If you download this document, you will be lost 1100 Beer
Subaru legacy Outback 2008-2009 Workshop Manual
Number of Pages: 4981 Pages
Type of Manual: Workshop Manual, Wiring Diagrams
Model: Subaru legacy Outback 2008-2009
Brand: Subaru
General Information
Foreword
How to Use This Manuals
Legacy
Outback
Precaution
Note
Identification
Recommended Materials
Pre-Delivery Inspection
Pre-delivery Inspection
Periodic Maintenance Services
General Description
Schedule
Engine Oil
Engine Oil Filter
Spark Plug
V-belt
Timing Belt
Fuel Line
Air Cleaner Element
Cooling System
Engine Coolant
Clutch System
Transmission Gear Oil
Automatic Transmission Fluid
Front & Rear Differential Gear Oil
Brake Line
Brake Fluid
Disc Brake Pad and Disc
Parking Brake
Wheel Bearing
Axle Boots & Joints
Tire Rotation
Steering System (Power Steering)
H4SO
Fuel Injection (Fuel Systems)
Emission Control (Aux. Emission Control Devices)
Intake (Induction)
Mechanical
Exhaust
Cooling
Lubrication
Speed Control Systems
Ignition
Starting/Charging Systems
Engine (Diagnostics)
General Description
H4DOTC
Intake (Induction)
Mechanical
Exhaust
Cooling
Lubrication
Ignition
General Description
H6DO
Intake (Induction)
Mechanical
Exhaust
Cooling
Lubrication
Ignition
General Description
Transmission
Control Systems
General Description
AT Shift Lock Control System
Select Lever
Select Cable
Paddle Shift Assembly
AT Shift Lock Solenoid and P Range Switch
Body Integrated Unit
MT Gear Shift Lever
Reverse Check Cable
General Diagnostic Table
Automatic Transmission (4AT)
General Description
Road Test
Stall Test
Time Lag Test
Line Pressure Test
Transfer Clutch Pressure Test
Automatic Transmission Assembly
Transmission Mounting System
Extension Case Oil Seal
Differential Side Retainer Oil Seal
Inhibitor Switch
Front Vehicle Speed Sensor
Rear Vehicle Speed Sensor
Torque Converter Turbine Speed Sensor
Control Valve Strainer
Control Valve Body
Air Bleeding of Control Valve
Transmission Control Module (TCM)
ATF Cooler Pipe and Hose
Air Breather Hose
Oil Charge Pipe
Torque Converter Clutch Assembly
Extension Case
Transfer Clutch
Reduction Driven Gear
Reduction Drive Gear
Parking Pawl
Converter Case
Oil Pump Housing
Drive Pinion Shaft Assembly
Front Differential Assembly
AT Main Case
Transmission Control Device
Automatic Transmission (Diagnostics) (4AT)
Basic Diagnostic Procedure
Check List for Interview
General Description
Electrical Component Location
Transmission Control Module (TCM) I/O Signal
Subaru Select Monitor
Read Diagnostic Trouble Code (DTC)
Inspection Mode
Clear Memory Mode
AT OIL TEMP Warning Light Display
Diagnostic Procedure for Subaru Select Monitor Communication
List of Diagnostic Trouble Code (DTC)
Diagnostic Procedure with Diagnostic Trouble Code (DTC)
Diagnostic Procedure without Diagnostic Trouble Code (DTC)
Automatic Transmission (5AT)
General Description
Road Test
Stall Test
Time Lag Test
Line Pressure Test
Inhibitor Switch
Turbine Speed Sensor 1
Control Valve Body
ATF Filter
Lateral G Sensor
Air Breather Hose
Oil Charge Pipe
Torque Converter Assembly
Extension Case
Transfer Clutch
Rear Drive Shaft
Center Differential Carrier
Parking Pawl
Converter Case
Oil Pump Cover
AT Main Case
Automatic Transmission (Diagnostics) (5AT)
General Description
Inspection Mode
Clear Memory Mode
Learning Control
Manual Transmission & Differential (5MT)
General Description
Manual Transmission Assembly
Oil Seal
Switches and Harness
Preparation for Overhaul
Transfer Case and Extension Case Assembly
Transfer Drive Gear
Transfer Driven Gear
Center Differential
Reverse Check Sleeve
Transmission Case
Main Shaft Assembly for Single-Range
Reverse Idler Gear
Shifter Fork and Rod
Manual Transmission & Differential (6MT)
General Description
Oil Seal
Air Breather Hose
Back-up Light Switch
Neutral Position Switch
Extension Case
Reverse Check System
Transfer Drive Gear
Center Differential
Transmission Case
Main Shaft Assembly
Driven Gear Assembly
Reverse Idler Gear Assembly
Clutch Housing
Clutch System
General Description
Clutch Disc and Cover
Flywheel
Release Bearing and Lever
Operating Cylinder
Master Cylinder
Clutch Pipe and Hose
Clutch Fluid
Clutch Fluid Air Bleeding
Clutch Pedal
Clutch Switch
Chassis
Front Suspension
General Description
Wheel Alignment
Front Crossmember Support Plate
Front Stabilizer
Front Ball Joint
Front Arm
Front Strut
Front Crossmember
Rear Suspension
General Description
Wheel Alignment
Rear Stabilizer
Rear Arm
Upper Link
Rear Shock Absorber
Front Link
Rear Link
Sub Frame Support Arm
Rear Sub Frame
Helper
Wheel & Tire System
General Description
Tire
Steel Wheel
Aluminum Wheel
Wheel Balancing
T-type Tire
Tire Pressure Monitoring System
Tire Pressure Monitoring System (Diagnostics)
General Description
Control Module I/O Signal
Inspection Mode
Clear Memory Mode
Tire Pressure Warning Light / Trouble Indicator Light Illumination Pattern
Differentials
General Description
Rear Differential (T-type)
Rear Differential (VA-type)
Rear Differential Front Oil Seal
Rear Differential Side Oil Seal
Rear Differential Front Member
Transfer Case
General Description
Transfer Clutch
Extension Case
Oil Seal
Transfer Drive Gear
Center Differential
Drive Shaft System
General Description
Propeller Shaft
Front Axle
Front Hub Unit Bearing
Rear Hub Unit Bearing
Front Drive Shaft
Rear Drive Shaft
ABS
General Description
ABS Control Module and Hydraulic Control Unit (ABSCM&H/U)
ABS Sequence Control
Front ABS Wheel Speed Sensor
Rear ABS Wheel Speed Sensor
Front Magnetic Encoder
Rear Magnetic Encoder
G Sensor
ABS (Diagnostics)
General Description
Inspection Mode
Clear Memory Mode
ABS Warning Light / Brake Warning Light Illumination Pattern
Vehicle Dynamics Control (VDC)
General Description
VDC Control Module and Hydraulic Control Unit (VDCCM&H/U)
VDC Sequence Control
Yaw Rate and Lateral G Sensor
Steering Angle Sensor
VDC OFF Switch
Vehicle Dynamics Control (VDC) (Diagnostics)
General Description
Inspection Mode
Clear Memory Mode
General Description
Front Brake Pad
Front Disc Rotor
Front Disc Brake Assembly
Rear Brake Pad
Rear Disc Rotor
Rear Disc Brake Assembly
Master Cylinder
Brake Booster
Brake Fluid
Air Bleeding
Brake Hose
Brake Pipe
Brake Pedal
Stop Light Switch
Parking Brake
General Description
Parking Brake Lever
Parking Brake Cable
Parking Brake Assembly (Rear Disc Brake)
Power Assisted System (Power Steering)
General Description
Steering Wheel
Universal Joint
Tilt Steering Column
Steering Gearbox
Pipe Assembly
Oil Pump
Reservoir Tank
Power Steering Fluid
Body
HVAC System (Heater, Ventilator & A/C)
General Description
Refrigerant Pressure with Manifold Gauge Set
Refrigerant Recovery Procedure
Refrigerant Charging Procedure
Refrigerant Leak Check
Compressor Oil
Blower Motor Unit Assembly
Blower Motor
Power Transistor (Auto A/C Model)
Blower Resistor (Manual A/C Model)
Heater Core
Control Panel (Auto A/C Model)
Control Unit (Manual A/C Model)
Control Unit (Auto A/C Model)
Compressor
Condenser
Heater and Cooling Unit
Evaporator
Hose and Pipe
Relay and Fuse
Pressure Switch (Triple Pressure Switch)
Actuator
Ambient Sensor (Auto A/C Model)
Sunload Sensor (Auto A/C Model)
In-Vehicle Sensor (Auto A/C Model)
Air Vent Grille
Heater Duct
Heater Vent Duct
A/C Filter
HVAC System (Auto A/C) (Diagnostics)
General Description
Auto A/C Control Module I/O Signal
Diagnostic Chart for Self-Diagnosis
Diagnostics for A/C System Malfunction
Diagnostic Procedure for Actuators
Diagnostic Procedure for Sensors
Diagnostics with Phenomenon
Airbag System
General Description
Airbag Connector
Inspection Locations After a Collision
Driver's Airbag Module
Passenger's Airbag Module
Side Airbag Module
Curtain Airbag Module
Airbag Control Module
Front Sub Sensor
Side Airbag Sensor
Curtain Airbag Sensor
Satellite Safing Sensor
Roll Connector
Airbag System (Diagnostics)
General Description
Airbag Connector
Airbag Control Module I/O Signal
Inspection Mode
Clear Memory Mode
Airbag Warning Light Illumination Pattern
Airbag Warning Light Failure
Diagnostic Chart with Trouble Code
Occupant Detection System (Diagnostics)
General Description
Airbag Connector
Inspection Mode
Clear Memory Mode
Passenger's Airbag ON/OFF Indicator Light Illumination Pattern
Seat Belt System
General Description
Pretensioner Connector
Seat Belt Warning System
Front Seat Belt
Rear Seat Belt
Lighting System
General Description
Headlight and Tail Light System
Day Time Running Light System
Front Fog Light System
Turn Signal Light and Hazard Light System
Back-up Light System
Stop Light System
Room Light System
Combination Switch (Light)
Combination Base Switch Assembly
Headlight Assembly
Headlight Bulb
Front Turn Signal Light Bulb
Parking Light Bulb
Front Side Marker Light Bulb
Front Fog Light Assembly
Front Fog Light Bulb
Side Turn Signal Light Assembly
Rear Combination Light Assembly
Tail/Stop Light Bulb
Rear Turn Signal Light Bulb
Rear Side Marker Light Bulb
Back-up Light Assembly
Back-up Light Bulb
License Plate Light Assembly
License Plate Light
High-mounted Stop Light
Spot Map Light
Room Light
Luggage Room Light
Trunk Room Light
Glove Box Light
Door Step Light
Ignition Switch Illumination
Day Time Running Light Unit
Reflex Reflector
Door Switch
Wiper & Washer Systems
General Description
Wiper and Washer System
Combination Switch (Wiper)
Wiper Blade
Washer Tank and Motor
Front Wiper Arm
Front Wiper Motor and Link
Front Washer Nozzle
Rear Wiper Arm
Rear Wiper Motor
Rear Washer
Entertainment
General Description
Audio System
Audio
Front Speaker
Tweeter
Rear Speaker
Woofer
Power Amplifier
Antenna
Antenna Amplifier
Noise Suppressor
Navigation System
Navigation Display
GPS Antenna
Navigation Body
AUX Input Terminal
Front Accessory Power Supply Socket
Rear Accessory Power Supply Socket
Steering Satellite Switch
Communication System
General Description
Horn System
Horn Switch
Glass/Windows/Mirrors
General Description
Power Window System
Power Window Control Switch
Front Door Glass
Front Regulator and Motor Assembly
Remote Control Mirror System
Scalp Cap
Outer Mirror Assembly
Outer Mirror
Remote Control Mirror Switch
Rear Door Glass
Rear Regulator and Motor Assembly
Windshield Glass
Rear Gate Glass
Rear Window Glass
Rear Window Defogger System
Rear Quarter Glass
Sunroof Glass
Rearview Mirror
Wiper Deicer System
Wiper Deicer Switch
Body Structure
General Description
Datum Dimensions
Plastic Parts and Materials
List of Plastic Material Notations
Body Sealing
Anticorrosion Wax
Under Coat
Anti Chipping Coat
Stone Guard Coat
Galvanized Sheet Metal
Aluminium Sheet Metal
Instrumentation/Driver Info
General Description
Combination Meter System
Clock System
Combination Meter
Speedometer
Tachometer
Fuel Gauge
Engine Coolant Temperature Gauge
Clock
Multi-Information Display Selector
Seats
General Description
Front Seat
Rear Seat
Seat Heater System
Power Seat System
Security & Locks
General Description
Door Lock Control System
Keyless Entry System
Security System
Front Inner Remote
Front Outer Handle
Front Door Latch and Door Lock Actuator Assembly
Front Door Lock Actuator
Rear Inner Remote
Rear Outer Handle
Rear Door Latch and Door Lock Actuator Assembly
Rear Door Lock Actuator
Rear Gate Outer Handle
Rear Gate Latch Assembly
Trunk Lid Lock Assembly
Trunk Lid Release Handle
Front Hood Lock Assembly
Remote Openers
Ignition Key Lock
Key Lock Cylinders
Security Control Module
Impact Sensor
Keyless Entry Control Module
Keyless Buzzer
Transmitter
Immobilizer Control Module
Immobilizer Antenna
Sunroof/T-Top/Convertible Top (Sunroof)
General Description
Sunroof Control System
Glass Lid
Sunroof Assembly
Sunroof Motor
Sunroof Switch
Sunshade
Exterior/Interior Trim
General Description
Front Grille
Front Hood Grille
Front Under Cover
Floor Under Protector
Fuel Tank Protector
Mud Guard
Front Bumper
Rear Bumper
Cowl Panel
Roof Spoiler
Side Sill Spoiler
Side Protector
Side Garnish
Rear Quarter Protector
Roof Rail
Door Trim
Instrument Panel Lower Cover
Glove Box
Console Box
Center Console
Instrument Panel Assembly
Lower Inner Trim
Upper Inner Trim
Rear Quarter Trim
Sun Visor
Assist Grip
Roof Trim
Rear Gate Trim
Rear Shelf Trim
Trunk Room Trim
Floor Mat
Luggage Floor Box
Trunk Lid Garnish
Rear Gate Garnish
Heat Shield Cover
Ornament
Exterior Body Panels
General Description
Front Hood
Front Fender
Front Door
Front Sealing Cover
Rear Door
Rear Sealing Cover
Trunk Lid
Rear Gate
Cruise Control System
General Description
Cruise Control Module
Cruise Control Command Switch
Combination Meter
Stop Light & Brake Switch
Clutch Switch
Inhibitor Switch
Cruise Control System (Diagnostics)
General Description
Engine Control Module (ECM) I/O Signal
List of Cancel Code
Diagnostic Procedure with Cancel Code
Immobilizer (Diagnostics)
General Description
Immobilizer Control Module I/O Signal
Clear Memory Mode
Diagnostics Chart for Security Indicator Light
LAN System (Diagnostics)
General Description
Clear Memory Mode
Read Current Data
Function Setting (Customize)
Wiring System
Working Precautions
Power Supply Circuit
Ground Circuit
Engine Electrical System
Radiator Fan System
Charging System
Starter System
Remote Engine Start System
AT Control System
Anti-lock Brake System
Vehicle Dynamics Control System
Air Conditioning System
Power Seat System
Airbag System
Seat Heater System
Headlight System
Stop Light System
Clearance Light and Illumination Light System
Interior Light System
Front Wiper and Washer System
Rear Wiper and Washer System
Wiper Deicer System
Audio System
Front Accessory Power Supply Socket System
Rear Accessory Power Supply Socket System
Navigation System
Multi-Information Display (MID) System
Horn System
Power Window System
Rear Defogger System
Speedometer System
Clock System
Fuel Gauge System
Coolant Temperature System
Oil Pressure Warning Light System
Parking Brake / Brake Fluid Level Warning Light System
Security System
Immobilizer System
CAN Communication System
Harness Components Location
Front Wiring Harness
Bulkhead Wiring Harness (In Engine Compartment)
Bulkhead Wiring Harness (In Compartment)
Engine Wiring Harness and Transmission Cord
Instrument Panel Wiring Harness
Rear Wiring Harness
Door Cord
Rear Wiring Harness and Trunk Lid Cord
Rear Wiring Harness and Rear Gate Cord
