Toyota C-HR 2016-2022 Service and Repair Manual
Format: HTML
Engine: 8NR-FTS, 3ZR-FAE
Region: General, Europe, Russia, Australia
Model: Toyota C-HR
Model Code: NGX10, NGX50, ZGX10
INTRODUCTION
SETUP
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
8NR-FTS (ENGINE CONTROL)
3ZR-FAE (ENGINE CONTROL)
8NR-FTS (ENGINE MECHANICAL)
3ZR-FAE (ENGINE MECHANICAL)
8NR-FTS (FUEL)
3ZR-FAE (FUEL)
8NR-FTS (EMISSION CONTROL)
3ZR-FAE (EMISSION CONTROL)
8NR-FTS (INTAKE / EXHAUST)
3ZR-FAE (INTAKE / EXHAUST)
8NR-FTS (COOLING)
3ZR-FAE (COOLING)
8NR-FTS (LUBRICATION)
3ZR-FAE (LUBRICATION)
8NR-FTS (STARTING)
3ZR-FAE (STARTING)
Drivetrain
CLUTCH
EC6A (MANUAL TRANSMISSION / TRANSAXLE)
K114 (MULTIDRIVE / CVT)
K313 (MULTIDRIVE / CVT)
K313F (MULTIDRIVE / CVT)
GF1A (TRANSFER / 4WD / AWD)
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE PRESSURE MONITORING
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
TELEMATICS
PARK ASSIST / MONITORING
Power Source / Network
8NR-FTS (BATTERY / CHARGING)
3ZR-FAE (BATTERY / CHARGING)
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
PRE-COLLISION
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
New Car Features
INTRODUCTION
SPECIFICATIONS
3ZR-FAE ENGINE MECHANICAL
8NR-FTS (FUEL)
3ZR-FAE (FUEL)
8NR-FTS COOLING
3ZR-FAE COOLING
8NR-FTS LUBRICATION
3ZR-FAE LUBRICATION
8NR-FTS (STARTING)
3ZR-FAE (STARTING)
Drivetrain
CLUTCH
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
TELEMATICS
3ZR-FAE BATTERY / CHARGING
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
PRE-COLLISION
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS INTRODUCTION
WIRE HARNESS REPAIR GUIDELINES
TERMINAL AND CONNECTOR REPAIR PROCEDURES
System Circuit
Drivetrain
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
ADAS / AD
Location & Routing
Engine Compartment
Instrument Panel
Body
Seat
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Seat
Overall EWD
Drivetrain
Vehicle Interior
Vehicle Exterior
ADAS / AD
Body Repair Manual
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
