1,375
232
If you download this document, you will be lost 1050 Beer
LEXUS IS350 / IS300 / IS250 / IS220D / IS200D SERVICE & REPAIR INFORMATION MANUAL Update 2015​
Brand: Lexus
Product Code: Lexus
Availability: In Stock
Update : 08.2010 --> 2015
Market : All Regions
Lexus IS350 / IS300 / IS250 / IS220D / IS200D Service information library 08.2010 - up
New car features
Electrical wiring diagram
Body Repair
Service data sheet
ALE20, GSE20, GSE21, GSE22 series
Engines:
2GR-FSE - 3.5L 24-Valve DOHC V6
3GR-FE - 3.0L 24-Valve DOHC V6
4GR-FSE - 2.5L 24-Valve DOHC V6
2AD-FHV - 2.2L 4cylinder 16-Valve DOHC D-4D D-CAT
2AD-FTV - 2.2L 4cylinder 16-Valve DOHC D-4D
REPAIR MANUAL
Engine control system
2AD-FHV - ECD system, Diesel throttle body, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Manifold absolute pressure sensor, EFI relay, EDU relay
2AD-FTV - ECD system, Diesel throttle body, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Manifold absolute pressure sensor, Air fuel ratio sensor, EFI relay, EDU relay
3GR-FE - SFI system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, VVT sensor, Crankshaft position sensor, Engine coolant temperature sensor, Knock sensor, Integration relay, Fuel pump relay
2GR-FSE - SFI system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, VVT sensor, Crankshaft position sensor, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Integration relay, Fuel pump relay
4GR-FSE - SFI system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, VVT sensor, Crankshaft position sensor, Engine coolant temperature sensor, Knock sensor, Integration relay, Fuel pump relay
Engine mechanical
2AD-FHV - Engine, Drive belt, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
2AD-FTV - Engine, Drive belt, Camshaft, Cylinder head gasket, Cylinder head, Cylinder block, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
3GR-FE - Engine, Drive belt, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
2GR-FSE - Engine, Drive belt, Camshaft, Cylinder head gasket, Cylinder head, Cylinder block, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
4GR-FSE - Engine, Drive belt, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
Fuel
2AD-FHV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Injector driver, Fuel pump, Fuel tank, Fuel sender gauge assembly, Fuel tank solenoid return valve
2AD-FTV - Fuel system, Fuel injector, Fuel supply pump, Fuel pressure regulator, Common rail, Fuel filter, Injector driver, Fuel pump, Fuel tank, Fuel sender gauge assembly, Fuel sedimenter warning switch, Fuel tank solenoid return valve
3GR-FE - Fuel system, Fuel injector, Fuel pressure pulsation damper, Fuel pump, Fuel pump resistor, Fuel tank, Fuel sender gauge assembly
2GR-FSE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pressure pulsation damper, Fuel relief valve, Injector driver, Fuel pump, Fuel pump resistor, Fuel tank, Fuel sender gauge assembly
4GR-FSE - Fuel system, Fuel injector, Cold start injector, Fuel pressure pulsation damper, Fuel pressure sensor, Fuel relief valve, Injector driver, Fuel pump, Fuel pump resistor, Fuel tank, Fuel sender gauge assembly
Emission Control
2AD-FHV - Emission control system, EGR valve, EGR cooler, Exhaust gas temperature sensor, Exhaust fuel addition injector, Exhaust manifold converter, Differential pressure sensor, Vacuum regulating valve, Air fuel ratio sensor, Fuel tank cap
2AD-FTV - Emission control system, EGR valve, EGR cooler, Exhaust gas temperature sensor, Exhaust fuel addition injector, Exhaust manifold converter, Differential pressure sensor, Vacuum regulating valve, Fuel tank cap
3GR-FE - Emission control system, Canister, Purge valve, PCV valve, Air fuel ratio sensor, Heated oxygen sensor
2GR-FSE - Emission control system, Canister, Purge valve, PCV valve, Fuel tank cap
4GR-FSE - Emission control system, Canister, Purge valve, PCV valve, Air fuel ratio sensor, Heated oxygen sensor
Intake / Exhaust
2AD-FHV - Intake system, Turbocharger, Intercooler, Exhaust pipe
2AD-FTV - Intake system, Intake manifold, Turbocharger, Intercooler, Exhaust manifold, Exhaust pipe
3GR-FE - Intake system, Exhaust pipe, Exhaust manifold, Exhaust pipe
2GR-FSE - Intake system, Intake manifold, Exhaust manifold, Exhaust pipe
4GR-FSE - Intake system, Exhaust pipe
Cooling
2AD-FHV - Cooling system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan relay, Radiator
2AD-FTV - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan relay, Radiator
3GR-FE - Cooling system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan relay, Radiator
2GR-FSE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan relay, Radiator
4GR-FSE - Cooling system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan relay, Radiator
Lubrication
2AD-FHV - Lubrication system, Oil filter, Oil pump, Engine oil cooler
2AD-FTV - Lubrication system, Oil and oil filter, Oil pressure switch, Oil level sensor, Oil pump, Engine oil cooler
3GR-FE - Lubrication system, Oil filter, Oil pump
2GR-FSE - Lubrication system, Oil and oil filter, Oil pressure switch, Oil level sensor, Oil pump
4GR-FSE - Lubrication system, Oil filter, Oil pump
Ignition
3GR-FE - Ignition system, Ignition coil and spark plug
2GR-FSE - Ignition system, Ignition coil and spark plug
4GR-FSE - Ignition system, Ignition coil and spark plug
Starting
2AD-FHV - Starting system, Pre-heating system, Entry and start system, Glow plug, Starter, Starter relay, Starter cut relay, Glow relay, Engine switch
2AD-FTV - Starting system, Pre-heating system, Entry and start system, Glow plug, Starter, Starter relay, Starter cut relay, Glow relay, Engine switch
3GR-FE - Starting system, Entry and start system, Starter, Starter relay, Starter cut relay, Engine switch
2GR-FSE - Starting system, Entry and start system, Starter, Starter relay, Starter cut relay, Engine switch
4GR-FSE - Starting system, Entry and start system, Starter, Starter relay, Starter cut relay, Engine switch
Charging
2AD-FHV - Charging system, Generator, Battery current sensor, Battery thermometer sensor
2AD-FTV - Charging system, Generator, Battery current sensor, Battery thermometer sensor
3GR-FE - Charging system, Generator
2GR-FSE - Charging system, Generator, Battery current sensor, Battery thermometer sensor
4GR-FSE - Charging system, Generator, Battery current sensor, Battery thermometer sensor
Transmission
A760E Automatic transmission - Automatic transmission system, Extension housing rear oil seal, Speed sensor, Transmission wire, Park / Neutral position switch, Valve body assembly, Shift lock system, Transmission control switch, Shift paddle switch, Pattern select switch, Shift lever assembly, Automatic transmission assembly, Torque converter and drive plate, Transmission unit, Oil pump, Clutch drum and input shaft assembly, Shift solenoid valve
A960E Automatic transmission - Automatic transmission system, Extension housing rear oil seal, Speed sensor, Transmission wire, Park / Neutral position switch, Valve body assembly, Shift lock system, Transmission control switch, Shift paddle switch, Pattern select switch, Shift lever assembly, Automatic transmission assembly, Torque converter and drive plate, Transmission unit, Oil pump, Clutch drum and input shaft assembly, Shift solenoid valve
Clutch - Clutch system, Clutch pedal, Master cylinder, Release cylinder, Clutch accumulator, Clutch unit, Pedal switch
RA63 manual transmission - Manual transmission system, Oil, Transmission unit, Input shaft, Output shaft, Counter gear
Drive Line
Propeller Shaft - Propeller shaft system, Propeller shaft assembly
Drive Shaft - Drive shaft system, Rear drive shaft assembly
Differential - Differential system, Differential oil, Differential side gear shaft oil seal, Differential carrier assembly, Mount cushion
Suspension & Axle
Axle - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle hub
Suspension - Suspension system, Front wheel alignment, Rear wheel alignment, Front shock absorber, Front upper suspension arm, Front lower suspension arm, Front lower ball joint, Front stabilizer bar, Rear shock absorber, Rear upper No1 control arm, Rear upper No2 control arm, Rear No1 suspension arm, Rear No2 suspension arm, Toe control link, Rear stabilizer bar
Tire and Wheel - Tire and wheel system, Tire repair seal
Brake Control - Stop light control relay, Vehicle stability control system, Brake actuator, Front speed sensor, Rear speed sensor, Yaw rate and acceleration sensor, Steering angle sensor, Skid control buzzer, VSC off switch, Brake pedal load sensing switch
Brake - Brake system, Fluid, Brake pedal, Master cylinder, Brake booster, Vacuum pump, Front brake, Front brake flexible hose, Rear brake, Rear brake flexible hose
Parking Brake - Parking brake system, Parking brake lever, Brake pedal, Parking brake cable, Parking brake assembly
Steering Column - Steering system, Power tilt and power telescopic steering column system, Steering lock system, Steering column assembly, Multiplex tilt and telescopic ECU
Power Steering - Power steering system, Steering gear, Power steering ECU
Heater & Air Conditioning system
Air Conditioning - Air conditioning system, Refrigerant, Refrigerant line, Air conditioning unit, Blower unit, Compressor, Condenser, Room temperature sensor, Ambient temperature sensor, Front evoporator temperature sensor, Smog ventilation sensor, Pressure switch, Heater glow plug, Water hose joint, Air conditioning panel, Air conditioning amplifier
Heater - Combustion type power heater system, Heater switch, Heater assembly, Heater exhaust pipe, Heater fuel pump
Restraints
Pre-crash safety system - Pre-crash safety system, Seat belt control ECU
Supplemental Restraint System - Airbag system, Steering pad, Spiral cable, Driver side knee airbag assembly, Front passenger side knee airbag assembly, Front passenger airbag assembly, Curtain shield airbag, Front seat side airbag, Center airbag sensor, Front airbag sensor, Side airbag sensor, Rear airbag sensor, Seat position sensor, Airbag cut-off switch
Seat Belt - Occupant detection sensor, Seat belt tension reducer, Seat belt warning system, Front seat inner belt assembly, Front seat outer belt assembly, Rear seat inner belt, Rear seat outer belt, Togue plate stopper, Child restraint seat tether anchor, Child restraint seat anchor bracket
Securities
Theft Deterrent - Theft deterrent system, Engine hood courtesy switch, Security horn assembly
Engine Immobiliser - Engine immobiliser system
Cruise Control System
Cruise Control - Distance control ECU, Millimeter wave radar sensor, Cruise control, Dynamic radar cruise control system, Cruise control main switch, Clutch switch
Body Electrical
Lighting, Wiper and Washers, Door Lock, Meter, Audio / Visual, Navigation, G-Book, Park Assit / Monitoring, Horn, Clock, Power outler socket
Body
Windshield / Windowglass, Mirror, Instrument Panel, Seat, Engine Hood / Door, Exterior, Interior, Sliding Roof
Communication System
CAN communication system, Multiplex communication system
NEW CAR FEATURES
New model outline, Engines, Chassis, Body, Body electrical, Technical specifications
ELECTRICAL WIRING DIAGRAM
Engine - Charging, Engine control, Cooling fan, Entry and Start system, Ignition
Transmission - ECT and A/T indicator, Shift lock
Brake - ABS, TRS, VSC, Vehicle Dynamics integrated management
Steering - EPS, Power tilt and power telescopic
Heater & Air Conditioner System - Air conditioner, Power heater
Restraints - Seat belt warning, SRS, Electric tension reducer, Pre-crash safety system
Securities - Blocking system, Theft deterrent
Cruise Control System - Cruise control, Dynamic radar cruise control
Body Electrical - Audio system, Automatic light control, Back-up light, Cigarette lighter, Front fog light, Headlight, Interior light, Stop light, Navigation system, G-Book, Wireless door lock control and much much more
Body - Automatic Glare-Resistant EC mirror, Climate control seat, Front window deicer, Mirror heater, Power heater, Power seats, Power windows, Rear sunshade, Rear window defogger, Remote control mirror, Seat heater, Sliding roof
Communication System - Multiplex communication system
BODY REPAIR
OTHER INFORMATION
Lexus-IS350-IS300-IS250-IS220D-IS200D-Service-Repair-Manual-Full-Update-2015-SALES-1.jpg
Lexus-IS350-IS300-IS250-IS220D-IS200D-Service-Repair-Manual-Full-Update-2015-SALES-2.jpg
Lexus-IS350-IS300-IS250-IS220D-IS200D-Service-Repair-Manual-Full-Update-2015-SALES-3.jpg
Lexus-IS350-IS300-IS250-IS220D-IS200D-Service-Repair-Manual-Full-Update-2015-SALES-4.jpg
Lexus-IS350-IS300-IS250-IS220D-IS200D-Service-Repair-Manual-Full-Update-2015-SALES-5.jpg
  • LEXUS IS350 IS300 IS250 IS220D IS200D 2010-2015.txt
