- If you download this document, you will be lost 4500 Beer
Land Rover Discovery 5 2017-2021 L462 Service Repair Manual and Diagram
Brand: Land Rover
Type of Manual: Service Repair Manual, Wiring Diagram
Publication Date: 2017 2018 2019 2020 2021
Model: Land Rover Discovery 5 2017-2021
Number of Pages: 15860 Pages
Workshop Manual
Body and Paint
Chassis
Electrical
General Information
Powertrain 3.0L Diesel
Powertrain 3.0L SC V6 Petrol
Powertrain INGENIUM I4 2.0L Diesel
Accessory Fitting
Active Diesel Misfueling
Activity Key
Closing the Hood
Connecting Jump Leads
Connecting Starting Aid
Electric Parking Brake
Engine Compartment Fuse Box
Engine Start Backup
First Responder - Discovery 5 Seater
First Responder - Discovery 7 Seater
Fluid Filler Locations
Fuel Filler Flap
Fuel Filler
Fuse Box Locations
Introduction
Load Space Fuse Box
OBD Location
Opening the Hood
Passenger Compartment Fuse Box
Removing the Spare Wheel
Running out of Fuel
Tool Kit
Transmission Park Release
Transporting the Vechile
Unlocking the Vechile
Vechile Recovery Guide
Vechile Recovery
Wheel Changing
Wiring
204-04 WHEELS AND TIRES Tire pressure monitoring system
204-05 VEHICLE DYNAMIC SUSPENSION
204-06 RIDE AND HANDLING OPTIMIZATION Terrain Response
204-06 RIDE AND HANDLING OPTIMIZATION Wade sensing system
205-02 REAR DRIVE AXLE AND DIFFERENTIAL
206-09 ANTI-LOCK CONTROL
211-02 POWER STEERING
211-04 STEERING COLUMN Clock spring
211-04 STEERING COLUMN Lock
211-04 STEERING COLUMN Steering column adjustment
211-04 STEERING COLUMN Steering wheel - heated
303-03 ENGINE COOLING DI4
303-03 ENGINE COOLING DV6
303-03 ENGINE COOLING PV6
303-06A STARTING SYSTEM - DV6
303-06B STARTING SYSTEM - DI4
303-06C STARTING SYSTEM - PV6
303-08A ENGINE EMISSION CONTROL - DV6
303-08C ENGINE EMISSION CONTROL - DI4
303-14A ELECTRONIC ENGINE CONTROLS - DV6
303-14C ELECTRONIC ENGINE CONTROLS - PV6
303-14E ELECTRONIC ENGINE CONTROLS - DI4
307-01 AUTOMATIC TRANSMISSION
308-07 FOUR WHEEL DRIVE SYSTEMS Transfer case - Diesel
308-07 FOUR WHEEL DRIVE SYSTEMS Transfer case - Petrol
310-01 FUEL TANK AND FUEL LINES DV6
310-01 FUEL TANK AND FUEL LINES PV6 and DI4
310-03 SPEED CONTROL
412-01 CLIMATE CONTROL Vehicles with hidden instrument panel stowage
412-01 CLIMATE CONTROL Vehicles without hidden instrument panel stowage
412-02 AUXILIARY CLIMATE CONTROL Engine cooling system heater
412-02 AUXILIARY CLIMATE CONTROL Fuel fired booster heater
412-02 AUXILIARY CLIMATE CONTROL Heated rear window
412-02 AUXILIARY CLIMATE CONTROL Heated windshield
412-02 AUXILIARY CLIMATE CONTROL Washer jets - heated
413-00 INSTRUMENT CLUSTER AND PANEL ILLUMINATION
413-06 HORN
413-08 INFORMATION AND MESSAGE CENTER Head-Up Display
413-09 WARNING DEVICES
413-13 PARKING AID Proximity camera system
413-13 PARKING AID Rear view camera (InControl Touch Pro systems)
413-13 PARKING AID Rear view camera (InControl Touch systems)
413-13 PARKING AID
414-01 BATTERY, MOUNTING AND CABLES Battery junction box
414-01 BATTERY, MOUNTING AND CABLES Body Control Module Gateway Module Assembly
414-01 BATTERY, MOUNTING AND CABLES Engine junction box - Diesel
414-01 BATTERY, MOUNTING AND CABLES Engine junction box - Petrol
414-01 BATTERY, MOUNTING AND CABLES Ground distribution
414-01 BATTERY, MOUNTING AND CABLES Passenger junction box
414-01 BATTERY, MOUNTING AND CABLES Rear junction box
414-01 BATTERY, MOUNTING AND CABLES Voltage quality module
414-02 GENERATOR AND REGULATOR DI4
414-02 GENERATOR AND REGULATOR DV6
414-02 GENERATOR AND REGULATOR PV6
415-00 INFORMATION AND ENTERTAINMENT SYSTEM InControl Touch - 6 and 10-Speaker system
415-00 INFORMATION AND ENTERTAINMENT SYSTEM InControl Touch Pro - 10 and 14-Speaker system
415-00 INFORMATION AND ENTERTAINMENT SYSTEM Telematics system
417-01 EXTERIOR LIGHTING Adaptive front lighting system
417-01 EXTERIOR LIGHTING Brake and reverse lamps
417-01 EXTERIOR LIGHTING Fog lamps
417-01 EXTERIOR LIGHTING Halogen
417-01 EXTERIOR LIGHTING LED
417-01 EXTERIOR LIGHTING Trailer socket - Europe
417-01 EXTERIOR LIGHTING Trailer socket - NAS
417-01 EXTERIOR LIGHTING Turn signal indicators and hazard flashers
417-02 INTERIOR LIGHTING Ambience lighting
417-02 INTERIOR LIGHTING Configurable ambience lighting
417-02 INTERIOR LIGHTING Entry illumination
417-02 INTERIOR LIGHTING Map and Courtesy
418-00 MODULE COMMUNICATIONS NETWORK CAN bus - High speed - Body systems
418-00 MODULE COMMUNICATIONS NETWORK CAN bus - High speed - Chassis systems
418-00 MODULE COMMUNICATIONS NETWORK CAN bus - High speed - HMI systems
418-00 MODULE COMMUNICATIONS NETWORK CAN bus - High speed - Power mode zero systems
418-00 MODULE COMMUNICATIONS NETWORK CAN bus - High speed - Powertrain systems
418-00 MODULE COMMUNICATIONS NETWORK Diagnostic connector
418-00 MODULE COMMUNICATIONS NETWORK FlexRay
418-00 MODULE COMMUNICATIONS NETWORK LIN bus
419-01 ANTI-THEFT SYSTEM Passive start
501-09 REAR VIEW MIRRORS Blind spot monitoring system
501-09 REAR VIEW MIRRORS Electrochromic
501-09 REAR VIEW MIRRORS Mirror movement
501-10 SEATING Driver - Massage
501-10 SEATING Driver - Memory - 8 to 16 way adjustment
501-10 SEATING Driver - Memory - 10 way
501-10 SEATING Driver - Memory - including rear adjustments
501-10 SEATING Driver - Non-memory
501-10 SEATING Front - Climate controlled
501-10 SEATING Front - Heated
501-10 SEATING Passenger - Massage
501-10 SEATING Passenger - Memory - 8 to 10 way adjustment
501-10 SEATING Passenger - Memory - 10 Way
501-10 SEATING Passenger - Memory - including rear adjustments
501-10 SEATING Passenger - Non-memory
501-10 SEATING Rear - Climate controlled
501-10 SEATING Rear - Heated (5-Seat vehicles)
501-10 SEATING Rear - Heated (7-Seat vehicles)
501-11 GLASS, FRAMES AND MECHANISMS Window lift - Driver side
501-11 GLASS, FRAMES AND MECHANISMS Window lift - Passenger side
501-12 INSTRUMENT PANEL AND CONSOLE Accessory socket(s)
501-12 INSTRUMENT PANEL AND CONSOLE Cool box
501-14 HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS Central door locking system
501-14 HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS Doors, windows, mirrors
501-14 HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS Glove compartment release
501-14 HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS Passive entry system
501-14 HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS Tailgate - Powered
501-16 WIPERS AND WASHERS
501-17 ROOF OPENING PANEL
501-20A SEATBELT SYSTEM
501-20B SUPPLEMENTAL RESTRAINT SYSTEM Occupant sensing
502-03 TOWBAR
DISCOVERY Fuse and Relay Locations (1a)
DISCOVERY Fuse and Relay Locations (1a)1
DISCOVERY Fuse and Relay Locations (1a)2
Introduction DISCOVERY iEWD (LHD) (4a)
Maintenance
Body & Paint
Inspection Information
MAINTENANCE CHECKSHEET
New Vehicle Storage Form - Vehicle Transportation Aids And Vehicle Storage
PDI Checksheet
PDI Manual
Repair Times Support Information
Other Information
California Emission Control
Contents
Customer Assistance
Discovery Sport
Discovery
Federal Emission Control
Foreword
Guidelines Applicable to warranties
Land Rover Roadside Assistance
Maintenance Service Recommendation
Obtaining warranty repairs
Owners and vehicle Identification
PASSPORT TO SERVICE
Range Rover Evoque
Range Rover Sport
Range Rover
Summary of Warranties
Using the Passport to Service
Vechile Warranties
Connector
1BEFORE USING THIS PUBLICATION
2FIBRE OPTICS
3HARNESS REPAIRS
4TABLE OF CIRCUIT OPTION CODES
C1A101 Valve-Control-Fuel volume
C1A102 Valve-Control-Fuel pressure
C1BB01AA Junction box-engine
C1BB01B Junction box-engine
C1BB01C Junction box-engine
C1BB01D Junction box-engine
C1BB01E Junction box-engine
C1BB01F Junction box-engine
C1BB01G Junction box-engine
C1BB01H Junction box-engine
C1BB01J Junction box-engine
C1BB01K Junction box-engine
C1BB01L Junction box-engine
C1BB01M Junction box-engine
C1BB01N Junction box-engine
C1BB01P Junction box-engine
C1BB01R Junction box-engine
C1BF01A Junction box-Auxiliary
C1BF01C Junction box-Auxiliary
C1BF01EB Junction box-Auxiliary
C1BF01F Junction box-Auxiliary
C1BF01G Junction box-Auxiliary
C1BF01H Junction box-Auxiliary
C1BF01J Junction box-Auxiliary
C1BF01K Junction box-Auxiliary
C1CA01A Module-ABS control
C1CA03 Sensor-Wheel speed-Front-Left
C1CA05 Sensor-Wheel speed-Front-Right
C1CA38A Sensor-Brake vacuum
C1CD07 Accelerometer-Front left
C1CD08 Accelerometer-Front right
C1CD10 Sensor-Height-Front-Left
C1CD11 Sensor-Height-Front-Right
C1CL02B Valve block-Front
C1CS05A Module-Control-Power Steering
C1CS05B Module-Control-Power Steering
C1CS05C Module-Control-Power Steering
C1CS14 Sensor-Torque
C1DC12B Stud-cable junction
C1DC12C Stud-cable junction
C1DC12E Stud-cable junction
C1DC12G Stud-cable junction
C1DC13A Stud-through panel
C1DC14E Generator
C1DC16 Generator
C1DC16A Generator
C1DC16C Generator
C1DC16J Generator
C1DC35AA Starter motor
C1DC35AAJB Starter motor
C1DC35AJB Starter motor
C1DC35C Starter motor
C1DC35CA Starter motor
C1DC35J Starter motor
C1DC73A Starter motor
C1DC73D Starter motor
C1DC73E Starter motor
C1DC74A Generator
C1DC81 Jump Start-Terminal
C1E107A Module-Powertrain control-DI4
C1E107B Module-Powertrain control-DI4
C1E114A Solenoid-Charge air
C1E115A Module-Powertrain control-DV6
C1E116B Module-Powertrain control-DV6
C1E120B Module-Powertrain control-PV6
C1E121A Module-Powertrain control-PV6
C1E135 Valve-Purge
C1E137E Throttle-Electric
C1E166A Solenoid-Valve-High pressure EGR
C1E167A Actuator-Valve-Exhaust pressure control
C1E167AA Solenoid valve-EGR-Low pressure
C1E167B Actuator-Valve-Exhaust pressure control
C1E168AA Throttle-Electric
C1E170A Module-DEF tank
C1E170B Module-DEF tank
C1E173A Heater-DEF pressure line
C1E173AM Heater-DEF pressure line
C1E173B Heater-DEF pressure line
C1E173BM Heater-DEF pressure line
C1E174A Injector-DEF
C1E174B Injector-DEF
C1E176 Module-DEF heating control
C1E177 Sensor-Soot-SCR-Downstream
C1E178 Sensor-NOx-SCR-Upstream
C1E178A Sensor-NOx-SCR-Upstream
C1E179 Sensor-NOx-SCR-Downstream
C1E179A Sensor-NOx-SCR-Downstream
C1E205A Fuel injector-No.1
C1E205AA Fuel injector-No.1
C1E205E Fuel injector-No.1
C1E206A Fuel injector-No.2
C1E206AA Fuel injector-No.2
C1E206E Fuel injector-No.2
C1E207A Fuel injector-No.3
C1E207AA Fuel injector-No.3
C1E207E Fuel injector-No.3
C1E243 Glow plug
C1E244 Glow plug
C1E245 Glow plug
C1E246 Glow plug
C1E247 Glow plug
C1E248 Glow plug
C1E256AA Valve-Control-Fuel volume
C1E259AA Valve-Control-Fuel pressure
C1E303E Ignition coil-1
C1E304E Ignition coil-2
C1E305E Ignition coil-3
C1E306E Ignition coil-4
C1E308E Ignition coil-5
C1E309E Ignition coil-6
C1E316C Valve-Manifold tuning
C1E318 Pump-Supercharge-coolant
C1E318A Solenoid-Variable coolant pump
C1E357E Capacitor
C1E358A Solenoid-Oil jet-Piston cooling
C1E359 Solenoid-Oil pump
C1E359A Solenoid-Oil pump
C1E359AM Solenoid-Oil pump
C1E359B Solenoid-Oil pump
C1E364A Sensor-Coolant pump position
C1E364AM Sensor-Coolant pump position
C1E435A Solenoid-Valve Turbine shut-off
C1E437A Sensor-Valve position-Turbine intake
C1E437B Sensor-Valve position-Turbine intake
C1E444A Solenoid-VVT-Bank 1-Intake
C1E445A Solenoid-VVT-Bank 2-Intake
C1E446A Solenoid-VVT-Bank 1-Exhaust
C1E446AA Solenoid-VVT-Bank 1-Exhaust
C1E447A Solenoid-VVT-Bank 2-Exhaust
C1E457AA Solenoid-EGR cooler bypass valve
C1E460AA Actuator-Wastegate
C1E476A Solenoid-Compressor bypass-Turbocharger
C1E477A Actuator-Varible swirl-Intake manifold
C1E565A Actuator-Bypass valve
C1E701 Sensor-Position-Accelerator pedal
C1E706E Sensor-Camshaft position-Bank 1-Intake
C1E707E Sensor-Camshaft position-Bank 2-Intake
C1E709A Sensor-Temperature-Post-catalytic converter
C1E710A Sensor-Temperature-Pre-catalytic converter
C1E713AA Sensor-Differential pressure-Low pressure EGR
C1E717A Sensor-Oil temperature-and level
C1E717E Sensor-Oil level and temperature
C1E719 Sensor-Temperature-Low pressure EGR cooler outlet
C1E731A Sensor-Heated oxygen-Pre catalyst-Left
C1E731AM Sensor-Heated oxygen-Pre catalyst-Left
C1E731C Sensor-Heated oxygen-Post catalyst-Right
C1E731CA Sensor-Heated oxygen-Post catalyst-Right
C1E733C Sensor-Heated oxygen-Post catalyst-Left
C1E733CA Sensor-Heated oxygen-Post catalyst-Left
C1E735A Sensor-Heated oxygen-Pre catalyst-Right
C1E735AM Sensor-Heated oxygen-Pre catalyst-Right
C1E736A Sensor-Camshaft position-Bank 1-Outlet
C1E736AA Sensor-Camshaft position (CMP)
C1E755 Sensor-Temperature-Charge air
C1E759AA Sensor-Radiator outlet-temperature
C1E765A Sensor-Heated oxygen (HO2S)
C1E773AA Sensor-Temperature-Cylinder block
C1E779AA Sensor-Pressure-High pressure EGR inlet
C1E782AA Sensor-Temperature-High pressure EGR cooler outlet
C1E803A Sensor-Manifold Absolute-Pressure (MAP)
C1E803E Sensor-Manifold Absolute-Pressure (MAP)
C1E807C Sensor-Mass Air Flow and Temperature-(MAFT) Bank 1
C1E843A Sensor-Outlet temperature-Fixed turbocharger
C1E925 Solenoid-Active engine mount
C1E925B Solenoid-Active engine mount
C1EC01C Fan-Cooling-Electric-Front
C1EC01D Motor-Cooling fan-1
C1EC01EM Cooling fan harness to engine compartment harness
C1ET02 Module-Transmission-control
C1ET76 Sensor-Selector-position
C1HA06A Pump-Coolant-Fuel fired booster heater (FFBH)
C1HB03A Block heater harness to AC mains supply
C1MC06M Sensor-Brake pad wear-Front left
C1MP10 Sensor-Parking aid-Inner-Front-Left
C1MP11 Sensor-Parking aid-Outer-Front-Left
C1MP13A Sensor-Park assist-Front-Right
C1RD15BM Washer jet-Heated-Center
C1RH02C Horn(s)
C1RW18 Pump-Power wash
C2H101E Module-Automatic-Temperature Control
C2H101F Module-Automatic-Temperature Control
C2H101G Module-Automatic-Temperature Control
C2H101H Module-Automatic-Temperature Control
C2H101J Module-Automatic-Temperature Control
C2H123 Blower-Front
C2H206 Motor-Recirculation
C2H251 Motor-Temperature blend-Front-Left
C2H252 Motor-Temperature blend-Front-Right
C2H263 Motor-Cool air bypass
C2H460 Sensor-Temperature-Duct air-Foot-Front-Left
C2H461 Sensor-Temperature-Duct air-Foot-Front-Right
C2LF23A Switch-Auxiliary lighting
C2LN111 Lamp-Glovebox illumination
C2LS32A Switch-Hazard warning lamps
C2LS41A Switchpack-Steering wheel-Left
C2LS41B Switchpack-Steering wheel-Right
C2MC57A Module-Cooling fan-Head-up display
C2ME06 Speaker-Mid-range-Instrument panel
C2PD09 Illumination-Stowage compartment
C2PP11 Switchpack-Steering column-adjustment
C2PS212 Motor-Seat latch release-Third row-Left
C2R103A Airbag-Passenger
C2R103B Airbag-Passenger
C3A-A2 Driver door harness to main harness
C3AT18 Module-Trailer-brake control
C3B-A2 Passenger door harness to main harness
C3B-C2 Passenger door trim harness to passenger door harness
C3DC08 Socket-Accessory 12V-Stowage compartment-Floor console
C3DC93 Socket-Charging-USB-Floor console-Rear-Left
C3ET66 Sensor-Temperature-Differential oil
C3H464A Sensor-Temperature-Duct air-Foot-Rear-Left
C3H465B Sensor-Temperature-Duct air-Foot-Rear-Right
C3H466B Sensor-Temperature-Duct air-Face-Rear-Left
C3HA00 Panel-Climate control-Rear
C3HA50 Motor-Temperature blend-Auxiliary-Left
C3HA51 Motor-Temperature blend-Auxiliary-Right
C3HA52 Motor-Temperature blend-Auxiliary climate control
C3HS03A Module-Climate control Driver seat (DSCCM)
C3HS05A Assembly-Climate-Seat cushion-Driver
C3HS05AM Assembly-Climate-Seat cushion-Driver
C3HS07A Heater element-Cushion-Passenger
C3HS08A Module-Climate control Passenger seat (PSCCM)
C3HS10A Assembly-Climate-Seat backrest-Driver
C3HS13AM Assembly-Climate-Seat cushion-Passenger
C3HS31A Switchpack-Rear console
C3HS39B Assembly-Climate-Seat cushion-Rear-Left
C3HS41C Module-Climate control-Rear seat-Left
C3HS41D Module-Climate control-Rear seat-Right
C3HS43BM Assembly-Climate-Seat cushion-Rear-Right
C3HS74B Assembly-Climate-Seat backrest-Rear-Left
C3HS75A Heater element-Backrest-Rear-Right
C3HS75B Assembly-Climate-Seat backrest-Rear-Right
C3HS85 Switch-Seat heat-Rear-LH
C3LN47A Lamp-Footwell-Rear-Right
C3LN47B Lamp-Footwell-Rear-Left
C3MA01A Controller-Master-Infotainment (IMC)
C3MA01C Controller-Master-Infotainment (IMC)
C3MA01H Controller-Master-Infotainment (IMC)
C3MA01P Controller-Master-Infotainment (IMC)
C3MA02C Controller-Slave-Infotainment (ISC)
C3MA02L Controller-Slave-Infotainment (ISC)
C3MA11AA Hub-USB 2.0
C3MA11B Hub-USB 2.0
C3MA11CA Hub-USB 2.0
C3MC53 Module-General-Proximity Sensor
C3ME03A Audio head unit
C3ME03C Audio head unit
C3ME76 Speaker-Subwoofer
C3ME118A Panel-Audio Video Input-Output
C3ME118C Panel-Audio Video Input-Output
C3ME118J Panel-Audio Video Input-Output
C3MR01A Screen-Rear seat-entertainment-Left
C3PS02A Module-Driver seat
C3PS12A Pump-Lumbar-Driver
C3PS13A Pump-Lumbar-Passenger
C3PS13D Pump-Lumbar-Massage
C3PS22C Switchpack-Seat-Driver
C3PS25 Motor-Seat-Tilt-Driver
C3PS27 Motor-Seat height-driver
C3PS32A Switchpack-Seat-Passenger
C3PS35 Motor-Seat-Tilt-Passenger
C3PS44 Switchpack-Powerfold-Rear seat
C3PS71A Module-Passenger seat
C3PS91A Solenoids-Lumbar-Driver
C3PS93A Solenoids-Lumbar-Passenger
C3PS100C Switchpack-Seats-Rear-Left
C3PS114B Solenoid-Master-Massage
C3PS193A Motor-Head restraint
C3R116 Sensor-Occupant detection
C3R116MA Sensor-Occupant detection
C3R123 Switch-Seatbelt-Rear Left
C3R170 Pretensioner-Seatbelt-Passenger
C3R173 Pretensioner-Seatbelt anchor-Driver
C3R215 Sensor-Seat position-Driver
C4AT24A Module-Control-Deployable towbar
C4AT26 Motor-Deployable towbar
C4CA04 Sensor-Wheel speed-Rear-Left
C4CL01A Compressor-Self levelling suspension (SLS)
C4DC03A Battery
C4DC31A Module-Voltage quality
C4HF01 Pump-Fuel-Fuel fired booster heater (FFBH)
C4LN13 Lamp-Tailgate-Upper-Left
C4LS36B Assembly-Tail lamp-Tailgate-Right
C4MC11A Unit-Fuel Tank
C4ME168 Amplifier-Antenna-TV-Left
C4ME192A GPS signal splitter
C4ME206 Antenna-Bluetooth-Rear
C4MP17 Sensor-Parking aid-Outer-Rear-Right
C4MP19 Camera-Rear view
C4MT01A Module-Telematic control
C4PD06 Switch-Deployable luggage compartment-floor
C4PK08A Antenna-LF-Luggage compartment-Center
C4PL18 Motor-Release-Fuel flap
C4PL45 Lamp-License plate and-tail door switch
C4PL126B Module-Hands-free tailgate-Right
C4PL126C Module-Hands-free tailgate-Right
C4PL129 Sensor-Hands-free tailgate-Upper
C4PR59B Module-Tailgate control-Upper
C4PR71 Motor-Closing-Tailgate
C4PS51 Switchpack-Powerfold-Third row seat
C4PS190 Motor-Head restraint-Third row-Left
C4R128 Pretensioner-Seatbelt Third row-Right
C4RB02A Module-Blind spot monitoring-Right
C5LN45B Ambience lighting LED-Door handle-Driver
C5LN107 Ambience lighting LED-Door-Driver
C5ME07 Speaker-Bass-Front door-Left
C5ME15 Speaker-Mid range-Front door-Left
C6LN45B Ambience lighting LED-Door handle-Passenger
C6ME16 Speaker-Mid range-Front door-Right
C7LN33 Lamp-Puddle-Rear-Left
C7ME09 Speaker-Bass-Rear door-Left
C7PL01AL Module-Rear door-Left
C7PL72 Motor-Central door-locking-Rear-Left
C8LN36 Lamp-Puddle-Rear-Right
C8LN44 Ambience lighting LED-Door handle-Rear-Right
C8ME12 Speaker-Bass-Rear door-Right
C8PK26 Handle-Rear door-Right
C8PL72 Motor-Central door locking-Rear-Right
C8PM110 Switch-Door locking-Rear-Right
C9LN14 Lamp-Interior-Rear Left
C9LN27 Lamp-Interior-Rear
C9LN28 Console-Overhead-Front
C9MC45 Receiver-Tire-pressure monitoring system (TPMS)
C9ME43A Roof pod
C9ME144 Headphones-Wireless
C9ME161 Speaker-Mid-range-Luggage compartment-Left
C9ME164A Antenna-FM2 and Digital radio band 3
C9ME164B Antenna-FM2 and Digital radio band 3
C9ME166 Amplifier-Antenna-TV-Left
C9ME166A Antenna-TV and Digital radio band 3
C9MF13M Fan-Cooling-IPCM
C9MN03A Roof pod
C9MT13 Speaker-Telematics
C9PM05 Mirror-Rear view
C9PR32A Module-Roof opening panel control
C9R109 Air curtain-Side-Left
C9RD02A Element-Heated rear window
C9RD03B Heater-Windshield-Left
C9RW06 Sensor-Rain light
C11-AB2 Link harness to engine compartment harness
C11-AB3 Engine compartment harness to link harness
C11-AE1 Stud-cable junction
C11-AE2 Stud-cable junction
C11-AF Engine harness to knock sensor link harness
C11-AN Knock sensor link harness to engine harness
C11-B2 Bumper harness to engine compartment harness
C11-B3 Engine compartment harness to bumper harness
C11-D1 Engine compartment harness to bumper harness
C11-D2 Bumper harness to engine compartment harness
C11-F2 EPAS link harness to engine compartment harness
C11-F2 EPAS link harness to engine compartment harness1
C11-F2 EPAS link harness to engine compartment harness2
C11-F3 Engine compartment harness to link harness
C11-G1 Engine compartment harness to EPAS link harness
C11-G2 EPAS link harness to engine compartment harness
C11-G2 EPAS link harness to engine compartment harness1
C11-G2 EPAS link harness to engine compartment harness2
C11-K1 Engine compartment harness to link harness
C11-K2 Link harness to engine compartment harness
C11-KA1 Engine compartment harness to cooling fan harness
C11-KA2 Cooling fan harness to engine compartment harness
C11-M1 Engine compartment harness to engine harness
C11-M2 Engine harness to engine compartment harness
C11-N1 Engine compartment harness to engine harness
C11-N2 Engine harness to engine compartment harness
C11-P13 Engine compartment harness to glow plug harness
C11-P14 Engine harness to engine compartment harness
C11-P15 Engine compartment harness to engine harness
C11-P16 Engine harness to engine compartment harness
C11-R1 Engine compartment harness to glow plug harness
C11-R2 Glow plug harness to engine compartment harness
C11-S1 Engine compartment harness to glow plug harness
C11-S2 Glow plug harness to engine compartment harness
C11-SS1 Engine harness to link harness
C11-SS2 Link harness to engine harness
C11-T4 Engine harness to glow plug harness
C11-T5 Glow plug harness to engine harness
C11-U1 Engine compartment harness to cooling fan harness
C11-U2 Cooling fan harness to engine compartment harness
C11-UU1 Engine harness to link harness
C11-UU2 Link harness to engine harness
C11-V1 Engine harness to link harness
C11-V2 Link harness to engine harness
C11-YA1 Engine harness to transmission harness
C11-YA2 Transmission harness to engine harness
C11-Z1 Engine harness to starter motor link harness
C11-Z1 Engine harness to starter motor link harness1
C11-Z2 Starter motor link harness to engine harness
C11-Z2 Starter motor link harness to engine harness1
C12-A1 Engine compartment harness to instrument panel harness
C12-A2 Instrument panel harness to engine compartment harness
C13-M1 Engine compartment harness to transmission harness
C13-M2 Transmission harness to engine compartment harness
C31-A2 Main harness to engine compartment harness
C31-F1 Main harness to engine compartment harness
C31-G1 Main harness to engine compartment harness
C31-J2 Main harness to engine compartment harness
C31-K1 Main harness to engine compartment harness
C31-K2 Engine compartment harness to main harness
C31-L1 Engine compartment harness to main harness
C32-A1 Main harness to instrument panel harness
C32-LA1 Main harness to instrument panel harness
C32-M2 Rear console harness to main harness
C32-N2 Instrument panel harness to main harness
C33-A2 Driver seat harness to main harness
C33-AB1 RSE link harness to head restraint link harness
C33-AC1 Telematics harness RSE link harness
C33-AD1 RSE link harness to head restraint link harness
C33-B2 Driver seat harness to main harness
C33-BD1 Head restraint link harness to RSE link harness
C33-D1 Main harness to wing harness
C33-J2 Driver seat harness to main harness
C38-A2 Rear door harness to main harness
C38-C2 Rear door harness to door trim harness
C44-F2 Rear bumper harness to main harness
C44-N1 Main harness to trailer harness
C44-TA1 Tailgate harness to tailgate link harness
C44-ZZ1 Main harness to main harness
C49-A1 Main harness to roof harness
CBPL64 Motor-Central door-locking-Passenger
CBPM26C Proximity camera-Mirror-Left
CBPW20 Motor-Window-Passenger
