Servicemaxx J1708 & J1939
Description: ServiceMaxx is a diagnostic and programming service tool for Navistar Engines.
Capacity: 375 Mb
Region: All regions
Sofware Feature:
Read Fault and clear diagnostic fault codes
View, graph, and save engine data
Check engine in key mode ON, engine does not running (KOEO – Key On Engine Off)
Check the engine in the key mode ON, the engine running (KOER – Key On Engine Running)
Actuation test
Injector disable test
Cylinder cutout test
Compression test
Aftertreatment System Tests
High-pressure pump test
Fan test
Hardware support:
Nexiq USB link
DPA5
Noregon DLA
Operating System: Windows: 7, 10 32/ 64 Bit
Free hard drive space: 1GB or above
CPU: Intel Core I3 or above
Ram: 4GB or above
  • Servicemaxx J1708 & J1939.txt
