Kobelco Crawler Crane CK2000G-3 Parts Manual S3JC05131ZO04
Size: 268.93 MBFormat: PDF
Brand: Kobelco
Type of Machine: Crawler Crane
Type of Manual: Parts Catalog, Parts List
Model: Kobelco CK2000G-3 Crawler Crane
Book Number: S3JC05131ZO04
Kobelco Crawler Crane CK2000G-3 Parts Manual S3JC05131ZO04.pdf (1386 Pages)
Isuzu Engine 6UZ1XBJK01 Parts Manual.pdf (102 Pages)
Content:
Our policies and instructions: https://dhtauto.com/dht/threads/rules-when-using-the-forum-update-to-03-01-2022.90280/Kobelco Crawler Crane CK2000G-3 Parts Manual S3JC05131ZO04.pdf (1386 Pages)
1. Control Device
2. Front Rear Winch
3. Boom Winch
4. Swing Device
5. Driving Device
6. Hydraulic Lines
7. Electric Lines
8. Cab Guard Platform
9. Frame Counterweight
10. Gantry
11. Lower Device
12. Crane Attachment
13. Luffing Jib Attachment
14. Guy Cable Rope Hook
15. Safety Device
16. Third Winch (Opt.) Jib Winch
17. Reeving Winch (Opt.)
18. Label
19. Others
Engine Gasket Kit
Cylinder Head Cover
Cylinder Head
Cylinder Block
Oil Pan And Level Gauge
Camshaft And Valve
Crankshaft, Piston And Flywheel
Timing Gear Case And Flywheel Housing
Engine Mounting
Inlet Manifold
Exhaust Manifold
Ventilation System
Water Pump And Corrosion Resistor
Thermostat And Housing
Water Piping; Engine
Fan And Fan Belt
Turbocharger System
Air Compressor Piping Engine Side
Fuel Injection System
Fuel Filter And Bracket
Fuel Pump And Pipe
Oil Cooler And Oil Filter
Oil Pump And Oil Strainer
Oil And Vacuum Piping Engine
Emission Piping
Engine Electrical Control Parts
Starter
Generator
Fuel Tank
Def Tank And Piping
Exhaust Pipe And Silencer
Exhaust Brake Valve And Control Cylinder
Wiring Harness And Fuse
Fixing Parts; Wiring Harness
Electrical Control And Other Parts
