ohenry
730
80
ho chi minh
If you download this document, you will be lost 6100 Beer
Mercedes-Benz Xentry OpenShell XDOS 03.2023
Description:
XENTRY is the complete diagnosis system that is used to troubleshoot Mercedes-Benz car problems and is the official Mercedes-Benz dealer software. It can configure, reprogram, initialization of new components, program, perform guided tests, read or erase fault codes in any of the systems including Airmatic, SRS, EIS, Transmission, ETS, BAS,... and all of the control modules.
Capacity: 19.8 GB
Data status: 03/2023
Brand: Mercedes-Benz
Region: All region
Language: Multilanguage
==> Diagnostic software Mercedes Xentry OpenShell Diagnostaic (XDOS) works under the operating systems Windows 10 64 bit.
In order to install Xentry OpenShell:
==> The size of the C drive at least 80 GB (the program is installed on drive C without choice directory)
Supported Hardware:
- Mercedes Star Diagnosis C4
- Mercedes Star Diagnosis C5
- Xentry new VCI Star Diagnosis C6
Supported models:
Passenger car:
- A/B: A(117) A(176) A(169) A(168) B(247) B(242, 246) B(245) EQA(243) EQB(243) CLA (118) CLA(117)
- C: C(2060 C(205) C(204) C(203) C(202) 190(201) CLK(209) CLK(208)
- E: EQE(294) EQE(295) CLE(236) E(238) E(214) E(213) E(212) E(211) E(210) E(207) 124(124) CLS(257) CLS(218) CLS(219)
- SUV: GLB(247) GLC(254) GLS(167) GLE(167) GLE(292) M/GLE(166) M(164) M(164) G(464) G(463) G(461) (460) GL/GLS(166) GL(164) EQC(293) GLC(253) GLK(204) GLA(247) (GLA(156) R(251)
- S: EQS(296) EQS(297) S(223) S(222) S(221) S(220) S(217) S(140) S(126) CL(216) CL(215) CL(140)
- Sports car: AMG(298) X290AMG SLK/SLC172 SLK(171) SLK(170) SL(232) SL(231) SL(230) SL(129) SL(107) AMG GT(192) AMG GT(190) SLS(197)
Van: X(470/471) Citan(420) Citan Vaneo(414) V(448) Vito(448) V(447) Vito/Metris(447) Viano(639) Vito(639) V(638) Vito(638) MB100(631) Sprinter910 Sprinter909 Sprinter907 Sprinter900 SprinterIII SprinterII SprinterI T1 Vario T2 SprinterIII up to 2013
Super sport cars: SLR(199)
Special procedures:
- High Voltage Battery
- FBS4 Diagnosis
- Code
- G(463) Landaulet
- OBD Readout
- Configuration 2D
- Charging cable
- Camper
Truck:
eActros(983) Actros(969) Auman965 H6B SFTP965 H6A Atrocs(964) Antos(963) Actros 2,3 Atego(967) Atego II Axor II eEconic(956) Econic(956) Econic Zetros(959) Zetros Actros Atego light Atego heavy Axor SK MK LK ACCELO LN HSK L98 FPN M96 FPN M2000 HPN M96 Atron HPN M2000 SKL FSK MB Indonesia Further model series
Unimogs:
U20 UHE UGE UGN UHN
Busses:
TRAVEGO INTOURO INTEGRO CITARO II CITARO CAPACITY CITO TOURISMO O350/0403 CONECTO O404 O405-O408 Minibus 907 Minibus 902-906 OC500 TOURO TOURINO MBC MULTEGO O500 CBC O500 Art O500 IBC OH Arg OH XBC OF LO INDIA Bus MBO Mexico O400 Further model series Minibus up tp 2013
Special procedures:
- Software request
- Bus Powertrain
- EDB HVBB
- TCM UHN
- Atego Powertrain
- Flash ICC5
Industrial major assemblies:
- Mj as.(800) Mj as.(000) OM 906 CNG KAMAZ GROVE5059 GROVE5110 GROVE5130-3 GROVE5130-1 GROVE4100 GROVE5100 GROVE GMK4060HC TerexAC60 TerexAC100 LTM 1030-2.1 3B/Tier 4i LTM 1040-2.1 3B/Tier 4i LTM 1045-3.1 3B/Tier 4i Component Kit MCG Cab MCG MB Cab SISU KAMAG.
In addition, Xentry OpenShell XDOS also supports diagnosis for other brands including: smart, MAYBACH, BAIC MOTOR, BHARATBENZ, FREIGHTLINER, FUSO, SETRA, cobus, FotonDaimler.
Software Feature:
This is Mercedes-Benz’s specialized software, it fully supports all functions from the most basic functions to programming and coding the vehicle’s electronic control systems.
- Check the data on the vehicle: VIN code, Vehicle model, Engine code, Transmission code…
- Read and clear errors
- Activate the actuators
- Basic settings: Resetting maintenance, setting steering angle, injector code, relearning gears
- Supporting diagnostics of all vehicle systems: body, engine, chassis, transmissions.
- Support the error code repair process.
- Integrated lookup circuit diagrams, and detailed location of parts on the software.
- The systems on the car are supported for diagnosis.
System Support
- Engine: ECM
- Transmission control module: TCM
- Air fork system (Airmatic) and Active Body Control Suspension Systems (Active Body Control Suspension Systems): ABC
- Anti-slip brake system: ESP / ASR / ETS / ABS / BAS / SBC
- Airbag system (AIRBAG): SRS
- All body systems: OCP / UCP / LCP / SCM / DCM / RCM / KFB / SKF
- SAM Unit body box: BCM
- Electronic Ignition system: EIS
- Air conditioning system: A/C
- Parking assist system: Parktronic System
- Keyless go system: DHCU -VL, DHCU-VR
- Network connection system: D2B AND MOST
- Light adjustment system: SG-SW-L; SG-SW-R
- Rvc, RST & Vario Roof modules
- Networking system: D2B AND MOST
- Seat Electronics: SEU
- Automatic Clutch System ACS
- Electric body of M-CLASS models: ( AAM / EAM / DAS / SEM )
Note
This version is not included Zenzefi Certificate so Can't diagnostic some new car need this like: W213FL, W167, W223, W206,...
How to active:
Our channels:
https://www.youtube.com/channel/UC4jMJIFZsycq2qddyxcxIpg/
  • SoMeMe3.2321.txt
