Opel Zafira B 2013 Electrical Wiring Diagrams & Component Locations
Type of Document: Electrical Wiring Diagrams, Component Locations
Model: 2013 Opel Zafira B
Format: PDF, CGM, XPS, HTM
Opel EWD - 2013 - Zafira B - Service Interval reset 2013 MY.pdf
Opel EWD - 2013 - Zafira B - Belts and Chains - A16XER_Z16XER_A18XER - Replace ribbed V-belt tensioner.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A16XER_Z16XER_A18XER - Replace ribbed V-belt.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A16XER_Z16XER_A18XER - Replace toothed belt.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A16XER_Z16XER_A18XER - Timing, Adjust.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A16XER_Z16XER_A18XER - Timing, Check.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A16XNT - Replace auxiliary drive.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A16XNT - Replace timing drive.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A16XNT - Timing, Adjust.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A16XNT - Timing, Check.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A17DTJ_A17DTR - Replace ribbed V-belt tensioner.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A17DTJ_A17DTR - Replace ribbed V-belt.xps
Opel EWD - 2013 - Zafira B - Belts and Chains - A17DTJ_A17DTR - Replace toothed belt.xps
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10435846.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10435847.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10435849.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10435850.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10437238.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438904.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438905.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438906.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438907.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438910.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438911.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438914.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438915.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438916.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438917.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438918.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438920.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438921.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438922.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438923.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438924.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438926.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438927.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438928.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438931.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438932.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438933.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10438934.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10440043.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10440108.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10440127.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10440150.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10440152.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10440153.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10440154.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10440156.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 10440157.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42978994.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42978995.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42978996.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42978997.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42978998.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42978999.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42979000.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42979001.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42979002.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42979003.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42979004.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42979005.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42979006.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42979007.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42979008.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 42979009.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179287.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179288.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179290.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179291.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179292.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179319.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179326.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179327.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179328.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179330.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179331.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179332.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179334.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179335.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179359.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179363.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179369.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179371.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179372.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179373.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179374.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179376.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179377.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179378.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179380.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179381.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179382.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179383.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179384.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179385.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179386.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179387.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179390.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179391.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179392.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179393.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179395.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179397.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179398.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179399.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179400.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179401.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179402.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179403.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179404.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179405.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179406.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179407.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179408.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179409.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179410.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179411.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179412.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179413.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179414.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179415.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179416.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179417.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179420.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179421.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179423.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179424.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179425.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179490.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179491.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179492.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179493.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179494.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179495.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179499.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179500.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179513.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179514.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - 9179516.cgm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - D-pillar, left Left-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - D-pillar, left Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - D-pillar, left.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - D-pillar, right Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - D-pillar, right.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - Fuel Tank.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - Rear - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - Rear - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - Rear - 3.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - Rear electronic module.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - Under vehicle - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - Under vehicle - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - Under vehicle - 3.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - Wheel suspension, left.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Body rear - Wheel suspension, right.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Driver door Left-hand drive - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Driver door Left-hand drive - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Driver door Right-hand drive - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Driver door Right-hand drive - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Front passenger door Left-hand drive - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Front passenger door Left-hand drive - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Front passenger door Right-hand drive - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Front passenger door Right-hand drive - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Rear door, left - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Rear door, left - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Rear door, right - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Rear door, right - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Doors - Tailgate.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Behind front panelling, right.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Front, left Engine A16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Front, left Engine Z16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Front, left.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Headlamp, left Not xenon lights.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Headlamp, right Not xenon lights.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Left.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Radiator Air conditioning, compressor.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Radiator Engine A18XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Radiator Engine Z16XEP.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Radiator Engine Z18XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Radiator.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Rear.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Right - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Right - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Steering house Electrical power steering (TRW).htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Steering house Electrical power steering (ZF).htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Under vehicle Engine A16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Under vehicle Engine Z16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Under vehicle Engine Z16YNG.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Underhood electrical centre.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Wheel house, left Not semi active damping system.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Wheel house, left Semi active damping system.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Wheel house, right Airbag with side airbags.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment - Wheel house, right Not semi active damping system.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment, side panel, right Engine A16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Engine compartment, side panel, right Engine Z16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Front end - Behind front panelling Not OPC.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Front end - Behind front panelling.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Left Front of the Vehicle Components Engine A16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Left Front of the Vehicle Components Engine Z16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Air conditioning Air conditioning - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Air conditioning Air conditioning - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - A-pillar, left _ B-pillar, left Left-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - A-pillar, left _ B-pillar, left Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - A-pillar, right _ B-pillar, right Left-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - A-pillar, right _ B-pillar, right Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Behind instrument panel Left-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Behind instrument panel Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Behind instrument panel, left Left-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Behind instrument panel, left Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Behind instrument panel, left.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Behind instrument panel, right Left-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Behind instrument panel, right Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Centre console _ Under front seats Left-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Centre console _ Under front seats Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Centre console, selector lever.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Climate control - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Climate control - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Heating Heating.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Heating_air conditioning.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Roof, front - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Roof, front - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Roof, front _ A-pillar, left Panoramic roof.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Roof, front Not panoramic roof.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Roof, rear - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Roof, rear - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Roof.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Steering column.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Passenger compartment - Steering wheel.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, control unit Engine A16XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, control unit Engine Z16XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, distribution side A17DTJ_A17DTR Engines.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, distribution side Engine A16XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, distribution side Engine A18XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, distribution side Engine Z16XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, distribution side Engine Z16YNG.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, distribution side Engine Z18XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, exhaust side A17DTJ_A17DTR Engines - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, exhaust side A17DTJ_A17DTR Engines - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, exhaust side A17DTJ_A17DTR Engines - 3.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side _ Distribution side Engine Z16YNG.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side _ Transmission side A17DTJ_A17DTR Engines.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side A17DTJ_A17DTR Engines - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side A17DTJ_A17DTR Engines - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine A16XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine A18XER - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine A18XER - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine A18XER - 3.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine A18XER - 4.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine Z16XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine Z16YNG - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine Z16YNG - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine Z16YNG - 3.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine Z18XER - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine Z18XER - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine Z18XER - 3.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, intake side Engine Z18XER - 4.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, overview Engine A18XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, overview Engine Z18XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, top A17DTJ_A17DTR Engines.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, top Engine A16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, top Engine Z16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, transmission side Engine A18XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, transmission side Engine Z16XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Engine, transmission side Engine Z18XER.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Manual transmission automatically shifted - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Manual transmission automatically shifted - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - 3D Harness Diagram - Power train - Manual transmission Engine Z16YNG.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 10439972.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 10439973.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 10440128.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179329.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179333.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179358.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179364.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179365.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179368.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179370.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179375.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179379.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179388.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179389.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179394.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179422.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - 9179489.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - A - pillar, left.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - A - pillar, right.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Battery.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Body, front, left - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Body, front, left - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Body, rear, left _ D - pillar, left.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Cross member, instrument panel Left-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Cross member, instrument panel Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Engine compartment, left.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Engine compartment, right.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Engine Engine Z16YNG - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Engine Engine Z16YNG - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Engine Engine Z18XER - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Engine Engine Z18XER - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Front frame side member, left.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Roof, rear.htm
Opel EWD - 2013 - Zafira B - Component Locations - Grounding Point - Tunnel.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - 10436690.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - 10436691.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - 10436692.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - 10438925.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - 10439974.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - 9179262.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - 9179485.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - Body rear - Fuse & Relay box rear Fog lamps, front Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - Body rear - Fuse & Relay box rear Left-hand drive Fog lamps, front.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - Body rear - Fuse & Relay box rear Not fog lamps, front.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - Engine compartment - Front, left Engine Z16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - Engine compartment - Fuse box.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - Engine compartment - Underhood electrical centre.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Fuses - REC - Fuses.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - 10436689.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - 10436690.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - 10436691.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - 10436692.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - 10438925.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - 10440092.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - 10440093.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - 9179259.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - 9179496.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - 9179606.cgm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - Body rear - Fuse & Relay box rear Fog lamps, front Right-hand drive.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - Body rear - Fuse & Relay box rear Left-hand drive Fog lamps, front.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - Body rear - Fuse & Relay box rear Not fog lamps, front.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - Body rear - Rear, left - 1.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - Body rear - Rear, left - 2.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - Engine compartment - Front, left Engine Z16XNT.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - Engine compartment - Radiator Not Z19DT_Z19DTL engines (Manual transmission as of MY2006 1_2) Not engine Z20LER Not engine Z22YH.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - Engine compartment - Underhood electrical centre Not rear electronic module Petrol.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - Engine compartment - Underhood electrical centre Rear electronic module.htm
Opel EWD - 2013 - Zafira B - Component Locations - Relays and Fuses - Relays - REC - Relays.htm
Opel EWD - 2013 - Zafira B - EWD - Body Equipment - Airbag - 42978783.cgm
Opel EWD - 2013 - Zafira B - EWD - Body Equipment - Airbag - 42978784.cgm
Opel EWD - 2013 - Zafira B - EWD - Body Equipment - Airbag - Airbag (SDM, Temic) - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Body Equipment - Airbag - Airbag (SDM, Temic) - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Body Equipment - Glass, Window Guides, Window Winders - Inner Rear View Mirror - 42978808.cgm
Opel EWD - 2013 - Zafira B - EWD - Body Equipment - Glass, Window Guides, Window Winders - Inner Rear View Mirror - Electrochromatic inside mirror.htm
Opel EWD - 2013 - Zafira B - EWD - Body Equipment - Glass, Window Guides, Window Winders - Outside Rear View Mirror - 42978805.cgm
Opel EWD - 2013 - Zafira B - EWD - Body Equipment - Glass, Window Guides, Window Winders - Outside Rear View Mirror - Outside mirror (Left-hand drive).htm
Opel EWD - 2013 - Zafira B - EWD - Body Equipment - Glass, Window Guides, Window Winders - Outside Rear View Mirror - Outside mirror (Right-hand drive).htm
Opel EWD - 2013 - Zafira B - EWD - Brakes - ABS MK60 ESP - 42978766.cgm
Opel EWD - 2013 - Zafira B - EWD - Brakes - ABS MK60 ESP - Anti-Lock Brake System (ABS MK60 ESP).htm
Opel EWD - 2013 - Zafira B - EWD - Brakes - ABS MK70 - 42978766.cgm
Opel EWD - 2013 - Zafira B - EWD - Brakes - ABS MK70 - Anti-Lock Brake System (ABS MK70).htm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Automatic Transmission Front Wheel Drive - Automatic 6-Speed Transmission AF 40 - 31614235.cgm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Automatic Transmission Front Wheel Drive - Automatic 6-Speed Transmission AF 40 - 31614236.cgm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Automatic Transmission Front Wheel Drive - Automatic 6-Speed Transmission AF 40 - Automatic transmission (AF40_6).htm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Automatic Transmission Front Wheel Drive - Automatic 6-Speed Transmission AF 40 - Selector lever module (AF40_6).htm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Automatic Transmission Front Wheel Drive - Automatic Transmission AF 13_17_14_20_22_30 - 42978762.cgm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Automatic Transmission Front Wheel Drive - Automatic Transmission AF 13_17_14_20_22_30 - 42978763.cgm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Automatic Transmission Front Wheel Drive - Automatic Transmission AF 13_17_14_20_22_30 - Automatic transmission (AF22_4).htm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Automatic Transmission Front Wheel Drive - Automatic Transmission AF 13_17_14_20_22_30 - Selector lever module (AF22_4).htm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Automatic Transmission Front Wheel Drive - Automatic Transmission AF 13_17_14_20_22_30 - Switch, automatic transmission (AF22_4).htm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Clutch - 42978764.cgm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Clutch - Clutch switch.htm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Manual Transmission Front Wheel Drive - Manual Transmission F 10_F 13_F 15_F 17, Easytronic F 13_F 17_M 20 - 42978765.cgm
Opel EWD - 2013 - Zafira B - EWD - Clutch and Transmission - Manual Transmission Front Wheel Drive - Manual Transmission F 10_F 13_F 15_F 17, Easytronic F 13_F 17_M 20 - Manual transmission automatically shifted (F17_5).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Anti-Theft Warning System - 42978793.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Anti-Theft Warning System - Anti-theft warning system.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CAN-Bus - 10440082.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CAN-Bus - 10440141.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CAN-Bus - 42978778.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CAN-Bus - 42978779.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CAN-Bus - 42978780.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CAN-Bus - CAN-bus (Not rear electronic module) - Block Diagram.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CAN-Bus - CAN-bus (rear electronic module) - Block Diagram.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CAN-Bus - CAN-bus high speed.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CAN-Bus - CAN-bus low speed.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CAN-Bus - CAN-bus mid speed.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - 42978790.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - 42978791.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - 42978792.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - 42978793.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - 42978812.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - 42978813.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - 42978815.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - 42978818.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - 42978819.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - Central door locking (not rear electronic module & not Open & Start).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - Central door locking (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - Central door locking (Open & Start) - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - Central door locking (Open & Start) - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - Central door locking (rear electronic module & not Open & Start).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - Central door locking (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - Open & Start - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - Open & Start - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Door Locking System - Open & Start - 3.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - 42978790.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - 42978791.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - 42978792.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - 42978793.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - 42978802.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - 42978812.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - 42978813.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - 42978815.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - 42978818.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - 42978819.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Anti-theft warning system.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Central door locking (not rear electronic module & not Open & Start).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Central door locking (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Central door locking (Open & Start) - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Central door locking (Open & Start) - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Central door locking (rear electronic module & not Open & Start).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Central door locking (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Open & Start - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Open & Start - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Open & Start - 3.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Central Locking with ATWS (electronic) - Sensor, anti-theft warning system.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CID (Colour Info Display) - 42978782.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CID (Colour Info Display) - 42978833.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CID (Colour Info Display) - Info Display.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - CID (Colour Info Display) - Switch unit - Steering column, right.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Antenna, microphone and AUX - 42978801.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Antenna, microphone and AUX - 42978830.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Antenna, microphone and AUX - 42978832.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Antenna, microphone and AUX - Antenna.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Antenna, microphone and AUX - AUX-IN Connector.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Antenna, microphone and AUX - Microphone.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Mobile telephone - 42978832.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Mobile telephone - Voice controlled telephone.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - On-Star system - 42978801.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - On-Star system - Microphone.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - 42978782.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - 42978809.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - 42978828.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - 42978829.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - 42978830.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - 42978831.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - Digital audio broadcast.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - Radio.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - Remote control, radio (Dalphimetal steering wheel).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - Remote control, radio (Takata-Petri steering wheel).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - Speakers, front doors, left side.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - Speakers, front doors, right side.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - Speakers, Instrument panel.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - Speakers, rear doors.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Communication_navigation - Radio - Twin audio.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electrical Socket Front_Rear - 42978802.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electrical Socket Front_Rear - Accessory socket.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electrical Window Winders - 42978806.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electrical Window Winders - 42978807.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electrical Window Winders - Window lifters, rear doors.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electrical Window Winders - Window lifters.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 10440078.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 10440146.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978764.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978772.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978773.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978776.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978778.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978780.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978781.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978782.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978783.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978800.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978812.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 42978831.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - 9179433.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - Block Diagram - Column integrated module (Not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - Block Diagram - Column integrated module (Rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - Block Diagram - Column integrated module (voltage distrubution).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 10.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 11.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 12.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 3.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 4.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 5.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 6.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 7.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 8.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - CIM - CIM - 9.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - Diagnostic Link - 42978781.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - Diagnostic Link - Diagnostic link.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978768.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978770.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978778.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978785.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978787.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978790.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978791.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978794.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978799.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978802.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978810.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978818.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978823.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978824.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - 42978826.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 10.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 11.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 12.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 13.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 14.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 15.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 3.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 4.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 5.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 6.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 7.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 8.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - IPC - IPC - 9.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - Open & Start - 42978812.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - Open & Start - 42978813.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - Open & Start - 42978815.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - Open & Start - Open & Start - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - Open & Start - Open & Start - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - Open & Start - Open & Start - 3.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978747.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978754.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978772.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978773.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978774.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978775.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978777.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978778.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978789.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978790.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978791.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978792.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978793.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978794.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978798.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978799.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978800.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978801.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978802.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978804.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978810.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978812.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978823.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - 42978826.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 10.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 11.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 12.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 13.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 14.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 15.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 16.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 17.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 18.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 19.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 20.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 21.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 22.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 23.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 24.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 3.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 4.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 5.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 6.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 7.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 8.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - REC - REC - 9.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - Sliding roof electronic module - 42978808.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - Sliding roof electronic module - Sunscreen, roof window.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978747.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978748.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978749.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978750.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978754.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978761.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978763.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978764.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978767.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978771.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978772.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978773.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978776.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978778.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978780.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978787.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978789.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978790.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978791.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978794.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978795.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978796.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978797.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978799.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978803.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978810.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978817.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978818.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978819.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978820.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978821.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978822.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978823.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978825.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - 42978833.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 10.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 11.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 12.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 13.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 14.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 15.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 16.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 17.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 18.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 19.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 20.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 21.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 22.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 23.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 24.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 25.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 26.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 27.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 28.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 29.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 3.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 30.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 31.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 32.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 33.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 34.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 35.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 4.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 5.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 6.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 7.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 8.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Electronic Modules - UEC - UEC - 9.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - GID (Graphic Info Display) - 42978782.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - GID (Graphic Info Display) - 42978833.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - GID (Graphic Info Display) - Info Display.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - GID (Graphic Info Display) - Switch unit - Steering column, right.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Ground Distribution - 42978776.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Ground Distribution - 42978777.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Ground Distribution - Ground distribution - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Ground Distribution - Ground distribution - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Fog Lamp - 42978795.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Fog Lamp - 42978824.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Fog Lamp - Fog lamps, front (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Fog Lamp - Fog lamps, front (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Glove Box Lamp - 42978801.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Glove Box Lamp - 42978822.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Glove Box Lamp - Glove box lamp (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Glove Box Lamp - Glove box lamp (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Headlamps - 42978795.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Headlamps - 42978796.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Headlamps - 42978797.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Headlamps - Front lamps (Adaptive forward lighting) - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Headlamps - Front lamps (Adaptive forward lighting) - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Headlamps - Front lamps (not adaptive forward lighting).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Horn - 42978800.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Horn - 42978821.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Horn - Trumpet horn (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Horn - Trumpet horn (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Horn - Trumpet horn switch (Dalphimetal steering wheel).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Horn - Trumpet horn switch (Takata-Petri steering wheel).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - 42978801.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - 42978802.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - 42978822.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - Cigarette lighter.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - Interior lights (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - Interior lights (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - Interior lights.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - Lamp doors.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - Sunshade lamps (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - Sunshade lamps (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Interior Lamp - Trunk lamp.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Licence Plate Lamp - 42978793.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Licence Plate Lamp - 42978819.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Licence Plate Lamp - Licence plate lamps (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Licence Plate Lamp - Licence plate lamps (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Rear Lamp - 42978794.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Rear Lamp - 42978798.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Rear Lamp - 42978819.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Rear Lamp - 42978820.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Rear Lamp - Lighting rear (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Rear Lamp - Lighting rear (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Rear Lamp - Stop lamp - Middle.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Rear Lamp - Stop lamp switch.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Rear Lamp - Switch - Reversing lamp.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Switch Unit - 42978764.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Switch Unit - 42978794.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Switch Unit - Switch unit - Light.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Switch Unit - Switch unit - Steering column, left.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Trailer Hitch - 42978800.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Trailer Hitch - Trailer hitch.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Turn Signal Lamps - 42978799.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Headlamps, Lamps and Horn - Turn Signal Lamps - Turn signal lamps.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Instruments, Telltales - Cigarette Lighter - 42978802.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Instruments, Telltales - Cigarette Lighter - Cigarette lighter.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Instruments, Telltales - Instruments - 42978810.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Instruments, Telltales - Instruments - 42978811.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Instruments, Telltales - Instruments - 42978827.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Instruments, Telltales - Instruments - Instrument - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Instruments, Telltales - Instruments - Instrument - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Instruments, Telltales - Instruments - Instrument - 3.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - MID (Multi Info Display) - 42978782.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - MID (Multi Info Display) - 42978833.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - MID (Multi Info Display) - Info Display.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - MID (Multi Info Display) - Switch unit - Steering column, right.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Park Pilot - 42978785.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Park Pilot - 42978826.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Park Pilot - Park pilot (2 Connectors).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Park Pilot - Park pilot (3 Connectors).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Switches, Control Unit, Relays, Ignition Lock - 42978770.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Switches, Control Unit, Relays, Ignition Lock - 42978804.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Switches, Control Unit, Relays, Ignition Lock - Switch unit, centre console.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Switches, Control Unit, Relays, Ignition Lock - Switch unit, driver door.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - TID (Triple Info Display) - 42978833.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - TID (Triple Info Display) - Info Display.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Tyre pressure control system - 42978768.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Tyre pressure control system - Tyre pressure control system.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - 42978771.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - 42978772.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - 42978773.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - 42978774.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - 42978775.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - 42978816.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - 42978825.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - Voltage distribution - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - Voltage distribution - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - Voltage distribution - 3.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - Voltage distribution - 4.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - Voltage distribution (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - Voltage distribution (rear electronic module) - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Voltage Distribution - Voltage distribution (rear electronic module) - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Headlamp Wash_Wipe System - 42978803.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Headlamp Wash_Wipe System - Headlamp washer.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Heated Screen - 42978789.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Heated Screen - Heated back window (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Heated Screen - Heated back window (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Rear Screen Wash_Wipe System - 42978803.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Rear Screen Wash_Wipe System - 42978823.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Rear Screen Wash_Wipe System - Back window wiper (not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Rear Screen Wash_Wipe System - Back window wiper (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Rear Screen Wash_Wipe System - Window washer front_rear.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Windscreen Wash_Wipe System - 42978782.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Windscreen Wash_Wipe System - 42978803.cgm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Windscreen Wash_Wipe System - Sensor - Rain.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Windscreen Wash_Wipe System - Switch unit - Steering column, right.htm
Opel EWD - 2013 - Zafira B - EWD - Electrical Equipment and Instruments - Windscreen Wash_Wipe System, Heated Screen - Windscreen Wash_Wipe System - Window washer front_rear.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Cooling System - 42978748.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Cooling System - 42978749.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Cooling System - 42978750.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Cooling System - Engine cooling (A16XNT & not air conditioning).htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Cooling System - Engine cooling (A16XNT).htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Cooling System - Engine cooling (A17DTJ & not air conditioning).htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Cooling System - Engine cooling (A17DTR & not air conditioning).htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Cooling System - Engine cooling (Diesel & air conditioning).htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Cooling System - Engine cooling (EC-A16XER_Z16XER_A18XER & air conditioning).htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Cooling System - Engine cooling (EC-A16XER_Z16XER_A18XER & not air conditioning).htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Engine Electrics - 42978771.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Engine Electrics - Start & Charging.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Denso DEC - 42978747.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Denso DEC - 42978751.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Denso DEC - 42978757.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Denso DEC - 42978758.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Denso DEC - Coolant temperature sensor.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Denso DEC - Engine A17DTJ, DECE1 - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Denso DEC - Engine A17DTJ, DECE1 - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Denso DEC - Engine A17DTR, DECE1 - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Denso DEC - Engine A17DTR, DECE1 - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Denso DEC - Pedal Position Sensor.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Motronic ME 7.6.1_ME 7.6.2_ME 7.6.3_ME 7.6.4_ME 7.9.9 - 42978747.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Motronic ME 7.6.1_ME 7.6.2_ME 7.6.3_ME 7.6.4_ME 7.9.9 - 42978751.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Motronic ME 7.6.1_ME 7.6.2_ME 7.6.3_ME 7.6.4_ME 7.9.9 - 42978759.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Motronic ME 7.6.1_ME 7.6.2_ME 7.6.3_ME 7.6.4_ME 7.9.9 - 42978760.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Motronic ME 7.6.1_ME 7.6.2_ME 7.6.3_ME 7.6.4_ME 7.9.9 - 42978761.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Motronic ME 7.6.1_ME 7.6.2_ME 7.6.3_ME 7.6.4_ME 7.9.9 - Coolant temperature sensor.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Motronic ME 7.6.1_ME 7.6.2_ME 7.6.3_ME 7.6.4_ME 7.9.9 - Engine A16XNT, Motronic 7.6.4 - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Motronic ME 7.6.1_ME 7.6.2_ME 7.6.3_ME 7.6.4_ME 7.9.9 - Engine A16XNT, Motronic 7.6.4 - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Motronic ME 7.6.1_ME 7.6.2_ME 7.6.3_ME 7.6.4_ME 7.9.9 - Engine A16XNT, Motronic 7.6.4 - 3.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Motronic ME 7.6.1_ME 7.6.2_ME 7.6.3_ME 7.6.4_ME 7.9.9 - Pedal Position Sensor.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - 42978746.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - 42978747.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - 42978752.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - 42978753.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - 42978755.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - 42978756.cgm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - Engine A18XER, Simtec 75 - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - Engine A18XER, Simtec 75 - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - Engine Z16XER, Simtec 75.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - Engines A16XER_Z16XER, Simtec 75 - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - Engines A16XER_Z16XER, Simtec 75 - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Engine and Engine Aggregates - Fuel Injection Systems - Simtec 75_78 - Pedal Position Sensor.htm
Opel EWD - 2013 - Zafira B - EWD - Fuel and Exhaust System - Electric Fuel Pump - 42978747.cgm
Opel EWD - 2013 - Zafira B - EWD - Fuel and Exhaust System - Electric Fuel Pump - 42978754.cgm
Opel EWD - 2013 - Zafira B - EWD - Fuel and Exhaust System - Electric Fuel Pump - Fuel pump (A16XNT).htm
Opel EWD - 2013 - Zafira B - EWD - Fuel and Exhaust System - Electric Fuel Pump - Fuel pump (not A16XNT).htm
Opel EWD - 2013 - Zafira B - EWD - Fuel and Exhaust System - Fuel Filter Heating - 42978747.cgm
Opel EWD - 2013 - Zafira B - EWD - Fuel and Exhaust System - Fuel Filter Heating - Filter heating.htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Air Conditioning - 42978787.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Air Conditioning - 42978788.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Air Conditioning - 42978789.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Air Conditioning - 42978817.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Air Conditioning - Air conditioning.htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Air Conditioning - Compressor, air conditioning (Diesel & not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Air Conditioning - Compressor, air conditioning (Petrol & not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Air Conditioning - Compressor, air conditioning (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Air Conditioning - Semi automatic air conditioning - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Air Conditioning - Semi automatic air conditioning - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - ECC Electronic Climate Control - 42978788.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - ECC Electronic Climate Control - 42978789.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - ECC Electronic Climate Control - 42978817.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - ECC Electronic Climate Control - Compressor, air conditioning (Diesel & not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - ECC Electronic Climate Control - Compressor, air conditioning (Petrol & not rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - ECC Electronic Climate Control - Compressor, air conditioning (rear electronic module).htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - ECC Electronic Climate Control - Electronic climate control - 1.htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - ECC Electronic Climate Control - Electronic climate control - 2.htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - ECC Electronic Climate Control - Sensor, air conditioning.htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Heating, Ventilation - 42978786.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Heating, Ventilation - 42978787.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Heating, Ventilation - Add-on heater, electrically operated, passenger compartment.htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Heating, Ventilation - Heating.htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Independent Car Heater - 42978814.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Independent Car Heater - Independent Heater.htm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Seat Heating Systems - 42978809.cgm
Opel EWD - 2013 - Zafira B - EWD - Heating, Ventilation, Air Conditioning (HVAC) - Seat Heating Systems - Seat heating.htm
Opel EWD - 2013 - Zafira B - EWD - Steering - EHPS - Electrical Hydraulic Power Steering - 42978767.cgm
Opel EWD - 2013 - Zafira B - EWD - Steering - EHPS - Electrical Hydraulic Power Steering - Electrical power steering (TRW).htm
Opel EWD - 2013 - Zafira B - EWD - Steering - EHPS - Electrical Hydraulic Power Steering - Electrical power steering (ZF).htm
Opel EWD - 2013 - Zafira B - EWD - Steering - Steering Wheel - Steering Column - 42978781.cgm
Opel EWD - 2013 - Zafira B - EWD - Steering - Steering Wheel - Steering Column - Electromechanical steering column lock (not Open & Start).htm
Opel EWD - 2013 - Zafira B - EWD - Steering - Steering Wheel - Steering Column - Electromechanical steering column lock (Open & Start).htm
Opel EWD - 2013 - Zafira B - EWD - Suspension - Electronic Ride Control - 42978769.cgm
Opel EWD - 2013 - Zafira B - EWD - Suspension - Electronic Ride Control - Semi active damping system.htm
