4
Toyota Avanza 2011-2016 Service and Repair Manual​
Model Code: F65#(F651,F654)
Region: General, Thailand, Malaysia, South Africa, Philippines, Mexico, GCC
Engine: K3-VE, 3SZ-VE, 1NR-VE, 2NR-VE
Model: Toyota Avanza
Format: HTML
Date:
INTRODUCTION
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
1NR-VE ENGINE CONTROL
2NR-VE ENGINE CONTROL
3SZ-VE ENGINE CONTROL
K3-VE ENGINE CONTROL
1NR-VE ENGINE MECHANICAL
2NR-VE ENGINE MECHANICAL
3SZ-VE ENGINE MECHANICAL
K3-VE ENGINE MECHANICAL
1NR-VE FUEL
2NR-VE FUEL
3SZ-VE FUEL
K3-VE FUEL
1NR-VE EMISSION CONTROL
2NR-VE EMISSION CONTROL
1NR-VE INTAKE / EXHAUST
2NR-VE INTAKE / EXHAUST
1NR-VE COOLING
2NR-VE COOLING
3SZ-VE COOLING
K3-VE COOLING
1NR-VE LUBRICATION
2NR-VE LUBRICATION
3SZ-VE LUBRICATION
K3-VE LUBRICATION
1NR-VE STARTING
2NR-VE STARTING
Drivetrain
A4Q AUTOMATIC TRANSMISSION / TRANSAXLE
A4R AUTOMATIC TRANSMISSION / TRANSAXLE
CLUTCH
M5S MANUAL TRANSMISSION / TRANSAXLE
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE PRESSURE MONITORING
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
PARK ASSIST / MONITORING
Power Source / Network
1NR-VE BATTERY / CHARGING
2NR-VE BATTERY / CHARGING
3SZ-VE BATTERY / CHARGING
K3-VE BATTERY / CHARGING
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
New Car Features
INTRODUCTION
SPECIFICATIONS
1NR-VE FUEL
2NR-VE FUEL
K3-VE INTAKE / EXHAUST
1NR-VE COOLING
2NR-VE COOLING
1NR-VE LUBRICATION
2NR-VE LUBRICATION
1NR-VE STARTING
2NR-VE STARTING
Drivetrain
CLUTCH
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
SEAT
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS REPAIR INTRODUCTION
TERMINAL AND CONNECTOR REPAIR
System Circuit
Drivetrain
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
Location & Routing
Engine Compartment
Instrument Panel
Body
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Overall EWD
Drivetrain
Vehicle Interior
Vehicle Exterior
Body Repair Manual
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
