aleksey-ms
283
204
43
Ukraine
vc2.motorstate.com.ua
Suzuki SDT-II Diagnostic Suite: Dealer Software & Calibration Files
WHAT INSIDE:
* Suzuki SDT-II 2.39.0.15
SUPPORTED MODELS & ECU:
* Global Models: Suzuki Vitara / Grand Vitara (1.6L, 2.0L, 2.4L, 2.5L, 3.2L), SX4 / SX4 S-Cross, Swift, Jimny, Baleno, Ignis.
* Additional Models: Celerio, Alto, Ertiga, APV, Carry.
* American/Other Markets: Aerio, Equator, Liana.
* Diagnostic Modules: Engine (Powertrain), Automatic Transmission (TCM), ABS, ESP, Airbags, BCM, HVAC, Immobilizer, and TPMS.
MAIN FEATURES:
* Reading, decoding, and deleting diagnostic trouble codes (DTC).
* Real-time monitoring of vehicle operation parameters with recording function (data stream).
* Adaptations and calibrations, including ECU reset, throttle and sensor calibration.
* Service functions, such as resetting oil change service intervals.
* Flashing and updating ECU software.
* Automatic vehicle recognition by VIN.
Professional dealer-level software for deep diagnostics of Suzuki vehicles. It works in conjunction with the original diagnostic scanner. Theoretically, it supports operation via J2534 / PassThru interfaces, but such a setup requires independent configuration.
IMPORTANT: J2534 / PassThru Compatibility Note
While the software theoretically supports J2534 / PassThru interfaces, real-world compatibility strongly depends on the adapter quality.
* Recommended & Tested: Scanmatik 2 PRO (SM2 Pro), Tactrix OpenPort 2.0 (original), and high-quality Ford VCM II clones (dual-board, full-chip versions).
* Problematic & Incompatible: Cheap single-board Ford VCM II clones, Mini VCI cables, and low-quality generic J2534 adapters.
*Note: Setting up third-party PassThru adapters requires manual driver and registry configuration. We do not provide technical support for configuring clone devices.*
  • Suzuki SDT II Diagnostic Software new.txt
