Opel Insignia 2016 Electrical Wiring Diagrams & Component Locator
Model: 2016 Opel Insignia
Format: PDF, CGM, XPS
Opel EWD - 2016 - Insignia - Control Module U Code List.pdf
Opel EWD - 2016 - Insignia - RPO Code List.pdf
Opel EWD - 2016 - Insignia - Schematics RPO Code List.pdf
Opel EWD - 2016 - Insignia - Service Interval reset 2016 MY.pdf
Opel EWD - 2016 - Insignia - Belts and Chains - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2016 - Insignia - Belts and Chains - Camshaft Timing Chain Inspection.xps
Opel EWD - 2016 - Insignia - Belts and Chains - Camshaft Timing Chain Installation.xps
Opel EWD - 2016 - Insignia - Belts and Chains - Camshaft Timing Chain Removal.xps
Opel EWD - 2016 - Insignia - Belts and Chains - Camshaft Timing Chain Replacement.xps
Opel EWD - 2016 - Insignia - Belts and Chains - Generator and Air Conditioning Compressor Belt Replacement.xps
Opel EWD - 2016 - Insignia - Belts and Chains - Oil Pump Drive Chain and Sprocket Replacement.xps
Opel EWD - 2016 - Insignia - Component Locator - Master Electrical Component List.pdf
Opel EWD - 2016 - Insignia - Component Locator - X84 Data Link Connector.pdf
Opel EWD - 2016 - Insignia - Component Locator - Electrical Center Identification Views - KR20M Cooling Fan Left Medium Speed Relay (LAU, LBS, LFS or LVL).pdf
Opel EWD - 2016 - Insignia - Component Locator - Electrical Center Identification Views - KR20N Cooling Fan Right Medium Speed Relay (LAU, LBS, LFS or LVL).pdf
Opel EWD - 2016 - Insignia - Component Locator - Electrical Center Identification Views - X50A Fuse Block - Underhood X3 (2H0, LAU, LVL or LWC).pdf
Opel EWD - 2016 - Insignia - Component Locator - Ground Views - G121 (LVL).pdf
Opel EWD - 2016 - Insignia - Component Locator - Powertrain Component Views - Front of the Engine Components.pdf
Opel EWD - 2016 - Insignia - Component Locator - Powertrain Component Views - Left Rear of the Engine Components.pdf
Opel EWD - 2016 - Insignia - Component Locator - Powertrain Component Views - Lower Side of the Engine Components.pdf
Opel EWD - 2016 - Insignia - Component Locator - Powertrain Component Views - Rear of the Engine Compnents (LVL) (1 of 2).pdf
Opel EWD - 2016 - Insignia - Component Locator - Powertrain Component Views - Rear of the Engine Compnents (LVL) (2 of 2).pdf
Opel EWD - 2016 - Insignia - Component Locator - Powertrain Component Views - Top of Engine Components (Diesel).pdf
Opel EWD - 2016 - Insignia - EWD - Body Repair - Bolted Exterior Body Panels and Closures - Hood Ajar Switch.cgm
Opel EWD - 2016 - Insignia - EWD - Body Repair - Bumpers and Fascias - Active Grille Air Shutter.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Fixed and Moveable Windows - Defogger Schematics - Rear Window Defogger.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Driver Door - Left Hand Drive (AER).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Driver Door - Right Hand Drive (AER).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Front Doors - Left Hand Drive (without AER).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Front Doors - Right Hand Drive (without AER).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Passenger Door (AER).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics - Rear Doors (AER).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Horns - Horns.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Exterior Lights Schematics - Backup Lights.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Exterior Lights Schematics - Controls.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Exterior Lights Schematics - Front Lamps (T4A).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Exterior Lights Schematics - Front Lamps (T4F).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Exterior Lights Schematics - Rear Position and License Lamps (Hatchback or Sedan).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Exterior Lights Schematics - Rear Position and License Lamps (Wagon).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Exterior Lights Schematics - Stop and Rear Turn Signal Lamps (Hatchback or Sedan).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Exterior Lights Schematics - Stop and Rear Turn Signal Lamps (Wagon).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Fog Lights Schematics - Hatchback or Sedan.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Fog Lights Schematics - Wagon.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Automatic Leveling and Adaptive Forward Lighting - Aiming, Leveling and Beam Control (TR7 and T95).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Automatic Leveling and Adaptive Forward Lighting - Power, Ground, Serial Data and Sensors (TR7 and T95).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Controls.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - High Beam Solenoids (T4A).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - High Intensity Discharge (T4F).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Manual Leveling (TR6).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Park Daytime Running Lamps and Headlamps (T4A).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Accent Lamps (TSP).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Controls.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Door Switches.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Indicator Dimming.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Instrument Panel, Console and Steering Wheel Switches.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Overhead Lamps and Switches.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Interior Lights Schematics - Controls.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Interior Lights Schematics - Courtesy and Cargo Lamps.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Lighting - Interior Lights Schematics - Instrument Panel and Overhead Lamps.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Mirrors - Inside Rearview Mirror Schematics - Inside Rearview Mirror.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Controls and Driver Position (LHD with A45).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Controls and Driver Position (RHD with A45).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Controls and Position (LHD without A45).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Controls and Position (RHD without A45).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Heated and Automatic Day Night Mirrors.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Passenger Position (LHD with A45).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Passenger Position (RHD with A45).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Actuators and Controls (UTT).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Actuators and Controls (without UTT).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Door Ajar Signals.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Liftgate Schematics (Wagon with TB5) - Latch, Motor and Switches.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Liftgate Schematics (Wagon with TB5) - Module Power, Ground, Serial Data and Sensors.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Release Systems Schematics - Fuel Door (UTT).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Release Systems Schematics - Fuel Door (without UTT).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Release Systems Schematics - Manual Liftgate Release (Wagon without TB5).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Release Systems Schematics - Trunk Liftgate Release (Hatchback or Sedan).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Wipers and Washers - Front Wiper.cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Wipers and Washers - Rain Sensor (CE1).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Wipers and Washers - Rear Wiper (Hatchback or Wagon).cgm
Opel EWD - 2016 - Insignia - EWD - Body Systems - Vehicle Access - Wipers and Washers - Washer System.cgm
Opel EWD - 2016 - Insignia - EWD - Brakes - Antilock Brake System - Module Power, Ground and Serial Data.cgm
Opel EWD - 2016 - Insignia - EWD - Brakes - Antilock Brake System - Vehicle Stability.cgm
Opel EWD - 2016 - Insignia - EWD - Brakes - Antilock Brake System - Wheel Speed Signals.cgm
Opel EWD - 2016 - Insignia - EWD - Brakes - Hydraulic Brakes - Hydraulic Brakes (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Brakes - Hydraulic Brakes - Hydraulic Brakes (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Brakes - Park Brake - Electric Park Brake (J71).cgm
Opel EWD - 2016 - Insignia - EWD - Driveline Axle - Rear Drive Axle - All-Wheel Drive (F46).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - OnStar Telematics Schematics - OnStar Telematics (UE1) (1 of 2).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - OnStar Telematics Schematics - OnStar Telematics (UE1) (2 of 2).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO3 or IO7) - Antennas (IO3 or IO7).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO3 or IO7) - Audio Amplifier Power, Ground and Serial Data (IO3 or IO7).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO3 or IO7) - Auxiliary Inputs (IO3 or IO7).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO3 or IO7) - Media Disc Player Power, Ground and Serial Data (IO3 or IO7 with TG5).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO3 or IO7) - Radio and Display, Power, Ground and Serial Data (IO3 or IO7).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO3 or IO7) - Speakers (IO3 or IO7 with U65).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO3 or IO7) - Speakers (IO3 or IO7 with UQA).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO5 or IO6) - Antennas (IO5 or IO6).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO5 or IO6) - Audio Amplifier Power, Ground and Serial Data (IO5 or IO6).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO5 or IO6) - Auxiliary Inputs (IO5 or IO6).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO5 or IO6) - Human Machine Interface and Display, Power, Ground and Serial Data (IO5 or IO6).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO5 or IO6) - Infotainment Control Touchpad (IO5 or IO6 with KOT).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO5 or IO6) - Media Disc Player Power, Ground and Serial Data (IO5 or IO6 with TG5).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO5 or IO6) - Radio, Power, Ground and Serial Data (IO5 or IO6).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO5 or IO6) - Speakers (IO5 or IO6 with U65).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics (IO5 or IO6) - Speakers (IO5 or IO6 with UQA).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Displays and Gauges - Audible Warnings Schematics - Audible Warnings.cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Driver Information.cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Gauges (2H0 or LUJ).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Gauges (LAU).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Gauges (LBS, LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Gauges (LTG or LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Power, Ground, Serial Data and Indicators.cgm
Opel EWD - 2016 - Insignia - EWD - Driver Information and Entertainment - Secondary and Configurable Customer Controls - Steering Wheel Controls (W1Y).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - 12 V Starting and Charging - Charging - Diesel (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - 12 V Starting and Charging - Charging - Gas (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Cruise Control - Brake and Clutch Signals.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Cruise Control - Control Switch and Adaptive Cruise.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - 5V1, 5V2 and Low Reference Bus (LUJ) (1 of 2).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - 5V3, 5V4 and Low Reference Bus (LUJ) (2 of 2).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Controlled Monitored Subsystem References (LUJ).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Engine Data Sensors - Heated Oxygen Sensors (LUJ).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Engine Data Sensors - Pressure and Temperature (LUJ).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Engine Data Sensors - Throttle Controls (LUJ).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Fuel Controls - Evaporative Emission and Turbocharger Controls (LUJ).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Fuel Controls - Fuel Injectors and Pump Controls (LUJ with KL7).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Fuel Controls - Fuel Injectors and Pump Controls (LUJ without KL7).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Fuel Controls - Fuel Select and Control (LUJ with KL7).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Fuel Controls - LPG Injectors (LUJ with KL7).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Ignition Controls - Camshaft Actuators, Ignition Sensors and Ignition System (LUJ).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Controls and Fuel - 1.4L (LUJ) - Power, Ground, Serial Data and MIL (LUJ).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Coolant Level Switch and Coolant Thermostat Heater.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Coolant Pump Clutch (LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Dual Fan Controls (LAU).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Dual Fan Controls (LBS, LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Dual Fan Controls and Motors (LTG).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Dual Fan Motors (LAU).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Dual Fan Motors (LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.4L (LUJ) - Engine Heating and Cooling - Single Fan (2H0, LUJ or LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - 12 V Starting and Charging - Charging - Diesel (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - 12 V Starting and Charging - Charging - Gas (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Cruise Control - Brake and Clutch Signals.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Cruise Control - Control Switch and Adaptive Cruise.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - 5V1, 5V2, 5V3, 5V4 and Low Reference (LVL) (1 of 3).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - 5V2, 5V4 and Low Reference Bus (LVL) (2 of 3).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Controlled Monitored Subsystem References (LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Exhaust Controls (LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Heated Oxygen Sensor and Intake Manifold Runner Control (LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Oil Pressure Solenoid, Piston Cooling, Oil Jet Solenoid, Camshaft and Crankshaft Sensors (LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Pressure and Temperature (LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Engine Data Sensors - Throttle and Turbocharger (LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Fuel Controls - Fuel Pump, Fuel Injectors and Water in Fuel (LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Fuel Controls - Glow Plugs, Pressure Sensors and Fuel Heater (LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Low Reference Bus (LVL) (3 of 3).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Controls and Fuel - 1.6L (LVL) Diesel - Module Power, Ground, Serial Data and MIL (LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Coolant Level Switch and Coolant Thermostat Heater.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Coolant Pump Clutch (LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Dual Fan Controls (LAU).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Dual Fan Controls (LBS, LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Dual Fan Controls and Motors (LTG).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Dual Fan Motors (LAU).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Dual Fan Motors (LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Heating and Cooling - Single Fan (2H0, LUJ or LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LVL) - Engine Mechanical - 1.6L Diesel (LVL) - Engine Oil Level and Pressure Control (LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - 12 V Starting and Charging - Charging - Diesel (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - 12 V Starting and Charging - Charging - Gas (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Cruise Control - Brake and Clutch Signals.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Cruise Control - Control Switch and Adaptive Cruise.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - 5V1, 5V2 and Low Reference Bus (LWC) (1 of 2).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - 5V3, 5V4 and Low Reference Bus (LWC) (2 of 2).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - Controlled Monitored Subsystem References (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - Engine Data Sensors - Heated Oxygen Sensors and Intake Manifold Pressure and Air Temperature Sensor (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - Engine Data Sensors - Pressure and Temperature (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - Engine Data Sensors - Throttle and Brake Sensor Controls (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - Fuel Controls - Emissions, Turbocharger and Oil Pressure Controls (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - Fuel Controls - Fuel Pump and Fuel Pressure Sensor (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - Fuel Controls - Fuel Pump, Fuel Rail Pressure, and Fuel Injectors (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - Ignition Controls - Ignition Sensors (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - Ignition Controls - Ignition System (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Controls and Fuel - 1.6L (LWC) - Power, Ground, Serial Data and MIL (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Coolant Level Switch and Coolant Thermostat Heater.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Coolant Pump Clutch (LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Dual Fan Controls (LAU).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Dual Fan Controls (LBS, LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Dual Fan Controls and Motors (LTG).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Dual Fan Motors (LAU).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Dual Fan Motors (LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Heating and Cooling - Single Fan (2H0, LUJ or LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.6L (LWC) - Engine Mechanical - 1.6L (LWC) - Engine Oil Level Switch (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - 12 V Starting and Charging - Charging - Diesel (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - 12 V Starting and Charging - Charging - Gas (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Cruise Control - Brake and Clutch Signals.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Cruise Control - Control Switch and Adaptive Cruise.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - 5V1, 5V2 and Low Reference Bus (2H0) (1 of 2).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - 5V3, 5V4 and Low Reference Bus (2H0) (2 of 2).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - Controlled Monitored Subsystem References (2H0).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - Engine Data Sensors - Heated Oxygen Sensors (2H0).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - Engine Data Sensors - Pressure and Temperature (2H0).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - Engine Data Sensors - Throttle Controls (2H0).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - Fuel Controls - Evaporative Emission Controls (2H0).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - Fuel Controls - Fuel Pump and Fuel Injectors (2H0).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - Ignition Controls - Ignition Sensors (2H0).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - Ignition Controls - Ignition System (2H0).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Controls and Fuel - 1.8L (2H0) - Power, Ground, Serial Data and MIL (2H0).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Coolant Level Switch and Coolant Thermostat Heater.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Coolant Pump - Auxiliary (LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Coolant Pump Clutch (LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Dual Fan Controls (LAU).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Dual Fan Controls (LBS, LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Dual Fan Controls and Motors (LTG).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Dual Fan Motors (LAU).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Dual Fan Motors (LFS or LVL).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 1.8L (2H0) - Engine Heating and Cooling - Single Fan (2H0, LUJ or LWC).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - 12 V Starting and Charging - Charging - Diesel (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - 12 V Starting and Charging - Charging - Gas (without KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - Cruise Control - Brake and Clutch Signals.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - Cruise Control - Control Switch and Adaptive Cruise.cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBS) Diesel - 5V1, 5V2 and Low Reference Bus (LBS) (1 of 2).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBS) Diesel - 5V2 , 5V3 and Low Reference Bus (LBS) (2 of 2).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBS) Diesel - Controlled Monitored Subsystem References (LBS).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBS) Diesel - Engine Data Sensors - Cylinder Pressure and Glow Plug Controls (LBS).cgm
Opel EWD - 2016 - Insignia - EWD - Engine - 2.0L (LBS) - Engine Controls and Fuel - 2.0L (LBS) Diesel - Engine Data Sensors - EGR and Turbocharger Controls (LBS).cgm
DHT-opel-insignia-2016-electrical-wiring-diagrams-component-locator-20322925012025-2.jpg
DHT-opel-insignia-2016-electrical-wiring-diagrams-component-locator-20322925012025-1.jpg
