Mr.NFC
Vip Member
Jul 30, 2021
3
26
Novosibirsk, Russia
HOW TO PROGRAMMING POWER STEERING CONTROL MODULE FORD RANGER 2021 WITH FDRS
Step by step
Step 1:
After connecting the software that has received power, select the steps below
- Select the Toolbox item
- Select PSCM
- PSCM - Power Steering Control Module (PSCM) Configuration, select Download
Step 2: PSCM - Power Steering Control Module (PSCM) Configuration section, select RUN and wait
Step 3: Read the notice carefully:
- Power the Battery with a separate charger and keep the voltage constant
- Do not remove the connection cable or turn off the key during the procedure
- Select Yes
Step 4: Turn on the key in the ON position (position II), press OK and wait for the software that is performing the installation
Step 5: Turn off the power key (OFF position) and press OK
Step 6: The successful installation message appears and click OK
Step 7: The end of the process message appears, select OK and conclude the installation process
GOOD LUCK !!!
  • Like
Reactions: Opensource
