Opel Zafira C 2015 Electrical Wiring Diagrams & Component Locator
Format: PDF, CGM
Model: 2015 Opel Zafira C
Opel EWD - 2015 - Zafira C - Control Module U Code List.pdf
Opel EWD - 2015 - Zafira C - RPO Code List.pdf
Opel EWD - 2015 - Zafira C - Schematics RPO Code List.pdf
Opel EWD - 2015 - Zafira C - Service Interval reset 2015 MY.pdf
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.4L (LUJ) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.4L (LUJ) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.4L (LUJ) - Camshaft Timing Chain Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.4L (LUJ) - Drive Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.4L (LUJ) - Engine Mechanical Specifications.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LGE) - Drive Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LGE) - Engine Mechanical Specifications (1.6L LGE - CNG).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LGE) - Timing Belt Adjustment.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LGE) - Timing Belt Inspection.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LGE) - Timing Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LGE) - Valve Clearance Adjustment.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVL) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVL) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVL) - Camshaft Timing Chain Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVL) - Drive Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVL) - Engine Mechanical Specifications (1.6L Diesel LVL & PL5).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVL) - Engine Mechanical Specifications (1.6L Diesel LVL).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVL) - Oil Pump Drive Chain and Sprocket Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVP, LWC) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVP, LWC) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVP, LWC) - Camshaft Timing Chain Installation.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVP, LWC) - Camshaft Timing Chain Removal.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVP, LWC) - Drive Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVP, LWC) - Engine Mechanical Specifications (1.6L LVP).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.6L (LVP, LWC) - Engine Mechanical Specifications (1.6L LWC).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.8L (2H0) - Drive Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.8L (2H0) - Engine Mechanical Specifications (1.8L 2H0).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.8L (2H0) - Power Steering Pump Belt Installation.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.8L (2H0) - Power Steering Pump Belt Removal.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.8L (2H0) - Timing Belt Adjustment.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.8L (2H0) - Timing Belt Inspection.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.8L (2H0) - Timing Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 1.8L (2H0) - Valve Clearance Adjustment.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LBQ, LBR, LBS) - Drive Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LBQ, LBR, LBS) - Engine Mechanical Specifications (2.0L Diesel LBS, LBR and LBQ).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LBQ, LBR, LBS) - Timing Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LBY) - Drive Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LBY) - Engine Mechanical Specifications (2.0L Diesel LBY).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LBY) - Timing Belt Replacement (2.0L Diesel LBY - New Belt).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LBY) - Timing Belt Replacement (2.0L Diesel LBY - Used Belt).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LFS) - Camshaft Intermediate Drive Chain Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LFS) - Drive Belt Replacement.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LFS) - Engine Mechanical Specifications.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LFS) - Timing Belt Inspection.xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LFS) - Timing Belt Replacement (New Belt).xps
Opel EWD - 2015 - Zafira C - Belts and Chains - 2.0L (LFS) - Timing Belt Replacement (Used Belt).xps
Opel EWD - 2015 - Zafira C - Component Locator - Master Electrical Component List.pdf
Opel EWD - 2015 - Zafira C - Component Locator - X84 Data Link Connector.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Door Component Views - Driver Door Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Door Component Views - Driver Door Trim Panel Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Door Component Views - Left Rear Door Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Door Component Views - Left Rear Door Trim Panel Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Door Component Views - Passenger Door Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Door Component Views - Passenger Door Trim Panel Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Door Component Views - Right Rear Door Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Door Component Views - Right Rear Door Trim Panel Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood Bottom View.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block – Underhood Label.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood Top View.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood X1.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood X2.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood X3.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood X4.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood X5.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood X6.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood X7 (LBQ, LBR, LBS or LBY).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood X7 (LFS or LVL).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood X8 (C32).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50D Fuse Block - Battery Top View.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50D Fuse Block - Battery X1.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50D Fuse Block - Battery X2.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50D Fuse Block - Battery X3.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50D Fuse Block - Battery X4.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50D Fuse Block - Battery X5.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50D Fuse Block - Battery X6 ((LUJ with KL9), LBQ, LBR, LBS or LBY).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X50D Fuse Block - Battery X6 (except ((LUJ with KL9), LBQ, LBR, LBS or LBY)).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X51A Fuse Block - Instrument Panel Bottom View Fuses.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X51A Fuse Block - Instrument Panel Bottom View Relays.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X51A Fuse Block - Instrument Panel Top View Fuses.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X51A Fuse Block - Instrument Panel Top View Relays.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X51A Fuse Block - Instrument Panel Wire Entry Fuses.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X51A Fuse Block - Instrument Panel Wire Entry Relays.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X53A Fuse Block - Rear Body Top View.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X53A Fuse Block - Rear Body X1.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X53A Fuse Block - Rear Body X2.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X53A Fuse Block - Rear Body X3.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X53A Fuse Block - Rear Body X4.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X54E Fuse Block – CNG Top View (LGE).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X55D Fuse Holder - Parking Heater (K07) Wire Entry.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X55D Fuse Holder – Parking Heater F1 (K07).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X55D Fuse Holder – Parking Heater F2 (K07).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X55D Fuse Holder – Parking Heater F3 (K07).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Electrical Center Identification Views - X55D Fuse Holder – Parking Heater Top View (K07).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Front of Vehicle Engine Compartment Component Views - Engine Compartment Components (1 of 2).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Front of Vehicle Engine Compartment Component Views - Engine Compartment Components (2 of 2).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Front of Vehicle Engine Compartment Component Views - Front of Vehicle Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Front of Vehicle Engine Compartment Component Views - Left Front Engine Compartment Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Front of Vehicle Engine Compartment Component Views - Left Front Wheel Well Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Front of Vehicle Engine Compartment Component Views - Rear of Radiator Support Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Front of Vehicle Engine Compartment Component Views - Right Front Engine Compartment Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Ground Views - G101, G103, G105 and G106.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Ground Views - G103 (LFS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Ground Views - G103 (LVL).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Ground Views - G104 (LGE).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Ground Views - G110 and G111.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Ground Views - G112.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Ground Views - G201.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Ground Views - G302 and G305.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Ground Views - G400 and G405.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Ground Views - G401 and G403.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Engine Harness Routing - Left Front (LFS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Engine Harness Routing - Left Rear (LVP or LWC).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Front Bumper Harness Routing.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Inside Rearview Mirror Harness Routing.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Left Front of Engine Harness Routing (LGE).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Left Front of Passenger Compartment Harness Routing (LHD).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Left Rear of Passenger Compartment Harness Routing (LHD).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Left Rear of the Engine Harness Routing (LVL).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Rear Bumper Harness Routing.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Right Front of Passenger Compartment Harness Routing (LHD).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Right Front of the Engine Harness Routing (LVL).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Right Rear of Engine Harness Routing (LGE).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Harness Routing Views - Right Rear of Passenger Compartment Harness Routing (LHD).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - Behind the Instrument Panel Components (Left Hand Drive).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - Behind the Instrument Panel Components (Right Hand Drive).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - Below Center of Instrument Panel Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - Below Right Side of Instrument Panel Components (Right Hand Drive).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - Center Console Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - HVAC Components - Left.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - HVAC Components - Right.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - Instrument Panel Components (Left Hand Drive).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - Instrument Panel Components (Right Hand Drive).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - Steering Column Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Instrument Panel Center Console Component Views - Steering Wheel Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Luggage Compartment Rear of Vehicle Component Views - Liftgate Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Luggage Compartment Rear of Vehicle Component Views - Rear of Vehicle Components - Rear Multifunction Carrier (D9Y).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Luggage Compartment Rear of Vehicle Component Views - Rear of Vehicle Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Passenger Compartment Roof Component Views - Driver Seat Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Passenger Compartment Roof Component Views - Headliner Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Passenger Compartment Roof Component Views - Left Front of Passenger Compartment Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Passenger Compartment Roof Component Views - Left Rear of Passenger Compartment Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Passenger Compartment Roof Component Views - Passenger Seat Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Passenger Compartment Roof Component Views - Right Front of Passenger Compartment Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Passenger Compartment Roof Component Views - Right Rear of Passenger Compartment Components.pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Automatic Transmission Components (MDK).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Automatic Transmission Components (MH8).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Engine Components – Left Front (LFS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Engine Components – Left Rear 1 of 3 (LFS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Engine Components – Left Rear 2 of 3 (LFS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Engine Components – Left Rear 3 of 3 (LFS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Engine Components – Right Front (LFS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Engine Components – Right Rear 1 of 2 (LFS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Engine Components – Right Rear 2 of 2 (LFS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Front of Engine Components (LGE).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Front of the Engine (LVP or LWC).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Front of the Engine Components (LVL).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Left Front of Engine Components (2H0).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Left Front of Engine Components (LBQ, LBR or LBS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Left Rear of Engine Components (2H0).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Left Rear of Engine Components (LBY).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Left Rear of Engine Components (LGE).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Left Rear of Engine Components (LUJ).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Lower Rear of the Engine (LVP).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Manual Transmission Components (M60 or MF3).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Manual Transmission Components (MR6 or MYJ).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Rear of the Engine (LVP or LWC).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Rear of the Engine Compnents (LVL).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Right Front of Engine Components (LBY).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Right Front of Engine Components (LUJ).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Right Front of the Engine Compnents (LVL).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Right Rear of Engine Components (LBQ, LBR or LBS).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Right Rear of Engine Components (LUJ).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Powertrain Component Views - Top of Engine Components (LGE).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Wheels Vehicle Underbody Component Views - Bi-Fuel Tank Components (LGE).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Wheels Vehicle Underbody Component Views - Diesel Fuel Tank Components (LBQ, LBR, LBS or LBY).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Wheels Vehicle Underbody Component Views - Gas Fuel Tank Components (2H0 or LUJ).pdf
Opel EWD - 2015 - Zafira C - Component Locator - Wheels Vehicle Underbody Component Views - Wheel Components.pdf
Opel EWD - 2015 - Zafira C - EWD - Body Repair - Bolted Exterior Body Panels and Closures - Hood Latch Schematics.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Repair - Bumpers and Fascias - Device Controls - Active Grille Air Shutter.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Fixed and Moveable Windows - Defogger Schematics - Rear Window Defogger.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Driver Window (AER).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Left Hand Drive (with C9B and without AER).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Left Hand Drive (without AER and C9B).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Passenger Window (AER).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Rear Windows (AER).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Right Hand Drive (with C9B and without AER).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Right Hand Drive (without AER and C9B).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Horns - Horn.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Exterior Lights Schematics - Controls and Indicators.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Exterior Lights Schematics - Left Park, Tail, and Stop Lamps.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Exterior Lights Schematics - License Plate, Backup, and Center Stop Lamps.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Exterior Lights Schematics - Rear Multifunction Carrier (LHD with D9Y).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Exterior Lights Schematics - Rear Multifunction Carrier (RHD with D9Y).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Exterior Lights Schematics - Right Park, Tail, and Stop Lamps.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Exterior Lights Schematics - Turn Signal and Cornering Lamps.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Fog Lights Schematics - Fog Lights.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Adaptive Forward Lighting (T4F).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Controls and Indicators.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Headlamp Leveling (TR6).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Headlamps - Left (T4F).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Headlamps - Right (T4F).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Headlamps (T4A).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Dimming Controls, Steering Wheel and Instrument Panel Switches.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Door Accent Lamps (C9B).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Door and Roof Switches.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Indicators.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Instrument Cluster, Radio and HVAC Controls and Center Console Switch Backlighting.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Instrument Panel and Center Console Accent Lamps (C9J or DBU).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Interior Lights Schematics - Cargo, Instrument Panel Compartment and Sunshade Lamps.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Interior Lights Schematics - Dome Reading Lamps.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Lighting - Interior Lights Schematics - Lighting Controls.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Mirrors - Inside Rearview Mirror Schematics - Inside Rearview Mirror (DD8, TQ5, UFL or UVY).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Controls and Motors.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Folding Mirrors (DWF).cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Heated Mirrors.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Actuators.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Indicators.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Lock Controls.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Vehicle Access - Release Systems Schematics - Fuel Door.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Vehicle Access - Release Systems Schematics - Liftgate.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Wipers and Washers - Front Wipers.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Wipers and Washers - Rear Wiper Motor.cgm
Opel EWD - 2015 - Zafira C - EWD - Body Systems - Wipers and Washers - Washers and Rear Wiper Switch.cgm
Opel EWD - 2015 - Zafira C - EWD - Brakes - Antilock Brake System - Module Power, Ground, and Serial Data.cgm
Opel EWD - 2015 - Zafira C - EWD - Brakes - Antilock Brake System - Vehicle Stability.cgm
Opel EWD - 2015 - Zafira C - EWD - Brakes - Antilock Brake System - Wheel Speed Signals.cgm
Opel EWD - 2015 - Zafira C - EWD - Brakes - Hydraulic Brakes - Hydraulic Brakes (LHD).cgm
Opel EWD - 2015 - Zafira C - EWD - Brakes - Hydraulic Brakes - Hydraulic Brakes (RHD).cgm
Opel EWD - 2015 - Zafira C - EWD - Brakes - Park Brake - Electric Park Brake (J71).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Cellular Telephone Schematics - Module Power, Ground, Serial Data, Audio Input, and Microphone (UCW with UPH, UPI or UPJ).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Amplifier (UQA).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Auxiliary Audio (without KTA).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Digital Radio Receiver (U4D).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Multimedia Player Interface (KTA).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Radio Antennas.cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Radio Display.cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Radio Power, Ground, Serial Data, and Controls.cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Speakers (U65, U66, or UW4).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Speakers (UQA).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Steering Wheel Controls (UC3).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Voice Navigation (UCW without UPH, UPI, or UPJ).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Displays and Gauges - Audible Warnings Schematics - Audible Warnings.cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Driver Information.cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Indicators (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Module Power, Ground, Serial Data, and Indicators (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Driver Information and Entertainment - Secondary and Configurable Customer Controls - Steering Wheel Controls (K33, K38, or UC3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - 5V1, 5V2, and Low Reference Bus (LUJ) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - 5V3, 5V4, and Low Reference Bus (LUJ) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Barometric Pressure, Intake Pressure, and Air Temperature Sensors (LUJ).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Camshaft and Crankshaft Sensors and Actuators, Knock Sensor (LUJ).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Controlled Monitored Subsystem References (LUJ).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Fuel Controls - Fuel Injectors (LUJ with KL7).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Fuel Injector Control Module - (LUJ with KL7).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Fuel Injectors, and Ignition Controls (LUJ).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Module Power, Ground, Serial Data, and MIL (LUJ).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Oxygen Sensors and Evaporative Emission Controls (LUJ).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Pressure and Temperature Sensors (LUJ with 5EA).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Pressure and Temperature Sensors (LUJ without 5EA).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) Gasoline LPG - Throttle Controls (LUJ).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - 5V1, 5V2 and Low Reference Bus (2H0) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - 5V3, 5V4 and Low Reference Bus (2H0) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Controlled Monitored Subsystem References (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Engine Data Sensors - Oxygen Sensors and Evaporative Emission Controls (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Engine Data Sensors - Pressure and Temperature (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Engine Data Sensors - Throttle Controls (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Fuel Controls - Fuel Injectors and Fuel Pump (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Ignition Controls - Camshaft, Crankshaft and Knock Sensors (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Module Power, Ground, Serial Data, and MIL (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - 5V1, 5V2 and Low Reference Bus (LGE) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - 5V2 and Low Reference Bus (LGE) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Controlled Monitored Subsystem References (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Engine Data Sensors - Oxygen Sensors, Evaporative Emission and Turbocharger Controls (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Engine Data Sensors - Pressure and Temperature (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Engine Data Sensors - Throttle Controls (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Fuel Controls - CNG Cut-Off (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Fuel Controls - CNG Injectors, Pressure and Temperature Controls (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Fuel Controls - Fuel Injectors and Fuel Pump (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Ignition Controls - Camshaft, Crankshaft and Knock Sensors (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Module Power, Ground, Serial Data and MIL (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LGE) - Engine Mechanical - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Oil Level (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - 5V1 and 5V2 (1 of 2) and Low Reference (1 of 3) (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - 5V2 (2 of 2), 5V3 and 5V4 and Low Reference (LVL) (2 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Controlled Monitored Subsystem References (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Emissions Controls - Reductant System (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Exhaust Controls (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Heated Oxygen Sensor and Intake Manifold Runner Control (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Nitrogen Oxides and Reductant Sensor Module (LVL with WM3) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Nitrogen Oxides and Reductant Sensor Module (LVL with WM3) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Nitrogen Oxides and Reductant Sensor Module (LVL without WM3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Oil Pressure Solenoid, Piston Cooling Oil Jet Solenoid, Camshaft and Crankshaft Sensors (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Pressure and Temperature (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Throttle and Turbocharger (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Fuel Controls - Fuel Pump, Fuel Injectors and Water in Fuel (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Fuel Controls - Glow Plugs, Pressure Sensors and Fuel Heater (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Low Reference Bus (LVL) (3 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Module Power, Ground, Serial Data and MIL (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVL) - Engine Mechanical - 1.6L (LVL) Diesel - Engine Oil Level and Pressure Control (LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - 5V1, 5V2 and Low Reference Bus (LVP or LWC with NE4) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - 5V3, 5V4 and Low Reference Bus (LVP or LWC with NE4) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Controlled Monitored Subsystem References (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Engine Data Sensors - Intake Air and Temperature Sensors (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Engine Data Sensors - Pressure and Oxygen Sensors and Thermostat Heater (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Engine Data Sensors - Throttle Controls (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Fuel Controls - Evaporative Emissions, Turbocharger Control and Engine Oil Pressure (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Fuel Controls - Fuel Injectors and High Pressure Control (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Fuel Controls - Fuel Pump (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Ignition Controls - Camshaft, Crankshaft and Knock Sensors, Camshaft Actuators (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Ignition Controls - Ignition Coils (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Module Power, Ground, Serial Data and MIL (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - 5V1, 5V2 and Low Reference Bus (LVP or LWC with NE9) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - 5V3, 5V4 and Low Reference Bus (LVP or LWC with NE9) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Controlled Monitored Subsystem References (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Engine Data Sensors - Intake Air and Temperature Sensors (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Engine Data Sensors - Pressure and Oxygen Sensors and Thermostat Heater (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Engine Data Sensors - Throttle Controls (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Fuel Controls - Evaporative Emissions, Turbocharger Control and Engine Oil Pressure.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Fuel Controls - Fuel Injectors and High Pressure Control (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Fuel Controls - Fuel Pump (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Ignition Controls - Camshaft, Crankshaft and Knock Sensors, Camshaft Actuators (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Ignition Controls - Ignition Coils (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Module Power, Ground, Serial Data and MIL (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LVP) - Engine Mechanical - 1.6L (LVP, LWC) - Engine Oil Level and Pressure Control (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - 5V1, 5V2 and Low Reference Bus (LVP or LWC with NE4) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - 5V3, 5V4 and Low Reference Bus (LVP or LWC with NE4) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Controlled Monitored Subsystem References (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Engine Data Sensors - Intake Air and Temperature Sensors (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Engine Data Sensors - Pressure and Oxygen Sensors and Thermostat Heater (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Engine Data Sensors - Throttle Controls (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Fuel Controls - Evaporative Emissions, Turbocharger Control and Engine Oil Pressure (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Fuel Controls - Fuel Injectors and High Pressure Control (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Fuel Controls - Fuel Pump (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Ignition Controls - Camshaft, Crankshaft and Knock Sensors, Camshaft Actuators (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Ignition Controls - Ignition Coils (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE4) - Module Power, Ground, Serial Data and MIL (LVP or LWC with NE4).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - 5V1, 5V2 and Low Reference Bus (LVP or LWC with NE9) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - 5V3, 5V4 and Low Reference Bus (LVP or LWC with NE9) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Controlled Monitored Subsystem References (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Engine Data Sensors - Intake Air and Temperature Sensors (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Engine Data Sensors - Pressure and Oxygen Sensors and Thermostat Heater (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Engine Data Sensors - Throttle Controls (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Fuel Controls - Evaporative Emissions, Turbocharger Control and Engine Oil Pressure.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Fuel Controls - Fuel Injectors and High Pressure Control (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Fuel Controls - Fuel Pump (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Ignition Controls - Camshaft, Crankshaft and Knock Sensors, Camshaft Actuators (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Ignition Controls - Ignition Coils (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LVP, LWC) - Engine Controls Schematics (LVP or LWC with NE9) - Module Power, Ground, Serial Data and MIL (LVP or LWC with NE9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.6L (LWC) - Engine Mechanical - 1.6L (LVP, LWC) - Engine Oil Level and Pressure Control (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - 5V1, 5V2 and Low Reference Bus (2H0) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - 5V3, 5V4 and Low Reference Bus (2H0) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Controlled Monitored Subsystem References (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Engine Data Sensors - Oxygen Sensors and Evaporative Emission Controls (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Engine Data Sensors - Pressure and Temperature (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Engine Data Sensors - Throttle Controls (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Fuel Controls - Fuel Injectors and Fuel Pump (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Ignition Controls - Camshaft, Crankshaft and Knock Sensors (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (2H0) - Module Power, Ground, Serial Data, and MIL (2H0).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - 5V1, 5V2 and Low Reference Bus (LGE) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - 5V2 and Low Reference Bus (LGE) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Controlled Monitored Subsystem References (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Engine Data Sensors - Oxygen Sensors, Evaporative Emission and Turbocharger Controls (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Engine Data Sensors - Pressure and Temperature (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Engine Data Sensors - Throttle Controls (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Fuel Controls - CNG Cut-Off (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Fuel Controls - CNG Injectors, Pressure and Temperature Controls (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Fuel Controls - Fuel Injectors and Fuel Pump (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Ignition Controls - Camshaft, Crankshaft and Knock Sensors (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Controls Schematics (LGE) - Module Power, Ground, Serial Data and MIL (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 1.8L (2H0) - Engine Mechanical - 1.6L (LGE) CNG or 1.8L (2H0) - Engine Oil Level (LGE).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - 5V1, 5V2 and Low Reference Bus (LBQ, LBR, LBX or LBS) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - 5V2, 5V3 and Low Reference Bus (LBQ, LBR, LBX or LBS) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Controlled Monitored Subsystem References (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Crankcase Ventilation, Exhaust, Intake Manifold Runner and Wastegate (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Glow Plug Controls (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Oxygen, Water in Fuel and Fuel Heater (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Pressure and Temperature (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Throttle Controls (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Fuel Controls - Fuel Injectors, Fuel Pump and Pressure, Engine Oil Pressure (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Ignition Controls - Camshaft and Crankshaft Sensors (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Module Power, Ground, Serial Data and MIL (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - 5V1, 5V2 and Low Reference Bus (LBY) (1 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - 5V2, 5V3 and Low Reference Bus (LBY) (2 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Controlled Monitored Subsystem References (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Crankcase Ventilation, Exhaust, Intake Manifold Runner and Wastegate (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Glow Plug Controls (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Oxygen, Water in Fuel and Fuel Heater (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Pressure and Temperature (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Throttle Controls (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Fuel Controls - Fuel Injectors, Fuel Pump and Pressure (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Fuel Controls - Fuel Pressure, Exhaust Pressure and Temperature (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Ignition Controls - Camshaft and Crankshaft Sensors, Exhaust Gas Recirculation (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Low Reference Bus (LBY) (3 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Module Power, Ground, Serial Data and MIL (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBQ) - Engine Mechanical - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Oil Level and Pressure Control (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - 5V1, 5V2 and Low Reference Bus (LBQ, LBR, LBX or LBS) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - 5V2, 5V3 and Low Reference Bus (LBQ, LBR, LBX or LBS) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Controlled Monitored Subsystem References (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Crankcase Ventilation, Exhaust, Intake Manifold Runner and Wastegate (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Glow Plug Controls (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Oxygen, Water in Fuel and Fuel Heater (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Pressure and Temperature (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Throttle Controls (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Fuel Controls - Fuel Injectors, Fuel Pump and Pressure, Engine Oil Pressure (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Ignition Controls - Camshaft and Crankshaft Sensors (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Module Power, Ground, Serial Data and MIL (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - 5V1, 5V2 and Low Reference Bus (LBY) (1 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - 5V2, 5V3 and Low Reference Bus (LBY) (2 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Controlled Monitored Subsystem References (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Crankcase Ventilation, Exhaust, Intake Manifold Runner and Wastegate (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Glow Plug Controls (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Oxygen, Water in Fuel and Fuel Heater (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Pressure and Temperature (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Throttle Controls (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Fuel Controls - Fuel Injectors, Fuel Pump and Pressure (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Fuel Controls - Fuel Pressure, Exhaust Pressure and Temperature (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Ignition Controls - Camshaft and Crankshaft Sensors, Exhaust Gas Recirculation (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Low Reference Bus (LBY) (3 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Module Power, Ground, Serial Data and MIL (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBR) - Engine Mechanical - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Oil Level and Pressure Control (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - 5V1, 5V2 and Low Reference Bus (LBQ, LBR, LBX or LBS) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - 5V2, 5V3 and Low Reference Bus (LBQ, LBR, LBX or LBS) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Controlled Monitored Subsystem References (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Crankcase Ventilation, Exhaust, Intake Manifold Runner and Wastegate (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Glow Plug Controls (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Oxygen, Water in Fuel and Fuel Heater (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Pressure and Temperature (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Throttle Controls (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Fuel Controls - Fuel Injectors, Fuel Pump and Pressure, Engine Oil Pressure (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Ignition Controls - Camshaft and Crankshaft Sensors (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Module Power, Ground, Serial Data and MIL (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - 5V1, 5V2 and Low Reference Bus (LBY) (1 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - 5V2, 5V3 and Low Reference Bus (LBY) (2 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Controlled Monitored Subsystem References (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Crankcase Ventilation, Exhaust, Intake Manifold Runner and Wastegate (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Glow Plug Controls (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Oxygen, Water in Fuel and Fuel Heater (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Pressure and Temperature (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Throttle Controls (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Fuel Controls - Fuel Injectors, Fuel Pump and Pressure (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Fuel Controls - Fuel Pressure, Exhaust Pressure and Temperature (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Ignition Controls - Camshaft and Crankshaft Sensors, Exhaust Gas Recirculation (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Low Reference Bus (LBY) (3 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Module Power, Ground, Serial Data and MIL (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBS) - Engine Mechanical - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Oil Level and Pressure Control (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - 5V1, 5V2 and Low Reference Bus (LBQ, LBR, LBX or LBS) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - 5V2, 5V3 and Low Reference Bus (LBQ, LBR, LBX or LBS) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Controlled Monitored Subsystem References (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Crankcase Ventilation, Exhaust, Intake Manifold Runner and Wastegate (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Glow Plug Controls (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Oxygen, Water in Fuel and Fuel Heater (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Pressure and Temperature (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Throttle Controls (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Fuel Controls - Fuel Injectors, Fuel Pump and Pressure, Engine Oil Pressure (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Ignition Controls - Camshaft and Crankshaft Sensors (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Module Power, Ground, Serial Data and MIL (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - 5V1, 5V2 and Low Reference Bus (LBY) (1 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - 5V2, 5V3 and Low Reference Bus (LBY) (2 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Controlled Monitored Subsystem References (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Crankcase Ventilation, Exhaust, Intake Manifold Runner and Wastegate (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Glow Plug Controls (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Oxygen, Water in Fuel and Fuel Heater (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Pressure and Temperature (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Throttle Controls (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Fuel Controls - Fuel Injectors, Fuel Pump and Pressure (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Fuel Controls - Fuel Pressure, Exhaust Pressure and Temperature (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Ignition Controls - Camshaft and Crankshaft Sensors, Exhaust Gas Recirculation (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Low Reference Bus (LBY) (3 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Module Power, Ground, Serial Data and MIL (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBX) - Engine Mechanical - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Oil Level and Pressure Control (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - 5V1, 5V2 and Low Reference Bus (LBQ, LBR, LBX or LBS) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - 5V2, 5V3 and Low Reference Bus (LBQ, LBR, LBX or LBS) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Controlled Monitored Subsystem References (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Crankcase Ventilation, Exhaust, Intake Manifold Runner and Wastegate (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Glow Plug Controls (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Oxygen, Water in Fuel and Fuel Heater (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Pressure and Temperature (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Engine Data Sensors - Throttle Controls (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Fuel Controls - Fuel Injectors, Fuel Pump and Pressure, Engine Oil Pressure (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Ignition Controls - Camshaft and Crankshaft Sensors (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBQ, LBR, LBS, LBX) - Module Power, Ground, Serial Data and MIL (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - 5V1, 5V2 and Low Reference Bus (LBY) (1 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - 5V2, 5V3 and Low Reference Bus (LBY) (2 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Controlled Monitored Subsystem References (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Crankcase Ventilation, Exhaust, Intake Manifold Runner and Wastegate (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Glow Plug Controls (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Oxygen, Water in Fuel and Fuel Heater (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Pressure and Temperature (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Engine Data Sensors - Throttle Controls (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Fuel Controls - Fuel Injectors, Fuel Pump and Pressure (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Fuel Controls - Fuel Pressure, Exhaust Pressure and Temperature (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Ignition Controls - Camshaft and Crankshaft Sensors, Exhaust Gas Recirculation (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Low Reference Bus (LBY) (3 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Controls and Fuel - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Controls Schematics (LBY) - Module Power, Ground, Serial Data and MIL (LBY).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LBY) - Engine Mechanical - 2.0L (LBQ, LBR, LBS, LBX and LBY) Diesel - Engine Oil Level and Pressure Control (LBQ, LBR, LBX or LBS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Cruise Control - Adaptive Cruise Control Module (K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Cruise Control - Cruise Control (K33 or K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - 5V1, 5V2 and Low Reference (LFS) (1 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - 5V2, 5V3 and Low Reference Bus (LFS) (2 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Controlled Monitored Subsystem References (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Emissions Controls - Reductant System (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Exhaust Controls (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Heated Oxygen Sensor and Intake Manifold Runner Control (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Nitrogen Oxides and Reductant Sensor Module (LFS) (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Nitrogen Oxides and Reductant Sensor Module (LFS) (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Oil Pressure Solenoid, Piston Cooling, Oil Jet Solenoid, Camshaft and Crankshaft Sensors (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Pressure and Temperature (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Throttle and Turbocharger (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Fuel Controls - Fuel Pump, Fuel Injectors and Water in Fuel (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Fuel Controls - Glow Plugs, Pressure Sensors and Fuel Heater (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Low Reference Bus (LFS) (3 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Module Power, Ground, Serial Data and MIL (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Heating and Cooling - 2H0, LGE, LUJ or LVP.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LVP or LWC).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Heating and Cooling - Coolant Pump Clutch (LVL or LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Heating and Cooling - LBS with MDK, LVL with C2, LBY or LFS.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Heating and Cooling - LBS with MYJ, LVL with C1, LBR or LBQ.cgm
Opel EWD - 2015 - Zafira C - EWD - Engine - 2.0L (LFS) - Engine Mechanical - 2.0L (LFS) Diesel - Engine Oil Level and Pressure Control (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Automatic - AC Compressor Controls (CJ2).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Automatic - Ambient Light and Windshield Sensors (CJ2).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Automatic - Auxiliary Heater (C32 with CJ2).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Automatic - Coolant Pump - Auxiliary (LVP or LWC with CJ2).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Automatic - Mode and Temperature Control Actuators (CJ2).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Automatic - Module Power, Ground, Serial Data, Controls (CJ2).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Automatic - Parking Heater Power, Ground, Diagnostic Connector and Serial Data.cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Automatic - Parking Heater Sensors and Controls.cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Automatic - Parking Heater Switch.cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Automatic - Temperature Sensors (CJ2).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Manual - AC Compressor Controls (C42 or C67).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Manual - Air Delivery and Temperature Control (C42 or C67).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Manual - Auxiliary Heater (C32 with C42 or C67).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Manual - Blower Motor Controls (C42 or C67).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Manual - Coolant Pump - Auxiliary (LVP or LWC with C42 or C67).cgm
Opel EWD - 2015 - Zafira C - EWD - HVAC - HVAC - Manual - Module Power, Ground, Serial Data and Controls (C42 or C67).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Body Control System Schematics - Module Power, Ground, and Serial Data.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Body Control System Schematics - Subsystem References (1 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Body Control System Schematics - Subsystem References (2 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Body Control System Schematics - Subsystem References (3 of 3).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Data Communication Schematics - Communications Enable.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Data Communication Schematics - High Speed Chassis GMLAN.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Data Communication Schematics - High Speed GMLAN.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Data Communication Schematics - Linear Interconnect Network (LIN).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Data Communication Schematics - Low Speed GMLAN.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Data Communication Schematics - Mid Speed GMLAN.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Data Communication Schematics - Powertrain Expansion Bus (LFS).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Data Communication Schematics - Powertrain Expansion Bus (LVL with WM3).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power and Signal Distribution - Data Communication Schematics - Powertrain Expansion Bus (LVL without WM3).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Power Outlets - Cigar Lighter Power Outlet Schematics - Accessory Power Outlets.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G101 (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G101 (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G102, G104, G105 and G106.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G103 (2H0, LGE, or LUJ).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G103 (LBQ, LBR, LBS, LBY or LVL).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G110, G111, and G112.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G201 (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G201 (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G202 and G204.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G203 (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G203 (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G302 (1 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G302 (2 of 2).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G303, G400, and G401.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G305.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G403.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G405.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ignition Lock Schematics - Ignition Lock Schematics.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - B+ Bus (1 of 4).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - B+ Bus (2 of 4).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - B+ Bus (3 of 4).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - B+ Bus (4 of 4).cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F01UA, F03UA and F07UA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F02UA, F27UA and F36UA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F04UA and F08UA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F05UA, F32UA, F51UA and F54UA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F11RA, F12RA, F13RA, F14RA, F15RA, F16RA, F17RA, F19RA, F20RA, F21RA, F27RA, F31RA and F4UD Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F14DA, F15DA, F16DA, F17DA, F19DA, F20DA, F21DA, F22DA, F23DA, F24DA, F25DA and F26DA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F14UA, F26UA, F45UA, and F48UA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F1RA, F2RA, F3RA, F4RA, F7RA, F8RA, F9RA, F10RA, F24RA, F26RA, F32RA and F21UA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F1UA, F3UA, F4UA, F10UA, F12UA, F13UA, F15UA, F17UA, F19UA, F20UA and F30UA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F22DA Fuse and Ignition Switch.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F28UA, F29UA, F35UA, F36UA, F38UA, F39UA, F43UA and F44UA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F2DA, F3DA, F8DA, F9DA, F10DA, F11DA, F2UD Fuses and F12DA and F13DA Circuit Breaker.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F33UA, F49UA, F50UA, F52UA and F53UA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F4DA, F5DA, F6DA, F7DA, F18DA and F1UD Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - F6UA, F18UA, F22UA, F24UA, F25UA, F41UA and F47UA Fuses.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Moding Schematics - Auxilliary Power and Ignition Run Relays.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Moding Schematics - Ignition Main Relays.cgm
Opel EWD - 2015 - Zafira C - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Trailer Connector Provision Schematics - Trailer Lighting Controls (D9Y or VQ9).cgm
Opel EWD - 2015 - Zafira C - EWD - Roof - Sunroof Schematics - Fixed Glass Sunroof (C06).cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Immobilizer - Immobilizer.cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Object Detection - Front and Side Object Sensors (UD5 or UDP).cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Object Detection - Module Power, Ground, Serial Data, Rear and Side Object Sensors, Controls, and Display (LHD).cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Object Detection - Module Power, Ground, Serial Data, Rear and Side Object Sensors, Controls, and Display (RHD).cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Object Detection - Rear Vision Camera (UVC).cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Object Detection - Vehicle Direction Camera (UFL or UVY).cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Remote Functions - Keyless Entry.cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Seat Belts - Seat Belts.cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Supplemental Inflatable Restraints - Front Impact Sensing and Deployment.cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Supplemental Inflatable Restraints - Module Power, Ground, Serial Data, and Indicators.cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Supplemental Inflatable Restraints - Side Impact Sensing and Deployment.cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Theft Deterrent - Glass Breakage Sensors and Indicator.cgm
Opel EWD - 2015 - Zafira C - EWD - Safety and Security - Theft Deterrent - Theft Deterrent (UTR or UTU).cgm
Opel EWD - 2015 - Zafira C - EWD - Seats - Power Seats - Driver Seat Schematics - Lumbar Switch and Motors (AL9).cgm
Opel EWD - 2015 - Zafira C - EWD - Seats - Power Seats - Driver Seat Schematics - Seat Adjuster Switch and Motors (AG1).cgm
Opel EWD - 2015 - Zafira C - EWD - Seats - Power Seats - Passenger Seat Schematics - Lumbar Switch and Motors (AT9).cgm
Opel EWD - 2015 - Zafira C - EWD - Seats - Seat Heating and Cooling - Module Power, Ground, Serial Data, and Controls.cgm
Opel EWD - 2015 - Zafira C - EWD - Seats - Seat Heating and Cooling - Seat Heating Elements (KA1).cgm
Opel EWD - 2015 - Zafira C - EWD - Steering - Power Steering - Electric Power Steering (NJ1).cgm
Opel EWD - 2015 - Zafira C - EWD - Steering - Steering Wheel and Column - Heated Steering Wheel (UVD with K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Steering - Steering Wheel and Column - Heated Steering Wheel (UVD without K38).cgm
Opel EWD - 2015 - Zafira C - EWD - Suspension - Electronic Suspension Control - Module Power, Ground, and Serial Data.cgm
Opel EWD - 2015 - Zafira C - EWD - Suspension - Electronic Suspension Control - Sensors and Actuators.cgm
Opel EWD - 2015 - Zafira C - EWD - Suspension - Electronic Suspension Control - Tour Mode and Sport Mode Switches.cgm
Opel EWD - 2015 - Zafira C - EWD - Transmission - Automatic Transmission - 6T40 (MH8) or 6T45 (MH7) - Internal Mode Switch and Manual Shift Switch.cgm
Opel EWD - 2015 - Zafira C - EWD - Transmission - Automatic Transmission - 6T40 (MH8) or 6T45 (MH7) - Module Power, Ground, Serial Data, and MIL.cgm
Opel EWD - 2015 - Zafira C - EWD - Transmission - Automatic Transmission - 6T40 (MH8) or 6T45 (MH7) - Shift Lever Position Indicator.cgm
Opel EWD - 2015 - Zafira C - EWD - Transmission - Automatic Transmission - 6T40 (MH8) or 6T45 (MH7) - Speed and Temperature Sensors, Pressure and Shift Controls.cgm
Opel EWD - 2015 - Zafira C - EWD - Transmission - Automatic Transmission - AF40-6 (MDK) - Module Power, Ground, Serial Data, MIL, and Tap Up Tap Down.cgm
Opel EWD - 2015 - Zafira C - EWD - Transmission - Automatic Transmission - AF40-6 (MDK) - Shift Lever Position Indicator.cgm
Opel EWD - 2015 - Zafira C - EWD - Transmission - Automatic Transmission - AF40-6 (MDK) - Speed and Temperature Sensors, Pressure and Shift Controls.cgm
Opel EWD - 2015 - Zafira C - EWD - Transmission - Manual Transmission - M32-6 (M60, MF3, MR5, MZ0) - 6-Speed (MF3 or M60).cgm
Opel EWD - 2015 - Zafira C - Specifications - Approximate Fluid Capacities.pdf
