXLE
U340E AUTOMATIC TRANSMISSION / TRANSAXLE
U341E AUTOMATIC TRANSMISSION / TRANSAXLE
CLUTCH
C50 MANUAL TRANSMISSION / TRANSAXLE
EB60 MANUAL TRANSMISSION / TRANSAXLE
EC60 MANUAL TRANSMISSION / TRANSAXLE
K111 CVT
K313 CVT
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE PRESSURE MONITORING
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
PARK ASSIST / MONITORING
Power Source / Network
1ZR-FAE BATTERY / CHARGING
1ZR-FE BATTERY / CHARGING
2ZR-FBE BATTERY / CHARGING
2ZR-FE BATTERY / CHARGING
3ZR-FBE BATTERY / CHARGING
3ZR-FE BATTERY / CHARGING
1ZZ-FE BATTERY / CHARGING
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
PRE-COLLISION
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
SLIDING ROOF / CONVERTIBLE
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
New Car Features
INTRODUCTION
SPECIFICATIONS
1ZR-FAE FUEL
1ZR-FE FUEL
2ZR-FBE FUEL
2ZR-FE FUEL
3ZR-FBE FUEL
3ZR-FE FUEL
1ZR-FAE COOLING
1ZR-FE COOLING
2ZR-FBE COOLING
2ZR-FE COOLING
3ZR-FBE COOLING
3ZR-FE COOLING
1ZR-FAE LUBRICATION
1ZR-FE LUBRICATION
2ZR-FBE LUBRICATION
2ZR-FE LUBRICATION
3ZR-FBE LUBRICATION
3ZR-FE LUBRICATION
1ZR-FAE STARTING
1ZR-FE STARTING
2ZR-FBE STARTING
2ZR-FE STARTING
3ZR-FBE STARTING
3ZR-FE STARTING
Drivetrain
CLUTCH
K111 CVT
K313 CVT
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-COLLISION
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS REPAIR INTRODUCTION
TERMINAL AND CONNECTOR REPAIR
System Circuit
Drivetrain
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
Location & Routing
Engine Compartment
Instrument Panel
Body
Seat
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Seat
Overall EWD
Drivetrain
Vehicle Interior
Vehicle Exterior
Body Repair Manual
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
