Opel Astra J 2015 Electrical Wiring Diagrams & Component Locator
Format: PDF, CGM, XPS
Model: 2015 Opel Astra J
Opel EWD - 2015 - Astra J - Control Module U Code List.pdf
Opel EWD - 2015 - Astra J - RPO Code List.pdf
Opel EWD - 2015 - Astra J - Schematics RPO Code List.pdf
Opel EWD - 2015 - Astra J - Service Interval reset 2015 MY.pdf
Opel EWD - 2015 - Astra J - Belts and Chains - 1,3L (LSF) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1,3L (LSF) - Camshaft Timing Chain and Sprocket Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1,3L (LSF) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1,3L (LSF) - Engine Mechanical Specifications.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1,3L (LSF) - Generator and Air Conditioning Compressor Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.4L (LDD, LUJ) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.4L (LDD, LUJ) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.4L (LDD, LUJ) - Camshaft Timing Chain Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.4L (LDD, LUJ) - Drive Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.4L (LDD, LUJ) - Engine Mechanical Specifications.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LDE), 1.8L (2H0) - Drive Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LDE), 1.8L (2H0) - Engine Mechanical Specifications (1.6L LDE).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LDE), 1.8L (2H0) - Engine Mechanical Specifications (1.8L 2H0).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LDE), 1.8L (2H0) - Power Steering Pump Belt Installation.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LDE), 1.8L (2H0) - Power Steering Pump Belt Removal.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LDE), 1.8L (2H0) - Timing Belt Adjustment (1.6L LDE and 1.8L 2H0).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LDE), 1.8L (2H0) - Timing Belt Inspection (1.6L LDE and 1.8L 2H0).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LDE), 1.8L (2H0) - Timing Belt Replacement (1.6L LDE and 1.8L 2H0).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LDE), 1.8L (2H0) - Valve Clearance Adjustment.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LLU) - Drive Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LLU) - Engine Mechanical Specifications (1.6L LLU).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LLU) - Timing Belt Adjustment (1.6L LLU).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LLU) - Timing Belt Inspection (1.6L LLU).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LLU) - Timing Belt Replacement (1.6L LLU).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LLU) - Valve Clearance Adjustment.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVL, LVM) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVL, LVM) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVL, LVM) - Camshaft Timing Chain Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVL, LVM) - Engine Mechanical Specifications (1.6L Diesel LVL).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVL, LVM) - Engine Mechanical Specifications (1.6L Diesel LVM).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVL, LVM) - Generator and Air Conditioning Compressor Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVL, LVM) - Oil Pump Drive Chain and Sprocket Removal.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVP, LWC) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVP, LWC) - Camshaft Timing Chain Inspection.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVP, LWC) - Camshaft Timing Chain Installation.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVP, LWC) - Camshaft Timing Chain Removal.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVP, LWC) - Drive Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVP, LWC) - Engine Mechanical Specifications (1.6L LVP).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.6L (LVP, LWC) - Engine Mechanical Specifications (1.6L LWC).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.7L (LUD, LUE) - Drive Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.7L (LUD, LUE) - Engine Mechanical Specifications.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.7L (LUD, LUE) - Timing Belt Adjustment.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.7L (LUD, LUE) - Timing Belt Inspection.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.7L (LUD, LUE) - Timing Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 1.7L (LUD, LUE) - Valve Clearance Adjustment.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LBS, LBX) - Drive Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LBS, LBX) - Engine Mechanical Specifications (2.0L Diesel LBS).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LBS, LBX) - Engine Mechanical Specifications (2.0L Diesel LBX).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LBS, LBX) - Timing Belt Replacement (2.0L Diesel LBS and LBX).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LBY) - Drive Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LBY) - Engine Mechanical Specifications (2.0L Diesel LBY).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LBY) - Timing Belt Replacement (2.0L Diesel LBY - New Belt).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LBY) - Timing Belt Replacement (2.0L Diesel LBY - Used Belt).xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LHU) - Camshaft Timing Chain Adjustment.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LHU) - Camshaft Timing Chain, Sprocket, and Tensioner Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LHU) - Drive Belt Replacement.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LHU) - Engine Mechanical Specifications.xps
Opel EWD - 2015 - Astra J - Belts and Chains - 2.0L (LHU) - Water Pump and Balance Shaft Chain Replacement.xps
Opel EWD - 2015 - Astra J - Component Locator - Master Electrical Component List.pdf
Opel EWD - 2015 - Astra J - Component Locator - X84 Data Link Connector.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A11 Radio X1.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A11 Radio X10.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A11 Radio X4 (U4D or UNM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A11 Radio X4.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A11 Radio X5 (UDN).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A11 Radio X7 (NV without KTA).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A11 Radio X7 (UCT, UXW or UXX without KTA).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A11 Radio X7 (without KTA without KTB with NV).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A11 Radio X8.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A12 Digital Radio Receiver Control Module X1 (U4D).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A12 Digital Radio Receiver Control Module X2 (U4D).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A14D Seat Lumbar Support Pump - Driver.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A14P Seat Lumbar Support Pump - Passenger.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A22 Radio Controls (UAG or UFD).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A23D Door Latch Assembly - Driver (LHD).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A23D Door Latch Assembly - Driver (RHD).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A23LR Door Latch Assembly - Left Rear (Without A46).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A23P Door Latch Assembly - Passenger.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A23RR Door Latch Assembly - Right Rear (Without A46).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A25A Glow Plug Pressure Sensor Cylinder 1 Assembly (LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A25B Glow Plug Pressure Sensor Cylinder 2 Assembly (LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A25C Glow Plug Pressure Sensor Cylinder 3 Assembly (LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A25D Glow Plug Pressure Sensor Cylinder 4 Assembly (LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A26 HVAC Controls.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A3L Sunshade - Left (D6I).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A3R Sunshade - Right (D6I).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A7 Fuel Pump and Level Sensor Assembly.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A9A Outside Rearview Mirror - Driver.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - A9B Outside Rearview Mirror - Passenger.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B1 AC Refrigerant Pressure Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B107 Accelerator Pedal Position Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B10B Ambient Light Sunload Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B110 Battery Current Sensor (KL9).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B111 Turbocharger Boost Sensor (LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B111B Turbocharger Boost Intake Air Temperature Sensor (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B111B Turbocharger Boost Intake Air Temperature Sensor (LUJ or LLU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B112 Turbocharger Vane Position Sensor (LBS, LBX, LUE or LUD).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B112 Turbocharger Vane Position Sensor (LSF).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B112 Turbocharger Vane Position Sensor (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B116 Water in Fuel Sensor (Diesel).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B118B Windshield Washer Fluid Level Switch (Y67).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B119 Multi-axis Acceleration Sensor (FX3).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B131 Exhaust Temperature Sensor (LSF).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B131A Exhaust Temperature Sensor 1 (LUD, LUE, LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B131A Exhaust Temperature Sensor 1 (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B131B Exhaust Temperature Sensor 2 (LUD, LUE, LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B131B Exhaust Temperature Sensor 2 (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B136 Exhaust Particulate Matter Sensor (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B154 Diesel Particulate Filter Exhaust Differential Pressure Sensor (LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B154 Diesel Particulate Filter Exhaust Differential Pressure Sensor (LSF).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B154 Diesel Particulate Filter Exhaust Differential Pressure Sensor (LUD or LUE).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B154 Diesel Particulate Filter Exhaust Differential Pressure Sensor (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B159L Glass Breakage Sensor - Left X1 (UTU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B159R Glass Breakage Sensor - Right X1 (UTU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B16 Backup Lamp Switch (2H0).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B16 Backup Lamp Switch (Except 2H0).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B160 Windshield Temperature and Inside Moisture Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B162LF Vertical Body Acceleration Sensor - Left Front (F45).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B162R Vertical Body Acceleration Sensor - Rear (F45).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B162RF Vertical Body Acceleration Sensor - Right Front (F45).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B165 Content Theft Deterrent Sensor Module (UTU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B166LF Advance Parking Assist Side Object Sensor - Left Front (UDP).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B166RF Advance Parking Assist Side Object Sensor - Right Front (UDP).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B17 Barometric Pressure Sensor (LLU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B17 Barometric Pressure Sensor (LUJ).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B18 Battery Current Sensor (without KL9).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B189 LPG Level Sensor (LUJ with KL7).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B190 LPG Pressure and Temperature Sensor (LUJ with KL7).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B19B Brake Booster Vacuum Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B20 Brake Fluid Level Switch.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B209 Neutral Position Sensor (LDD, LDE, LHU, LSF, LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B209 Neutral Position Sensor (LUJ, LUD or LUE).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B209 Neutral Position Sensor (LVL, LVM, LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B211 Rear Multifunction Carrier Position Switch (D9Y).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B22 Brake Pedal Position Sensor (MM1).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B22 Brake Pedal Position Sensor (MM3).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23 Camshaft Position Sensor (LLU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23 Camshaft Position Sensor (LSF, LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23 Camshaft Position Sensor (LUD or LUE).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23 Camshaft Position Sensor (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23E Camshaft Position Sensor - Exhaust (LDD, LUJ, LDE or 2H0).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23E Camshaft Position Sensor - Exhaust (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23E Camshaft Position Sensor - Exhaust (LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23F Camshaft Position Sensor - Intake (LDD or LUJ).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23F Camshaft Position Sensor - Intake (LDE or 2H0).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23F Camshaft Position Sensor - Intake (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B23F Camshaft Position Sensor - Intake (LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B24 Cellular Phone Microphone.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B25B Clutch Pedal Position Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B26 Crankshaft Position Sensor (LDD or LUJ without 5EA).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B26 Crankshaft Position Sensor (LDD with 5EA, LUD or LUE).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B26 Crankshaft Position Sensor (LDE, LLU or 2H0).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B26 Crankshaft Position Sensor (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B26 Crankshaft Position Sensor (LSF, LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B26 Crankshaft Position Sensor (LVL, LVM or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B26 Crankshaft Position Sensor (LVP).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B267 Piston Cooling Oil Pressure Switch (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B34 Engine Coolant Temperature Sensor (LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B34 Engine Coolant Temperature Sensor (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B34 Engine Coolant Temperature Sensor (LSF).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B34 Engine Coolant Temperature Sensor (LUD or LUE).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B34A Engine Coolant Temperature Sensor 1 (LUJ, LDD, LDE, LLU, LVP, LWC or 2H0).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B34A Engine Coolant Temperature Sensor 1 (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B34B Engine Coolant Temperature Sensor 2 (LUJ, LDD, LDE, LLU, LVP, LWC, 2H0, LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B35 Engine Oil Level Switch (LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B35 Engine Oil Level Switch (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B35 Engine Oil Level Switch (LLU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B35 Engine Oil Level Switch (LUD or LUE).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B35 Engine Oil Level Switch (LVL, LVM, LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B37 Engine Oil Pressure Switch (LDE with KL9, 2H0 or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B37 Engine Oil Pressure Switch (LDE without KL9, LBS or LBX).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B37 Engine Oil Pressure Switch (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B37 Engine Oil Pressure Switch (LUD or LUE).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B37 Engine Oil Pressure Switch (LUJ, LDD, LLU or (LSF - KL9)).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B37 Engine Oil Pressure Switch (LUJ, LDD, LLU or (LSF - KL9).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B37B Engine Oil Pressure Sensor (LBS or LBX).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B37B Engine Oil Pressure Sensor (LSF with KL9).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B37B Engine Oil Pressure Sensor (LVL, LVM, LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B39 AC Evaporator Temperature Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B47 Fuel Pressure Sensor (LHU, LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B47B Fuel Rail Pressure Sensor (LSF, LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B47B Fuel Rail Pressure Sensor (LUD or LUE).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B47B Fuel Rail Pressure Sensor (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B51F Suspension Height Sensor - Front (T4F or T95).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B51R Suspension Height Sensor - Rear (T4F or T95).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52 Heated Oxygen Sensor (LSF, LUD, LUE, LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LDD).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LDE, LLU or 2H0).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LUJ with KL7).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LUJ without KL7).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52A Heated Oxygen Sensor 1 (LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52B Heated Oxygen Sensor 2 (LDD, LUJ, LDE, LLU or 2H0).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52B Heated Oxygen Sensor 2 (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52B Heated Oxygen Sensor 2 (LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B52B Heated Oxygen Sensor 2 (LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B55 Hood Ajar Switch.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B59 Front Impact Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B5LF Wheel Speed Sensor - Left Front (without F45).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B5LR Wheel Speed Sensor - Left Rear.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B5RF Wheel Speed Sensor - Right Front (without F45).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B5RR Wheel Speed Sensor - Right Rear.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B60 Passenger Presence Sensor (UH0 or UH1).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B63LF Side Impact Sensor - Left Front.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B63RF Side Impact Sensor - Right Front.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B65 Intake Manifold Pressure and Air Temperature Sensor (LSF, LUD, LUE, LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B65 Intake Manifold Pressure and Air Temperature Sensor (LVL, LVM, LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B66C Inside Air Temperature Sensor - Auxiliary.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B68 Knock Sensor (LDE or 2H0).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B68 Knock Sensor (LLU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B68 Knock Sensor (LUJ or LDD).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B68 Knock Sensor (LVP or LWC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B68A Knock Sensor 1 (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B68B Knock Sensor 2 (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B74 Manifold Absolute Pressure Sensor (LDE or 2H0).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B74 Manifold Absolute Pressure Sensor (LHU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B74 Manifold Absolute Pressure Sensor (LLU).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B74 Manifold Absolute Pressure Sensor (LUJ or LDD).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B75B Mass Air Flow Intake Temperature Sensor (LDD or LUJ without 5EA, LDE without KL9, 2H0, LLU, LSF, LVL, LVM, LUD, LUE, LBS, LBX or LBY).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B75C Multifunction Intake Air Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B78A Front Object Sensor - Left Outer (UD5 or UDP).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B78B Front Object Sensor - Right Outer (UD5 or UDP).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B78C Front Object Sensor - Left Middle (UD5 or UDP).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B78D Front Object Sensor - Right Middle (UD5 or UDP).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B78E Rear Object Sensor - Left Middle (UD5, UD7, UDP or UDQ).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B78F Rear Object Sensor - Right Middle (UD5, UD7, UDP or UDQ).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B78G Rear Object Sensor - Left Outer (UD5, UD7, UDP or UDQ).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B78H Rear Object Sensor - Right Outer (UD5, UD7, UDP or UDQ).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B7D Air Temperature Sensor - Duct Left Lower (CJ2).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B7E Air Temperature Sensor - Duct Right Lower (CJ2).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B7H Air Temperature Sensor - Duct Left Upper (CJ2).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B7J Air Temperature Sensor - Duct Right Upper (CJ2).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B80 Park Brake Switch.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B87 Rear view Camera (UVC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B88D Seat Belt Switch - Driver.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B88LR Seat Belt Switch - Left Rear.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B9 Ambient Air Temperature Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B94LR Side Object Sensor Left Rear (UDQ).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B94RR Side Object Sensor Right Rear (UDQ).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B96 Cylinder Head Temperature Sensor (LUD, LUE, LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - B99 Steering Wheel Angle Sensor.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E11 Fuel Heater (Diesel).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E12A Glow Plug 1 (LUD, LUE, LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E12B Glow Plug 2 (LUD, LUE, LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E12C Glow Plug 3 (LUD, LUE, LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E12D Glow Plug 4 (LUD, LUE, LVL or LVM).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E14A Seat Heating Element - Driver Back.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E14B Seat Heating Element - Driver Cushion.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E14C Seat Heating Element - Passenger Back.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E14D Seat Heating Element - Passenger Cushion.pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E15 Steering Wheel Heater (UVD with N49).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E15 Steering Wheel Heater (UVD without N49).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E18 Rear Defogger Grid (US3).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X1 (35 with UVC).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X1 (without US3).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X2 (Except Notchback).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X2 (Notchback).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X3 (Notchback).pdf
Opel EWD - 2015 - Astra J - Component Locator - Component Connector End Views - E18 Rear Defogger Grid X4 (Notchback).pdf
Opel EWD
