blacks
Title: Toyota 2H_12H-T Engine Repair Manual
About the Toyota 2H Engine
The 2H is a 4.0 L (3980 cc) inline 6, 12 valve OHV diesel engine. Bore is 91 mm and stroke is 102 mm, with a compression ratio of 20.7:1. Output is 103 hp (77 kW) at 3500 rpm - later production years 107 hp (80 kW) with 177 lb·ft (240 N·m) of torque at 2000 rpm.
Applications
Toyota Land Cruiser HJ47, HJ60, HJ75
Toyota Dyna HU20, 30, 40, 50
Toyota Coaster HB20, 30
About the 12H-T engine
The 12H-T is a 4.0 L (3980 cc) inline 6, 12 valve OHV turbocharged diesel engine. Bore is 91 mm and stroke is 102 mm, with a compression ratio of 18.6:1. Output is 134 hp (100 kW) at 3500 rpm with 232 lb·ft (315 N·m) of torque at 1800 rpm.
Toyota Land Cruiser HJ61
  • Toyota 2H_12H-T Engine Repair Manual.txt
