If you download this document, you will be lost 4500 Beer
SUBARU FORESTER 2019-2020 Service Manual & Electrical Wiring Diagram​
Type of Document: Workshop Manual - Service Manual - Electrical Wiring Diagram
Type of Vehicle: Car
Format: PDF, ISO, HTML
Brand: Subaru
Publication Number
G8247GE 004
SUBARU FORESTER 2020
Publication Number
G8270GE 003
General Description
FOREWORD
SPECIFICATIONS
PRECAUTION
REPAIR CONTENTS
IDENTIFICATION
RECOMMENDED MATERIALS
PRE-DELIVERY INSPECTION
PERIODIC MAINTENANCE SERVICES
ENGINE
FUEL INJECTION (FUEL SYSTEMS)(H4DO(EXCEPT FOR HEV))
EMISSION CONTROL (AUX. EMISSION CONTROL DEVICES)(H4DO(EXCEPT FOR HEV))
INTAKE (INDUCTION)(H4DO(EXCEPT FOR HEV))
MECHANICAL(H4DO(EXCEPT FOR HEV))
EXHAUST(H4DO(EXCEPT FOR HEV))
COOLING(H4DO(EXCEPT FOR HEV))
LUBRICATION(H4DO(EXCEPT FOR HEV))
SPEED CONTROL SYSTEMS(H4DO(EXCEPT FOR HEV))
IGNITION(H4DO(EXCEPT FOR HEV))
STARTING/CHARGING SYSTEMS(H4DO(EXCEPT FOR HEV))
FUEL INJECTION (FUEL SYSTEMS)(H4DO(HEV))
EMISSION CONTROL (AUX. EMISSION CONTROL DEVICES)(H4DO(HEV))
INTAKE (INDUCTION)(H4DO(HEV))
MECHANICAL(H4DO(HEV))
EXHAUST(H4DO(HEV))
COOLING(H4DO(HEV))
LUBRICATION(H4DO(HEV))
SPEED CONTROL SYSTEMS(H4DO(HEV))
IGNITION(H4DO(HEV))
STARTING/CHARGING SYSTEMS(H4DO(HEV))
WHEEL AND TIRE SYSTEM
Driveline/Axle
DIFFERENTIALS
TRANSFER CASE
PROPELLER SHAFT / DRIVE SHAFT / AXLE
Brakes
Vehicle Dynamics Control
Parking Brake
Transmission/Transaxle
Controls Systems
Continuously Variable Transmission TR580
Continuously Variable Transmission TH58A
Power-Assisted System Power Steering
Heater & Airconditioner/Ventilator
Air Conditioner
Airbag System & Seat Belt System
AirBag System
Seat Belt System
Body & Electrical/WIRING SYSTEM
LIGHTING SYSTEM
WIPER AND WASHER SYSTEMS
ENTERTAINMENT & MONITORING
COMMUNICATION SYSTEM
GLASS/WINDOWS/MIRRORS
BODY STRUCTURE
INSTRUMENTATION/DRIVER INFO
SEATS
SECURITY AND LOCKS
SUNROOF/T-TOP/CONVERTIBLE TOP (SUNROOF)
EXTERIOR/INTERIOR TRIM
EXTERIOR BODY PANELS
CRUISE CONTROL SYSTEM
POWER REAR GATE SYSTEM
EyeSight
Subaru Rear Vehicle Detection
Reverse Automatic Braking
HYBRID ELECTRIC VEHICLE
PEDESTRIAN ALERT SYSTEM
WIRING SYSTEM(EXCEPT FOR HEV)
WIRING SYSTEM(HEV)
DIAGNOSTICS
ENGINE (DIAGNOSTICS)(H4DO 2.0(EXCEPT FOR ES))
ENGINE (DIAGNOSTICS)(H4DO 2.0(ES))
ENGINE (DIAGNOSTICS)(H4DO 2.5)
ENGINE (DIAGNOSTICS)(H4DO HEV(EXCEPT FOR ES))
ENGINE (DIAGNOSTICS)(H4DO HEV(ES))
AUTO START STOP (DIAGNOSTICS)
TRANSMISSION (DIAGNOSTICS)
TRANSMISSION (DIAGNOSTICS)(HEV)
HYBRID POWERTRAIN CONTROL(DIAGNOSTICS)
DRIVE MOTOR(DIAGNOSTICS)
HIGH VOLTAGE BATTERY(DIAGNOSTICS)
BRAKE CONTROL (DIAGNOSTICS)
POWER STEERING (DIAGNOSTICS)
TIRE PRESSURE MONITOR(DIAGNOSTICS)
AIR CONDITIONER(DIAGNOSTICS)
AIRBAG(DIAGNOSTICS)
OCCUPANT DETECTION(DIAGNOSTICS)
CRUISE CONTROL (DIAGNOSTICS)
EyeSight (DIAGNOSTICS)(EXCEPT FOR HEV)
EyeSight (DIAGNOSTICS)(HEV)
EyeSight ASSIST MONITOR (DIAGNOSTICS)
Subaru Rear Vehicle Detection (DIAGNOSTICS)
Reverse Automatic Braking(DIAGNOSTICS)
IMMOBILIZER (DIAGNOSTICS)
LAN SYSTEM (DIAGNOSTICS)(EXCEPT FOR HEV)
LAN SYSTEM (DIAGNOSTICS)(HEV)
KEYLESS ENTRY(DIAGNOSTICS)
KEYLESS ACCESS WITH PUSH BUTTON START(DIAGNOSTICS)
BODY CONTROL(DIAGNOSTICS)
MULTI-FUNCTION DISPLAY(DIAGNOSTICS)
COMBINATION METER (DIAGNOSTICS)
INFOTAINMENT(DIAGNOSTICS)
AUTOMATIC LIGHT AND WIPER (DIAGNOSTICS)
HEADLIGHT / FOGLIGHT(DIAGNOSTICS)
POWER SEAT MEMORY(DIAGNOSTICS)
POWER WINDOW(DIAGNOSTICS)
TELEMATICS SYSTEM (DIAGNOSTICS)
POWER REAR GATE(DIAGNOSTICS)
DRIVER MONITOR(DIAGNOSTICS)
PEDESTRIAN ALERT(DIAGNOSTICS)
COMMON(diag)
  • SUBARU FORESTER 2019-2020 Service Manual & Electrical Wiring Diagram.txt
