ohenry
730
80
ho chi minh
If you download this document, you will be lost 14475 Beer
The National Locksmith InstaCode 01.2023
Description:
InstaCode is the most comprehensive knowledge base for locksmiths in the world. Created 20 years ago, the technology has been designed by locksmiths to provide a practical and comprehensive business tool that will help you run your business more efficiently and unlock new profit.
It's already been recognised as the only key code tool you need, with over 187 key blank manufacturers, 8577 key code series, 70,000 references, and more than 3 billion key codes in the database. The program is constantly evolving to include the ever-increasing bank of information you need.
Type of Software: Key Tool
Version: update 01.2023
InstaCode features:
+ Cross-referencing for 187+ key blank manufacturers
+ 8577+ key code series
+ Support for the widest range of key cutting machines
+ More than 3 billion key codes
+ Searches for bittings across a range of code series
+ Images of key blanks and keyways
+ Instructional guides for transponders
+ Guides for opening vehicles and disabling airbags
+ Lock decoding information
Software Function:
The InstaCode display is dynamic, showing menu options and buttons that pertain to the task you are performing and to the current state of the program.
Comprehensive search functionality:
Working with locks and vehicles in the real world can be very complex . InstaCode offers you an extensive set of search criteria to find exactly what you are looking for.
From a basic search of key code and manufacturer or searching by number of cuts, to specifying the exact lock system or key blank, InstaCode’s search engine caters to your needs.
Key information:
InstaCode shows you both visual and numerical displays of the specifications of your code series.
You can also set InstaCode to work in 1/1000 inch or 1/100 mm, whichever you are most comfortable with.
Find bitting:
Sometimes you will have an overly worn or broken key that you cannot fully decode. InstaCode allows you to search through the code series with as little or much information as you have available to find possible key codes.
InstaCode will organise all possible codes into an efficient cutting tree. This will allow you to test every code by recutting the test keys and wasting as few keys as possible until you find the code you are looking for.
Vehicle information:
Vehicle work has become an integral part of locksmithing and has become far more complex than requiring just a physically cut key. An understanding of transponders, complex picking techniques and obscure programming instructions requires clear instructions and accurate information. InstaCode curates and centralises all this information into the software.
Wafer locations and swapper:
InstaCode can save you time by displaying which wafers are in each lock in a vehicle. InstaCode can calculate the most secure code than can be created using the existing wafers when you don’t have replacement wafers during a rekey.
Identifying a key:
InstaCode will help you identify what key you are working with from the key blank number. You can identify the key depth and space information from dimensions you measure from the key.
Saving client information:
You can save a series code combination and record client information against it. Saved client information allows you to provide your customers with great service while also saving yourself time if you need to make another key for the customer.
Search criteria
+ Searching by code
+ Manufacturer
+ Vehicle make, model and year
+ Card number
+ Key blank reference, key type etc
Supported machines
+ Silco UnoCode V1, V2, 199, 299, 399, 399 Evo, 399 Plus, UnoCode Pro, Triax e-Code, Triax Quattro, Triax Pro, Viper, Futura V1, V2, QuattroCode
+ Keyline Dezmo, Ninja, Ninja Laser, Ninja Vortex, Ninja Total, Versa, Sigma Pro, Gymkana 994, New console 994, Bianchi 993, 994
+ HPC CodeMax, Blueshark
+ Ilco EZCode, UltraCode
+ ITL 9000, 950
+ JMA Avantcode, Procode, Multicode, XCode
+ Laser Key Products Machine
+ Miracle A4, A6, A9
+ Xhorse Condor XC-Mini
  • SotI20iMcA6152.txt
  • Like
Reactions: Người trông xe
Người trông xe
41
7
8
32
Việt Nam
Description:
InstaCode features:
Software Function:
Key information:
Find bitting:
Identifying a key:
Search criteria
+ Searching by code
+ Manufacturer
+ Card number
Supported machines
+ ITL 9000, 950
View attachment 84218 View attachment 84219 View attachment 84220 View attachment 84221 View attachment 84222 View attachment 84223 View attachment 84224
It worked so good. Thank you
