Mike Alex
25
Ho Chi Minh City, Vietnam
PROGRAMMING INJECTOR CODES WITH CAT ET SOFTWARE
The Injector Codes Calibration function reads the programmed Injector Code from the ECM and changes the numeric four or six digit Code for each Injector. Each Injector Code should match the Code stamped on the Injector.
Accessing
To run the Injector Codes Calibration
1). Connect CAT ET to the Service Tool connector.
2). Select Calibrations from the Service menu.
3). Select Injector Codes Calibration from the submenu.
4). Click Start. The Injector Codes Calibration screen is displayed.
Screen Layout
The Injector Codes Calibration screen has the following areas:
A. Display Area
The Injector Codes Calibration display area has two columns
Injector – Lists the available Injector Numbers
Code – Displays the Injector's Codes
B. Buttons
The buttons available in the Injector Codes Calibration screen may include:
- Change – Click this button to change the selected parameter’s values.
- Each Injector Code should match the Code stamped on the Injector
- Enter the New Value and click OK.
- Click Yes
- The Injector Code cannot begin with a zero (0)
- After the first Code (1-9), then required any digit "0" through "9".
Exchange – Click this button to electronically exchange Code information between two Injectors for diagnostic purposes.
Note: For some products, the Exchange button is not supported and
will not be displayed.
