Humss
33
Hyundai Aero Bus (CRC) C6AB Shop Manual 2010
Definition of terms
Unless otherwise specified, all dimensional presentation in illustrations representing the following values or limits is in mm although the unit is not indicated.
1.
Nominal Value (Abbr.: NV)
Shows dimension of an individual part, mutual clearance between parts of standard performance. Values however, do not necessarily conincide with design valuse as they are rounded off to fall within limits necessary for inspection.
2.
Repair Limit (Abbr.: RL)
Shows that when specified value is reached, repair is necessary. Repair means adjustment, grinding replacement of bushings, metals and the like, selection of oversize, selection of shim thickness, etc.
3.
Service Limit (Abbr.: SL)
Shows that when specified value is reached, replacement of the parts with new one is necessary.
4.
Basic Diameter (Abbr.: BD)
Shows nominal diameter of part to be measured.
5.
Tightening Torque (Abbr.: T)
Shows tightening torque of bolts or nuts.
Unit
The SI unit is used. Metric notation is jointly shown in parentheses.
Note, warning and caution
1.Note
A Point of information for the customer.
2.Caution
Information about on activity that could cause damage to the vehicle.
3.Warning
Information about an activity that could cause injury or damage to the driver, occupants or other personnel.
  • Hyundai Aero Bus (CRC) C6AB Shop Manual 2010.txt
