ohenry
749
87
27
ho chi minh
Perkins EST 2015A +KG
Perkins EST is designed to run on a personal computer (PC) under Microsoft Windows. It will communicate with the Electronic Control Modules (ECMs) through a communication data link thus allowing you to diagnose existing and potential problems, configure the product, and obtain data for analysis.
Capacity: 246 MB
Region: All region
Language: Multilanguage
Free drive space:
5 GB or more
CPU: Core i3 or above
RAM: 4 GB or more
Operating System: Window XP, Window 7, Window 8, Window 10
Software Feature:
  • View active and logged diagnostics
  • View events where irregularities occurred and were logged by the ECM
  • View the status of a group of parameters (temperatures, pressures, etc.) simultaneously
  • Record and log performance data
  • Graph a group of status parameters
  • View the current configuration of an ECM
  • Change ECM configurations
  • Perform diagnostic tests
  • Perform calibrations
  • Print reports and diagnostic results
Diagnostic software Perkins EST allows users to:
  • Override Powerwizard level three passwords
  • Configure and/or change system parameters
  • Display, graph and record logs of parameter status
  • Display the status of a group of parameters (temperatures, pressures, etc)
  • View and clear active and logged diagnostic codes
  • View and clear active and logged event codes
  • Display, view or change the current Configuration File or Base level Flash File
  • Upload, download and save configuration files
  • View a list of irregularities logged by the ECM (engine control module)
  • Print reports and diagnostic results.
Electronic service tool Perkins EST 2021A includes the following changes:
  • WinFlash Screen changes – the WinFlash screen has been updated for improved usability.
  • New Help System – in this system, existing content has been significantly updated, and new content has been added to provide information and instruction on new features.
  • Snapshot Updates – the Snapshot feature now allows users to compare data points and to change the colors on the graph.
  • Time Mode Display Options for Data Log – “Time Mode” button is now available on the Data Log screen. Clicking this button allows users to toggle the display of the graph between the PC Clock Time (HH:MM:SS) and the time that elapsed while the data was being logged.
  • Trainer Enhancements – the following change was made to coach applications: application WinFlash has been added.
Hardware support:
  • Cat ET Datalink Adapter III
  • Nexiq USB link 1, 2
  • DG Technology DPA5
  • And some other RP1210 devices
  • Perkins EST 2015A +KG.txt
  • Like
Reactions: LysandKZ and TLwin
