NED 2017 (Navistar Engine Diagnostics)
Description: NED (Navistar Engine Diagnostics) is a specialized diagnostic software for MaxxForce engines of Navistar International. As you all know, since February 2017, Navistar no longer supports ServiceMaxx software, but replaced it with NED. In fact, NED is similar to ServiceMaxx, this is a software designed specifically for the engine system, in addition, the company also has many other software such as: DLB, ServiceMaxx, Navkal, Oncommand.
Type of software: Diagnostic Software
Capacity: 192MB
Version: v2.53
OS: Windows 7, 10 32/ 64 bit
Free drive space: 500 MB or above
CPU: Intel Core i3 or above
Ram: 4GB or above
Software Feature:
Basic Features: Read and clear DTC
View and save live data
Check engine in key mode ON, engine does not running (KOEO – Key On Engine Off)
Check the engine in the key mode ON, the engine running (KOER – Key On Engine Running)
Cylinder cutout test
Injector disable test
Fan test
Compression test
High pressure pump test
Aftertreatment System Tests
Features of NED (Navistar Engine Diagnostics) level 3
Advanced Features
Combined with Navkal software to delete aftertreatment system (DPF, or DPF + SCR), EPA7, EPA10 emission standards
Recover data files that have been previously saved or of another vehicle
Change the operating temperature of the cooling fan
Change engine idle speed
Change auto time off when idle
Engine warning and protection
Hydraulic governor pressure change
PTO control
Change the vehicle speed limit
Change from automatic transmission to manual transmission
Increase horse power, torque
Adjust the amount of fuel consumption
Change VIN, engine serial number even if the ECM has password protection
Supported Hardware:
Nexiq USB Link (version1 or 2)
DG Technology DPA5
Norgone DLA
And some other RP1210 devices
Supported models:
North American: MaxxForce 5 (2007 – 2009)
MaxxForce 7 (2007 – 2009)
MaxxForce 7 (2010 – 2012)
MaxxForce 7 (2013 – )
MaxxForce DT, 9 & 10 (2007 – 2009)
MaxxForce DT, 9 & 10 (2010 – 2012)
MaxxForce DT, 9 & 10 (2013)
MaxxForce 11/13 (2008 – 2009)
MaxxForce 11/13 (2010 – 2012)
MaxxForce 11/13 (2013 – 2013.5)
MaxxForce 15 (2010 – 2013)
SCR engines: N9/N10 SCR (2014 – )
N13 SCR (2013 – 2014)
N13 SCR (2015 – )
International A26 (2017 – )
Removed engine: I63BX: 3 Box I6 (1994 – 1997)
V83BX: 3 Box V8 (1994 – 1997)
I308: DLC I6 (1998 – 2004)
T444E: DLC V8 (1998 – 2004)
V126: DLCII V6 (2005 – 2006)
I313: DLCII I6 (2005 – 2006)
V128: DLC V8 (2005 – 2006)
