Kobelco Crawler Crane CK1200 Shop Manual and Diagram S5GK00003ZE01
Size: 13.77 MBFormat: PDF
Brand: Kobelco
Type of Machine: Crawler Crane
Type of Manual: Shop Manual, Electrical Diagram, Hydraulic Schematic
Model Covered: Kobelco CK1200 Crawler Crane
Book Number: S5GK00003ZE01
Number of Pages: 471
Cover
Table Of Contents
1. Specification
1.1 Specification
4. Maintenance Standards Test Procedures
4.1 Maintenance Standard
4.2 Performance Standard And Test Procedure
7. General Work Standard
7.1 Tightening Torque Of Capscrews And Nuts
7.2 Standard Parts
7.3 Conversion Table
7.4 Table Of Unit Weight
11. Power Train
11.1 Introduction
11.2 Engine
11.3 Pump Drive Assembly
12. Hydraulic System
12.1 Location Of Main Hydraulic Components
12.2 Hydraulic Circuits And Components
12.3 Hydraulic System
12.4 Valves
13. Hoist System
13.1 Apparatus And Location Of Components
13.2 Construction And Function
13.3 Drum Lock
13.4 Winch Assembly
13.5 Brake Pedal
13.6 Bleeding Air From Brake Circuit
14. Boom Hoist System
14.1 Apparatus And Location Of Components
14.2 Construction And Function
14.3 Boom Drum Lock
14.4 Drum And Reduction Unit
15. Swing System
15.1 Apparatus And Location Of Components
15.2 Construction And Function
15.3 Swing Reduction Unit
15.4 Swing Bearing
15.5 Swing Lock
18. Propel System
18.1 Location Of The Major Components
18.2 Construction And Function
18.3 Propel Reduction Unit
18.4 Adjustment
19. Electric System
19.1 Electrical Wiring Schematic
19.2 Arrangement Of Electrical Part
19.3 Electrical Part
19.4 Troubleshooting Of Exhaust Gas Secondary Regulation Engine
26. Load Safety Device
26.1 Part Names And Functions
26.2 Preparation For Use
26.3 Turn The Power On
26.4 Upgrading Programs
26.5 Status Check
26.6 Adjustments
26.7 Error Code (Abnormality Detection) And Countermeasures
26.8 Control Output
26.9 Releases
26.10 Mechanical Specification
26.11 External Dimensions
26.12 Electric Schematic Diagram
26.13 Controller Malfunction Emergency Measures
26.14 Load Safety Device Check Procedures
27. Gauge Cluster
27.1 Configuration Of Display
27.2 Priority
27.3 Status Display
27.4 Fault Log Display
28. Total Controller
28.1 Arrangement Of Total Controller
28.2 Composition Of System
28.3 Function Of Total Controller
28.4 Total Controller (Hardware)
28.5 Adjustment Of Total Controller
