If you download this document, you will be lost 5700 Beer
Kobelco Crawler Crane CK2000 CKE1800 Shop Manual and Diagram S5JC00002ZE11​
File Size: 47.23 MB
Manual Details:
  • Brand: Kobelco
  • Machine Type: Crawler Crane
  • Manual Type: Shop Manual, Electrical and Hydraulic Schematic
  • Models: Kobelco CK2000, CKE1800
Additional Information:
  • Part Number: S5JC00002ZE11
  • Total Pages: 690
Cover
Table Of Contents
1. Specification
1.1 Ck2000 Specification
1.2 Cke1800 Specification
2. Maintenance Standardstest Procedures
2.1 Maintenance Standard
2.2 Performance Standard And Test Procedure
3. General Work Standard
3.1 Tightening Torque Of Capscrews And Nuts
3.2 Standard Parts
3.3 Conversion Table
3.4 Table Of Unit Weight
4. Power Train
4.1 Introduction
4.2 Engine
4.3 Pump Drive Assembly
5. Hydraulic System
5.1 Hydraulic Circuits And Components
5.2 Hydraulic Circuit
5.3 Component Specification
5.4 Hydraulic System
5.5 Valves
6. Hoist System
6.1 Apparatus And Location Of Components
6.2 Construction And Function
6.3 Drum Lock
6.4 Winch Assembly
6.5 Brake Pedal
6.6 Bleeding Air From Brake Circuit
7. Boom Hoist System
7.1 Apparatus And Location Of Components
7.2 Construction And Function
7.3 Boom Drum Lock
7.4 Drum And Reduction Unit
8. Swing System
8.1 Apparatus And Location Of Components
8.2 Construction And Function
8.3 Swing Reduction Unit
8.4 Swing Bearing
8.5 Swing Lock
9. Propel System
9.1 Location Of The Major Components
9.2 Construction And Function
9.3 Propel Reduction Unit
9.4 Adjustment
10. Electric System
10.1 Electrical Wiring Schematic
10.2 Connector List
10.3 Arrangement Of Electrical Part
10.4 Electrical Part
10.5 Pressure Switch(Control Pressure Cut & Free Fall)
10.6 Pressure Sensor
10.7 Relay Box (Gg24e00024f1)
10.8 Left Side Stand Panel (With Free Fall)
10.9 Bypass Switch Panel
10.10 Troubleshooting Of Exhaust Gas Third Regulation Engine
11. Load Safety Device
11.1 Part Names And Functions
11.2 Preparation For Use
11.3 Turn The Power On
11.4 Upgrading Programs
11.5 Status Check
11.6 Adjustments
11.7 Error Code (Abnormality Detection) And Countermeasures
11.8 Control Output
11.9 Releases
11.10 Mechanical Specification
11.11 External Dimensions
11.12 Electric Schematic Diagram
11.13 Controller Malfunction Emergency Measures
11.14 Controller Malfunction Emergency Measures(In Case Of Machine Serial No. Jc04-02169 To After)
11.15 Load Safety Device Check Procedures
12. Gauge Cluster
12.1 Configuration Of Display
12.2 Priority
12.3 Status Display
12.4 Fault Log Display
13. Total Controller
13.1 Arrangement Of Total Controller
13.2 Composition Of System
13.3 Function Of Total Controller
13.4 Total Controller (Hardware)
13.5 Adjustment Of Total Controller
13.6 Controller Malfunction Emergency Measures
13.7 Controller Malfunction Emergency Measures(In Case Of Machine Serial No. Jc04-02169 To After)
14. Air Conditioner
14.1 Operation Items
14.2 Safety Monitor Functions
14.3 Disassembly And Assembly Procedure
14.4 Operational Precautions
14.5 Inspection And Maintenance
14.6 Electric System Schematic
15. Translifter System
15.1 Location Of Main Components
15.2 Construction And Working Principle
15.3 Working Principle
15.4 Remote Control Switch
  • Kobelco Crawler Crane CK2000 CKE1800 Shop Manual and Diagram S5JC00002ZE11.txt
