If you download this document, you will be lost 5700 Beer
Kobelco Crawler Crane CKE2500-2 Parts Catalog S3JD20005ZO​
File Size: 155 MB
File Format: PDF
Brand: Kobelco
Machine Type:
Crawler Crane
Manual Type: Parts Manual, Spare Parts Catalog, Parts List
Model: Kobelco CKE2500-2 Crawler Crane
Book Number: S3JD20005ZO
- CKE 2500-2
- CKE 2500/2
- CKE2500-2
- CKE2500/2
LIST OF FILES:
Kobelco Crawler Crane CKE2500-2 Parts Catalog S3JD20005ZO.pdf (1287 Pages)
Hino Engine P11CUN-KSFA Parts Catalog P11CUN-KSFA.pdf (67 Pages)
Kobelco CK CKE Series TIER-3 Hydraulic Components Parts Catalog S3JJ04101ZO.pdf (352 Pages)
CONTENTS:
1. Control System
2. Winch System (Without Free Fall)
3. Winch System (With Free Fall)
4. Boom Winch System
5. Jib Winch
6. Swing System
7. Lines
8. Power Plant
9. Electric System
10. Cab / Guarq
11. Lower System
12. Crane Attachment
13. Luffing Attachment
14. Gantry
15. Tagline (Opt.)
16. Reeving Winch
17. Safety Device
18. Counterweight / Frame
19. Label
20. Others
21. Opt
Illustration Index
Cylinder Head
Cylinder Block
Timing Gear Cover & Flywheel Housing
Main Moving Parts
Camshaft & Idle Gear
Valve System
Air Intake & Exhaust System
Lubrication System
Oil Filter
Oil Cooler
Oil Pump
Fuel System
Fuel Filter
Common-Rail
Pump, Common-Rail
Cooling System
Electrical Parts
Turbocharge-8
Engine Accessory Parts
Alternator
Starting Motor
Gasket Kit (Engine Overhaul)
1. Pump Group
2. Motor Group
3. Cylinder Group
4. Valve Group
5. Others Group
  • Kobelco Crawler Crane CKE2500-2 Parts Catalog S3JD20005ZO.txt
