CoolAir
Vip Member
Feb 11, 2022
8
Intialization ABS Module Procedure Ford Fiesta / U2101: Control Module Configuration Incompatible
- Open Ford IDS and detect vehicle, check DTC
- Go to Chassis and use Function “Module Intialization”
- Read carefully caution
- Software will working automatically
- Procedure successfully
- Step by step “Configure the lateral acceleration sensor”, “Configure the longitudial acceleration sensor”, “Configure the pressure sensor”, “Configure the yaw rate sensor”
- Clear DTC.
Good luck!.
  • Like
Reactions: Opensource
