Land Rover RANGE ROVER SPORT L494 4.4 V8 2016 Wiring Diagrams
Type of Document: Wiring Diagrams
Model Year: 2016 EU LHD
Brand: Land Rover
Model: Land-Rover RANGE ROVER SPORT (L494) 4.4 SDV8 4x4 2016 340 Hp 448DT
ANTI-LOCK CONTROL - ABS Circuit [LHD_VIN_555096_124030].pdf
ANTI-THEFT SYSTEM - Anti Theft Alarm Circuit [LHD_VIN_555096_124030].pdf
ANTI-THEFT SYSTEM - Passive Start Circuit [Passive start LHD_VIN_555096_124030].pdf
Automatic Transmission - Transmission Stick Shift Circuit [Vehicles with SCR system installed LHD_VIN_555096_124030].pdf
Automatic Transmission - Transmission Stick Shift Circuit [Vehicles without SCR system installed LHD_VIN_555096_124030].pdf
AUXILIARY CLIMATE CONTROL - Block Heater Circuit [Engine cooling system heater LHD_VIN_555096_124030].pdf
AUXILIARY CLIMATE CONTROL - Heated Front Screen Circuit [Heated windshield LHD_VIN_555096_124030].pdf
AUXILIARY CLIMATE CONTROL - Heated Washer Jets Circuit [Washer jets - heated LHD_VIN_555096_124030].pdf
AUXILIARY CLIMATE CONTROL - Heater Fuel Burning Circuit [Fuel fired booster heater LHD_VIN_555096_124030].pdf
AUXILIARY CLIMATE CONTROL - HTD Rear Screen & Mirrors Circuit [Heated rear window LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Earth Distribution (Schematic) Circuit [Ground distribution LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Hybrid Systems - High Voltage Circuit [Hybrid Electric Vehicle - High voltage connections LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Hybrid Systems - Interlock Loop Circuit [Hybrid Electric Vehicle - High voltage interlock loop LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Hybrid Systems - Low Voltage Circuit [Hybrid Electric Vehicle - Low voltage connections LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution Battery Junction Box Circuit [Battery junction box LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution BCM Circuit [Body Control Modulem Gateway Module Assembly LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution EJB Diesel Circuit [Engine junction box - Diesel LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution EJB Petrol Circuit [Engine junction box - Petrol LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution Hybrid Diesel V6 Circuit [Hybrid Electric Vehicle - Diesel LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution Passenger Compartment Circuit [Passenger junction box LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution RJB Circuit [Rear junction box LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution Twin Battery Cold Start V6D Circuit [Power supply distribution box - DV6 (Cold climate) LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution Twin Battery Cold Start V8D Circuit [Power supply distribution box - DV8 (Cold climate) LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution Twin Battery Psdb Diesel V6 Circuit [Power supply distribution box - DV6 LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution Twin Battery Psdb Petrol Circuit [Power supply distribution box - Petrol LHD_VIN_542165_555095_and_630154_666891].pdf
BATTERY, MOUNTING AND CABLES - Power Distribution VQM Circuit [Voltage quality module LHD_VIN_555096_124030].pdf
BATTERY, MOUNTING AND CABLES - Transit Relay Circuit [Transit relay LHD_VIN_555096_124030].pdf
CLIMATE CONTROL - Hevac Circuit [LHD_VIN_555096_124030].pdf
CLIMATE CONTROL - Hybrid Systems - Hevac Circuit [Hybrid Electric Vehicle LHD_VIN_555096_124030].pdf
Electronic Engine Controls - DV8 - Engine Management TDV8 Circuit [LHD_VIN_555096_124030].pdf
Engine Cooling - Cooling Fans DV6 Circuit [DV6 Gen 2 LHD_VIN_555096_124030].pdf
Engine Cooling - Cooling Fans DV6 Circuit [DV6 LHD_VIN_555096_124030].pdf
Engine Cooling - Cooling Fans DV8 Circuit [DV8 LHD_VIN_555096_124030].pdf
Engine Cooling - Cooling Fans GTDI Circuit [P4 LHD_VIN_555096_124030].pdf
Engine Cooling - Cooling Fans Petrol Circuit [PV8 and PV6 LHD_VIN_555096_124030].pdf
Engine Emission Control - DV8 - Diesel Exhaust Fluid (DEF) Circuit [Selective Catalytic Reduction (SCR) System LHD_VIN_542165_555095_and_630154_666891].pdf
Engine Emission Control - DV8 - Diesel Exhaust Fluid TDV8 Circuit [Selective Catalytic Reduction (SCR) System LHD_VIN_555096_124030].pdf
Exterior Lighting - Adaptive Front Lighting Circuit [Adaptive front lighting system LHD_VIN_555096_124030].pdf
Exterior Lighting - Brake & Reverse Lamps Circuit [Brake and reverse lamps LHD_VIN_555096_124030].pdf
Exterior Lighting - Exterior Lighting 5 Seat Circuit [Head, side, tail and license plate lamps (5-seat vehicles) LHD_VIN_555096_124030].pdf
Exterior Lighting - Exterior Lighting 7 Seat Circuit [Head, side, tail and license plate lamps (7-seat vehicles) LHD_VIN_555096_124030].pdf
Exterior Lighting - Fog Lamps Circuit [Fog lamps LHD_VIN_555096_124030].pdf
Exterior Lighting - Indicators & Hazards Circuit [Turn signal indicators and hazard flashers LHD_VIN_555096_124030].pdf
Exterior Lighting - Trailer Socket 13 Pin Circuit [Trailer socket - Europe LHD_VIN_555096_124030].pdf
Exterior Lighting - Trailer Socket NAS Circuit [Trailer socket - NAS LHD_VIN_555096_124030].pdf
EXTERIOR TRIM AND ORNAMENTATION - Deployable Side Steps Circuit [Deployable Side Step LHD_VIN_555096_124030].pdf
Four Wheel Drive Systems - Driveline Control Transfer Box-DPF Circuit [Vehicles with SCR system installed LHD_VIN_555096_124030].pdf
Four Wheel Drive Systems - Driveline Control Transfer Box-Non DPF Circuit [Vehicles without SCR system installed LHD_VIN_555096_124030].pdf
Fuel Tank and Fuel Lines - Fuel System Diesel V6 Circuit [DV6 Gen 2 LHD_VIN_555096_124030].pdf
Fuel Tank and Fuel Lines - Fuel System Diesel V6 Circuit [DV6 LHD_VIN_555096_124030].pdf
Fuel Tank and Fuel Lines - Fuel System Diesel V8 Circuit [DV8 LHD_VIN_555096_124030].pdf
Fuel Tank and Fuel Lines - Fuel System Petrol Circuit [Petrol LHD_VIN_555096_124030].pdf
Generator and Regulator - Charging AJ126 Circuit [PV6 LHD_VIN_555096_124030].pdf
Generator and Regulator - Charging AJ133 Circuit [PV8 LHD_VIN_555096_124030].pdf
Generator and Regulator - Charging TDV6 Circuit [DV6 LHD_VIN_555096_124030].pdf
Generator and Regulator - Charging TDV8 Circuit [DV8 LHD_VIN_555096_124030].pdf
GLASS, FRAMES AND MECHANISMS - Window Lift Driver Side Circuit [Window lift - Driver side LHD_VIN_555096_124030].pdf
GLASS, FRAMES AND MECHANISMS - Window Lift Passenger Side Circuit [Window lift - Passenger side LHD_VIN_555096_124030].pdf
HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS - Central Door Locking Circuit [Central door locking system LHD_VIN_555096_124030].pdf
HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS - Glovebox Unlocking Circuit [Glovebox release LHD_VIN_555096_124030].pdf
HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS - Module-Door Zone Circuit [Doors, windows, mirrors LHD_VIN_555096_124030].pdf
HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS - Passive Entry Circuit [Passive entry system LHD_VIN_555096_124030].pdf
HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS - Power Tailgate Circuit [Tailgate - Powered LHD_VIN_555096_124030].pdf
HORN - Vehicle Horn Circuit [LHD_VIN_555096_124030].pdf
Information and Entertainment System - Infotainment Audio Controls Circuit [Audio system LHD_VIN_555096_124030].pdf
Information and Entertainment System - Infotainment Dabs Sdars Circuit [SDARS or DAB LHD_VIN_555096_124030].pdf
Information and Entertainment System - Infotainment Phone System Circuit [Cellular phone LHD_VIN_555096_124030].pdf
Information and Entertainment System - Infotainment RSE Circuit [Rear seat entertainment LHD_VIN_555096_124030].pdf
Information and Entertainment System - Infotainment Speakers HI-Line Premium Circuit [13 and 19 Speaker systems LHD_VIN_555096_124030].pdf
Information and Entertainment System - Infotainment Speakers MID-Line Circuit [12-Speaker system LHD_VIN_555096_124030].pdf
Information and Entertainment System - Infotainment Speakers Super Premium Circuit [23-Speaker system LHD_VIN_555096_124030].pdf
Information and Entertainment System - Infotainment TV Circuit [Television - Digital LHD_VIN_555096_124030].pdf
Information and Entertainment System - Infotainment TV-Analogue Circuit [Television - Analogue LHD_VIN_555096_124030].pdf
Information and Entertainment System - Telematics Circuit [Telematics system LHD_VIN_555096_124030].pdf
INFORMATION AND MESSAGE CENTER - Driver Information Circuit [LHD_VIN_555096_124030].pdf
INFORMATION AND MESSAGE CENTER - Head up Display Circuit [Head-Up Display LHD_VIN_555096_124030].pdf
INSTRUMENT CLUSTER AND PANEL ILLUMINATION - IP & Switch Illumination Circuit [LHD_VIN_555096_124030].pdf
INSTRUMENT PANEL AND CONSOLE - Cigar Lighter Power Point Circuit [Accessory socket(s) LHD_VIN_555096_124030].pdf
INSTRUMENT PANEL AND CONSOLE - Cooler Box Circuit [Cool box LHD_VIN_555096_124030].pdf
Interior Lighting - Ambient Lighting Circuit [Configurable ambience lighting LHD_VIN_555096_124030].pdf
Interior Lighting - Ambient Lighting Low Line Circuit [Ambience lighting LHD_VIN_555096_124030].pdf
Interior Lighting - Interior Lighting-Courtesy Circuit [Map and Courtesy LHD_VIN_555096_124030].pdf
Interior Lighting-Illuminated Entry Circuit [Entry illumination LHD_VIN_555096_124030].pdf
MODULE COMMUNICATIONS NETWORK - Architecture Overview HS Can Chassis Circuit [CAN bus - High speed - Chassis systems LHD_VIN_555096_124030].pdf
MODULE COMMUNICATIONS NETWORK - Architecture Overview HS Can Power Train Circuit [CAN bus - High speed - Powertrain systems LHD_VIN_555096_124030].pdf
MODULE COMMUNICATIONS NETWORK - Architecture Overview LIN Bus Circuit [LIN bus LHD_VIN_555096_124030].pdf
MODULE COMMUNICATIONS NETWORK - Architecture Overview Lvds Circuit [Low-voltage differential signaling (LVDS) LHD_VIN_555096_124030].pdf
MODULE COMMUNICATIONS NETWORK - Architecture Overview Most (Low Line) Circuit [MOST - Conventional display instrument cluster LHD_VIN_555096_124030].pdf
MODULE COMMUNICATIONS NETWORK - Architecture Overview Most Circuit [MOST - Virtual display instrument cluster LHD_VIN_555096_124030].pdf
MODULE COMMUNICATIONS NETWORK - Architecture Overview MS Can Body Circuit [CAN bus - Medium speed - Body systems LHD_VIN_555096_124030].pdf
MODULE COMMUNICATIONS NETWORK - Architecture Overview MS Can Comfort Circuit [CAN bus - Medium speed - Comfort systems LHD_VIN_555096_124030].pdf
MODULE COMMUNICATIONS NETWORK - Diagnostic Socket Circuit [Diagnostic connector LHD_VIN_555096_124030].pdf
MODULE COMMUNICATIONS NETWORK - Hybrid Systems - Hybrid Can Circuit [CAN bus - High speed - Hybrid Electric Vehicle (HEV) LHD_VIN_555096_124030].pdf
NAVIGATION SYSTEM - Navigation Japan Circuit [Japan LHD_VIN_555096_124030].pdf
NAVIGATION SYSTEM - Navigation System Circuit [Asia LHD_VIN_555096_124030].pdf
PARKING AID - Camera-Rear View Circuit [Rear view camera LHD_VIN_555096_124030].pdf
PARKING AID - Cameras-5 Seat Circuit [Proximity camera system (5-Seat vehicles) LHD_VIN_555096_124030].pdf
PARKING AID - Cameras-7 Seat Circuit [Proximity camera system (7-Seat vehicles) LHD_VIN_555096_124030].pdf
PARKING AID - Park Assistance Module 7 Seat No SWC Circuit [7-Seat vehicles without spare wheel carrier LHD_VIN_555096_124030].pdf
PARKING AID - Park Assistance Module Circuit [LHD_VIN_555096_124030].pdf
PARKING BRAKE AND ACTUATION - Electric Park Brake Circuit [LHD_VIN_555096_124030].pdf
POWER STEERING - EPAS Circuit [LHD_VIN_555096_124030].pdf
REAR DRIVE AXLE AND DIFFERENTIAL - Driveline Control Tvbb Circuit [LHD_VIN_555096_124030].pdf
REAR VIEW MIRRORS - Blindspot Monitoring Circuit [Blind spot monitoring system LHD_VIN_555096_124030].pdf
REAR VIEW MIRRORS - Mirrors Electrochromic Circuit [Electrochromic LHD_VIN_555096_124030].pdf
REAR VIEW MIRRORS - Mirrors Memory Circuit [Door LHD_VIN_555096_124030].pdf
RIDE AND HANDLING OPTIMIZATION - Active Roll Control Circuit [Dynamic Response LHD_VIN_555096_124030].pdf
RIDE AND HANDLING OPTIMIZATION - ATCM Circuit [Terrain Response LHD_VIN_555096_124030].pdf
RIDE AND HANDLING OPTIMIZATION - Wade Aid Module Circuit [Wade sensing system LHD_VIN_555096_124030].pdf
ROOF OPENING PANEL - Sunroof & Sunblind Circuit [Roof opening panel and sun blind LHD_VIN_555096_124030].pdf
SEATBELT SYSTEM - Active Seat Belt Circuit [Retractors LHD_VIN_555096_124030].pdf
SEATBELT SYSTEM - Seat Belt Pretensioner Circuit [Pretensioners LHD_VIN_555096_124030].pdf
SEATING - Driver Base Seat Circuit [Driver - 2 way LHD_VIN_555096_124030].pdf
SEATING - Driver Massage Seat Circuit [Driver - Massage LHD_VIN_555096_124030].pdf
SEATING - Passenger Massage Seat Circuit [Passenger - Massag LHD_VIN_555096_124030].pdf
SEATING - Seat Heat Front Circuit [Front - Heated LHD_VIN_555096_124030].pdf
SEATING - Seat Heat Rear Circuit [Rear - Heated LHD_VIN_555096_124030].pdf
SEATING - Seat Passenger Non Memory Circuit [Passenger - Non-memory LHD_VIN_555096_124030].pdf
SEATING - Seats Climatic Front Circuit [Front - Climate controlled LHD_VIN_555096_124030].pdf
SEATING - Seats Climatic Rear 60 40 Circuit [Rear - Climate controlled LHD_VIN_555096_124030].pdf
SEATING - Seats Memory Base Driver Circuit [Driver - Memory - 8 to 12 way adjustment LHD_VIN_555096_124030].pdf
SEATING - Seats Memory Base Passenger Circuit [Passenger - Memory - 8 to 12 way adjustment LHD_VIN_555096_124030].pdf
SEATING - Seats Memory Driver Circuit [Driver - Memory - All adjustments LHD_VIN_542165_555095_and_630154_666891].pdf
SEATING - Seats Memory Driver-HI Line Circuit [Driver - Memory - All adjustments LHD_VIN_555096_124030].pdf
SEATING - Seats Memory MID Driver Circuit [Driver - Memory - 12 to 18 way adjustment LHD_VIN_555096_124030].pdf
SEATING - Seats Memory MID Passenger Circuit [Passenger - Memory - 12 to 18 way adjustment LHD_VIN_555096_124030].pdf
SEATING - Seats Memory Passenger Circuit [Passenger - Memory - All adjustments LHD_VIN_542165_555095_and_630154_666891].pdf
SEATING - Seats Memory Passenger-HI Line Circuit [Passenger - Memory - All adjustments LHD_VIN_555096_124030].pdf
SEATING - Seats Movement Driver Circuit [Driver - Non-memory LHD_VIN_555096_124030].pdf
SPEED CONTROL - Adaptive Cruise Control Circuit [LHD_VIN_555096_124030].pdf
Starting System - Starting AJ126 Circuit [PV6 LHD_VIN_555096_124030].pdf
Starting System - Starting AJ133 Circuit [PV8 LHD_VIN_555096_124030].pdf
Starting System - Starting TDV6 Circuit [DV6 Gen 2 LHD_VIN_555096_124030].pdf
Starting System - Starting TDV6 Circuit [DV6 LHD_VIN_555096_124030].pdf
Starting System - Starting TDV6 TSS Circuit [DV6 (Stop-Start) LHD_VIN_542165_555095_and_630154_666891].pdf
Starting System - Starting TDV8 Circuit [DV8 LHD_VIN_555096_124030].pdf
STEERING COLUMN - Heated Steering Wheel Circuit [Steering wheel - heated LHD_VIN_555096_124030].pdf
STEERING COLUMN - Power MEM Steering Column Circuit [Steering column adjustment LHD_VIN_555096_124030].pdf
STEERING COLUMN - Rotary Coupler Circuit [Clock spring LHD_VIN_555096_124030].pdf
STEERING COLUMN - Steering Column Lock Circuit [Lock LHD_VIN_555096_124030].pdf
SUPPLEMENTAL RESTRAINT SYSTEM - Occupancy Classification Sensor Circuit [Occupant sensing LHD_VIN_555096_124030].pdf
SUPPLEMENTAL RESTRAINT SYSTEM - SRS Circuit [LHD_VIN_555096_124030].pdf
TOWBAR - Deployable Towbar System Circuit [Deployable towbar system LHD_VIN_555096_124030].pdf
VEHICLE DYNAMIC SUSPENSION - Chassis Control System Circuit [LHD_VIN_555096_124030].pdf
WHEELS AND TIRES - Tyre Pressure Monitoring Circuit [Tire pressure monitoring system LHD_VIN_555096_124030].pdf
WIPERS AND WASHERS - Washers & Wipers Circuit [LHD_VIN_555096_124030].pdf
