Opel Antara 2016 Electrical Wiring Diagrams & Component Locator
Model: 2016 Opel Antara
Format: PDF, CGM, XPS
Opel EWD - 2016 - Antara - Control Module U Code List.pdf
Opel EWD - 2016 - Antara - RPO Code List.pdf
Opel EWD - 2016 - Antara - Schematics RPO Code List.pdf
Opel EWD - 2016 - Antara - Service Interval reset 2016 MY.pdf
Opel EWD - 2016 - Antara - Belts and Chains - 2.0L (LFS) - Camshaft Intermediate Drive Chain Replacement.xps
Opel EWD - 2016 - Antara - Belts and Chains - 2.0L (LFS) - Engine Mechanical Specifications.xps
Opel EWD - 2016 - Antara - Belts and Chains - 2.0L (LFS) - Generator and Air Conditioning Compressor Belt Replacement.xps
Opel EWD - 2016 - Antara - Belts and Chains - 2.0L (LFS) - Timing Belt Replacement (New Belt).xps
Opel EWD - 2016 - Antara - Belts and Chains - 2.0L (LFS) - Timing Belt Replacement (Used Belt).xps
Opel EWD - 2016 - Antara - Component Locator - Master Electrical Component List.pdf
Opel EWD - 2016 - Antara - Component Locator - X84 Data Link Connector.pdf
Opel EWD - 2016 - Antara - Component Locator - Electrical Center Identification Views (LFS) - X50A Fuse Block - Underhood X1 (LFW, LFS, LNQ, (LE9+LWB)).pdf
Opel EWD - 2016 - Antara - Component Locator - Electrical Center Identification Views (LFS) - X50A Fuse Block - Underhood X4 (LF5 LE9-MAO).pdf
Opel EWD - 2016 - Antara - Component Locator - Electrical Center Identification Views (LFS) - X50A Fuse Block - Underhood X4 (LFS).pdf
Opel EWD - 2016 - Antara - Component Locator - Electrical Center Identification Views (LFS) - X50A Fuse Block - Underhood X4 (LFS LNQ).pdf
Opel EWD - 2016 - Antara - Component Locator - Electrical Center Identification Views (LFS) - X50B Fuse Block - Underhood Auxiliary X1 (LFS).pdf
Opel EWD - 2016 - Antara - Component Locator - Electrical Center Identification Views (LFS) - X50D Fuse Block - Battery X4 (LFS).pdf
Opel EWD - 2016 - Antara - Component Locator - Powertrain Component Views (LFS) - Bottom of the Engine Component (LFS).pdf
Opel EWD - 2016 - Antara - Component Locator - Powertrain Component Views (LFS) - Left Rear Engine Components (LFS).pdf
Opel EWD - 2016 - Antara - Component Locator - Powertrain Component Views (LFS) - Top of the Engine Components (LFS).pdf
Opel EWD - 2016 - Antara - EWD - Body Repair - Bolted Exterior Body Panels and Closures - Hood Ajar Switch.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Fixed and Moveable Windows - Defogger Schematics - Defogger.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics (C140) - Front Doors (AA7).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics (C140) - Front Doors (ABZ).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics (C140) - Rear Doors.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics (C145) - Driver Door (A31).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics (C145) - Front Doors (ABZ).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics (C145) - Passenger Door (A31).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics (C145) - Rear Doors (A31).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Fixed and Moveable Windows - Moveable Window Schematics (C145) - Rear Doors (ABZ).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Horns - Horns.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Exterior Lights Schematics - Backup Lamps.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Exterior Lights Schematics - Front Turn Signal Lamps.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Exterior Lights Schematics - Stop Lamps (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Exterior Lights Schematics - Stop Lamps (Short Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Exterior Lights Schematics - Switch, Park Lamps and License Lamp (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Exterior Lights Schematics - Switch, Park Lamps and License Lamp (Short Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Exterior Lights Schematics - Turn Signal Controls and Rear Turn Signal Lamps (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Exterior Lights Schematics - Turn Signal Controls and Rear Turn Signal Lamps (Short Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Fog Lights Schematics - Front (T96) and Rear (T79) (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Fog Lights Schematics - Front (T96) and Rear (T79) (Short Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Automatic Headlamp Leveling (T4F).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Daytime Running Lights (T3N).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Headlamp Controls.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Headlamps (T4F).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Headlamps (V8A).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Headlamps (without T4F).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Headlights Daytime Running Lights (DRL) Schematics - Manual Headlamp Leveling (TR6).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Dimming Controls, Garage Door Opener, Shift Lever Position Indicator.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Instrument Panel.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Interior Lights Dimming Schematics - Switches.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Interior Lights Schematics - Courtesy Reading and Sunshade Lamps.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Lighting - Interior Lights Schematics - Dome Reading Lamps, Rear Compartment Courtesy Lamp, and Ignition Switch Illumination.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Mirrors - Inside Rearview Mirror Schematics - Inside Rearview Mirror.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Heated Mirrors.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Mirror Position and Power Fold (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Mirror Position and Power Fold (Short Wheel Base with Left Hand Drive).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Mirrors - Outside Rearview Mirror Schematics - Mirror Position and Power Fold (Short Wheel Base with Right Hand Drive).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Door Lock Actuators (AF8).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Door Lock Actuators (HDN with AF8).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Door Lock Actuators (without AF8).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Indicators.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Vehicle Access - Door Lock Indicator Schematics - Switches.cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Vehicle Access - Release Systems Schematics - Liftgate Release (BBL).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Vehicle Access - Release Systems Schematics - Liftgate Release (without BBL).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Vehicle Access - Release Systems Schematics - Liftgate Window Release (Short Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Wipers and Washers - Front Wiper System (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Wipers and Washers - Front Wiper System (Short Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Wipers and Washers - Heated Washers (XA7).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Wipers and Washers - Rear Wiper System (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Body Systems - Wipers and Washers - Rear Wiper System (Short Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Brakes - Antilock Brake System - Power, Ground, Data Communication, and Traction Control.cgm
Opel EWD - 2016 - Antara - EWD - Brakes - Antilock Brake System - Speed Signal, Stability and Hill Descent Controls.cgm
Opel EWD - 2016 - Antara - EWD - Brakes - Antilock Brake System - Wheel Speed Sensors.cgm
Opel EWD - 2016 - Antara - EWD - Brakes - Hydraulic Brake Schematics - Hydraulic Brakes.cgm
Opel EWD - 2016 - Antara - EWD - Brakes - Park Brake - Park Brake.cgm
Opel EWD - 2016 - Antara - EWD - Driveline Axle - Rear Drive Axle - Rear Axle (F46).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Cellular Telephone Schematics - Bluetooth Radio Patch Harness X1 (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Cellular Telephone Schematics - Bluetooth Radio Patch Harness X2 (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Cellular Telephone Schematics - Cellular Telephone (Long Wheel Base with UPF).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Cellular Telephone Schematics - Cellular Telephone (Short Wheel Base with UPF).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Navigation Module (Long Wheel Base with UCS).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Radio Power, Ground, and Inputs (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Radio Power, Ground, and Inputs (Short Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Radio Power, Ground, Data and Controls (IOB).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Speakers (IOB).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Speakers (Long Wheel Base with VXC).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Speakers (Long Wheel Base without VXC).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Radio Navigation System Schematics - Speakers (Short Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Cellular, Entertainment, and Navigation - Video System Schematics - Holden Genuine Accessory.cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Displays and Gauges - Audible Warnings Schematics - Audible Warnings.cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Displays and Gauges - Driver Information System Schematics - Analog Clock (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Displays and Gauges - Driver Information System Schematics - Information Display (Long Wheel Base with C68).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Displays and Gauges - Driver Information System Schematics - Information Display (Short Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Indicators and Air Temperature Sensor.cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Power, Ground, Serial Data, and Gauges 2 of 2.cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Displays and Gauges - Instrument Cluster Schematics - Power, Ground, Serial Data, and Gauges.cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Secondary and Configurable Customer Controls - Steering Wheel Secondary Configurable Control Schematics - Long Wheel Base.cgm
Opel EWD - 2016 - Antara - EWD - Driver Information and Entertainment - Secondary and Configurable Customer Controls - Steering Wheel Secondary Configurable Control Schematics - Short Wheel Base.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Cruise Control - Long Wheel Base.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Cruise Control - Short Wheel Base.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - 5V1, 5V2, and Low Reference Bus (1 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - 5V3, and Low Reference Bus (2 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Controlled Monitored Subsystem References.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Emission Controls - Reductant System.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Exhaust Controls.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Heated Oxygen Sensor, and Intake Manifold Runner Control.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Nitrogen Oxide Sensors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Oil Pressure Solenoid, Camshaft, and Crankshaft Sensor.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Pressure and Temperature Sensors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Reductant Control Module.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Engine Data Sensors - Throttle and Turbocharger.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Fuel Controls - Fuel Pump, Fuel Injectors, and Water in Fuel.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Fuel Controls - Glow Plugs, Pressure Sensors, and Fuel Heater.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Low Reference Bus (3 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Controls and Fuel - 2.0L (LFS) Diesel - Module Power, Ground, Serial Data, and MIL.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Cooling - Coolant Pumps.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Cooling - Cooling Fans (LE9, LFW, LNQ, and LFS).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Cooling - Cooling Fans (LFS).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.0L (LFS) - Engine Mechanical - 2.0L (LFS) Diesel - Engine Oil Level Switch (LFS).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Cruise Control - Long Wheel Base.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Cruise Control - Short Wheel Base.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - 5V1, 5V2, and Low Reference Bus (1 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - 5V3, and Low Reference Bus (2 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Controlled Monitored Subsystem References.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Engine Data Sensors - Brake Pedal Position Sensor and Throttle Controls.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Engine Data Sensors - Camshaft, Crankshaft, Exhaust Gas, and Knock Sensors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Engine Data Sensors - Exhaust Gas, Intake Manifold, and Turbocharger Controls.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Engine Data Sensors - Oxygen Sensor and Water In Fuel Sensors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Engine Data Sensors - Pressure and Temperature Sensors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Fuel Controls - Exhaust Pressure and Temperature, Fuel Economy and Pressure.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Fuel Controls - Fuel Heater.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Fuel Controls - Fuel Pump and Fuel Injectors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Fuel Controls - Glow Plug Controls.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Low Reference Bus (3 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Controls and Fuel - 2.0L (LNP) or 2.2L (LNQ) Diesel - Module Power, Ground, Serial Data, and MIL.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Cooling - Coolant Pumps.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Cooling - Cooling Fans (LE9, LFW, LNQ, and LFS).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Cooling - Cooling Fans (LFS).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.2L (LNQ) - Engine Mechanical - 2.0L (LNP) or 2.2L (LNQ) Diesel - Engine Oil Level Switch (LNP, LNQ).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Cruise Control - Long Wheel Base.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Cruise Control - Short Wheel Base.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - 5V1, 5V2, and Low Reference Bus (1 of 2).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Controlled Monitored Subsystem References.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Engine Data Sensors - Brake Pedal Position Sensor and Throttle Controls.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Engine Data Sensors - Oxygen Sensors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Engine Data Sensors - Pressure and Temperature Sensors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Fuel Controls - Evaporative Emission, Fuel Composition, and Fuel Economy Controls.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Fuel Controls - Fuel Injectors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Fuel Controls - Fuel Pump Controls.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Ignition Controls - Camshaft, Crankshaft, and Knock Sensors, Camshaft Actuators.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Ignition Controls - Ignition System.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Low Reference Bus (2 of 2).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Controls and Fuel - 2.4L (LE9) - Power, Ground, Serial Data, and MIL.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Cooling - Coolant Pumps.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Cooling - Cooling Fans (LE9, LFW, LNQ, and LFS).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Cooling - Cooling Fans (LFS).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 2.4L (LE9) - Engine Mechanical - 2.4L (LE9) - Engine Oil Level Switch (LE9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - 12 V Starting and Charging - Charging (KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - 12 V Starting and Charging - Charging (without KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - 12 V Starting and Charging - Starting.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - 12 V Starting and Charging - Stop Start System (KL9).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Cruise Control - Long Wheel Base.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Cruise Control - Short Wheel Base.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - 5V1, and Low Reference Bus (1 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - 5V2, 5V3, 5V4, and Low Reference Bus (2 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Controlled Monitored Subsystem References.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Engine Data Sensors - Brake Pedal Position Sensor and Throttle Controls.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Engine Data Sensors - Oxygen Sensors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Engine Data Sensors - Pressure and Temperature Sensors.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Fuel Controls - Evaporative Emission and Fuel Economy Controls.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Fuel Controls - Fuel Injectors and Fuel Pressure Sensor.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Fuel Controls - Fuel Pump Controls.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Ignition Controls - Bank 1 Ignition System.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Ignition Controls - Bank 2 Ignition System.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Ignition Controls - Camshaft, Crankshaft, and Knock Sensors, Camshaft Actuators.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Low Reference Bus (3 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Controls and Fuel - 3.0L (LFW) - Power, Ground, Serial Data, and MIL.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Cooling - Coolant Pumps.cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Cooling - Cooling Fans (LE9, LFW, LNQ, and LFS).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Cooling - Cooling Fans (LFS).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Mechanical - 3.0L (LFW) - Engine Oil Level Switch (LFW).cgm
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Mechanical - 3.0L (LFW) - Timing Chain Alignment Diagram - Camshaft Position Actuator Timing Marks.xps
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Mechanical - 3.0L (LFW) - Timing Chain Alignment Diagram - Stage One.xps
Opel EWD - 2016 - Antara - EWD - Engine - 3.0L (LFW) - Engine Mechanical - 3.0L (LFW) - Timing Chain Alignment Diagram - Stage Two.xps
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Automatic - Air Delivery and Temperature Controls.cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Automatic - Auxiliary Heater (LFS).cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Automatic - Auxiliary Heater (LNP or LNQ).cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Automatic - Compressor Controls.cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Automatic - Data Sensors.cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Automatic - Module Power, Ground, and Data Communication.cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Automatic - Rear HVAC (C69).cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Automatic - Secondary Controls (Long Wheel Base).cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Automatic - Temperature Sensors.cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Manual - Auxiliary Heater (LNP or LNQ).cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Manual - Compressor Controls.cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Manual - Mode Controls.cgm
Opel EWD - 2016 - Antara - EWD - HVAC - HVAC - Manual - Module Power, Ground, and Blower Controls.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Body Control System Schematics - Power, Ground, Data Communication, and Subsystem References (1 of 5).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Body Control System Schematics - Subsystem References (2 of 5).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Body Control System Schematics - Subsystem References (3 of 5).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Body Control System Schematics - Subsystem References (4 of 5).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Body Control System Schematics - Subsystem References (5 of 5).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Data Communication Schematics - High Speed CAN, and Chassis Expansion Bus.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Data Communication Schematics - High Speed GMLAN.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Data Communication Schematics - Low Speed GMLAN, Diagnostics Enable, and Data K-Line.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Data Communication Schematics - Medium Speed CAN.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Data Communication Schematics - Powertrain Expansion Bus (LFS).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Data Communications - Data Communication Schematics - Serial Data Communications Enable and Accessory Wake Up.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Power Outlets - Cigar Lighter Power Outlet.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G101 (1 of 2).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G101 (2 of 2), G103, G105, G202, and G204.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G106 and G208.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G107.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G108, G111, and G112.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G111 and G112 (LFS).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G201 (1 of 2).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G201 (2 of 2).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G301 (1 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G301 (2 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G301 (3 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G401 (1 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G401 (2 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G401 (3 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G402 (1 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G402 (2 of 3).cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Ground Distribution Schematics - G402 (3 of 3) and G900.cgm
Opel EWD - 2016 - Antara - EWD - Power and Signal Distribution - Wiring Systems and Power Management - Power Distribution Schematics - B+ Bus (1 of 2).cgm
