- If you download this document, you will be lost 150 Beer
Tile: ISUZU Truck Training MYY & MZZ Type Transmission
INTRODUCTION ----- ----- ----- ----- ----- ----- ----- ----- --------- ----- ----- ----- ----- ----- 1
MAIN FEATURES OF MYY & MZZ ----- ----- ----- ----- ----- ----- ----- ----- ----- - ----- ----- 2
GEAR RATIO ----- ----- ----- ----- ----- ----- ----- ----- -- ----- ----- ----- ----- ----- ----- 3
PTO (POWER TAKE OFF) ----- ----- ----- ----- ----- ----- ----- ------ ----- ----- ----- ----- ----- 3
CONSTRUCTION PARTS
TRANSMISSION CASE (MYY 5 SPEED) ----- ----- ----- ----- ----- ------- ----- ----- ----- ----- 5
TRANSMISSION CASE (MYY 6 SPEED) ----- ----- ----- ----- ----- ----- ----- ---- ----- ----- ----- 6
TRANSMISSION CASE (MZZ) ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- 7
TOP GEAR SHAFT (MYY & MZZ) ----------------------------------------------------------------- 8
MAIN-SHAFT (MYY 5 SPEED) ------------------------------------------------------------------- 9
MAIN-SHAFT (MYY 6 SPEED) --------------------------------------------------------------------------- 10
MAIN-SHAFT (MZZ) -------------------------------------------------------------------------------- 11
COUNTER-SHAFT (MYY 5 SPEED) ---------------------------------------------------------------- 12
COUNTER-SHAFT (MYY 6 SPEED & MZZ) ------------------------------------------------------------ 12
CONTROL BOX ------------------------------------------------------------------------------------- 14
GEAR SELECT & SHIFT CONTROL ---------------------------------------------------------------------- 15
INDEX-BALL TYPE SYNCHRONIZER -------------------------------------------------------------- 16
DETENT ASSEMBLY ----------------------------------------------------------------------------- 17
SPEED METER GEAR ----------------------------------------------------------------------------- 17
SECTION VIEW (MYY 5 SPEED) ----------------------------------------------------------------- 18
SECTION VIEW (MYY 6 SPEED) -------------------------------------------------------------------- 19
SECTION VIEW (MZZ) ------------------------------------------------------------------------- 20
SERVICING
OIL LEVEL CHECK ----------------------------------------------------------------------------- 21
PROBLEM & INSPECTION ------------------------------------------------------------------------ 22
MEASUREMENT ITEM ---------------------------------------------------------------------------- 23
SPECIAL TOOLS --------------------------------------------------------------------------- 26
CONSTRUCTION PARTS
SERVICING
