V.Jb
6
3
26
Japan
How to find and check ABS Fuse?
ABS system the same as any other electrical system and is protected by a fuse that can blow if an electrical surge or short circuit occurs.ABS pump motor or controller get in trouble when short circuit occurs.
1. How to locate the ABS fuses?
Usually,most ABS fuses are located in the fuse panel under the dash or in the power distribution center under the hood.Consult your car’s usermanual for detail locations.
Remove the shell and find ABS Fuse
After located,use a test light bulb which is connected to ground to test both sides of the fuse.It will ensure the ABS Fuse is working properly.You need to the test light bulb to touch both side of the Fuse.
2. According to the test result:
1.If you just seem one side of fuse get power,it mean ABS fuse damaged,you need to replace it.
2.Both sides of ABS Fuse get power mean it works correctly.
Note: If a blown fuse is found, replace it with a new fuse of the same amperage. Never install a fuse with more amperage than is called for as this could cause damage to the wiring or additional components.
