Subaru BRZ 2020 Service Manual and Circuit Diagram G4470BE
Brand: Subaru
Date: 2020
Model: Subaru BRZ
Type of Manual: Service Manual and Circuit Diagram
Number of Pages: 4202 Pages
Summary
How to read the repair manual
Working precautions and notes
Setting procedures at parts replacement and removal / installation
Oils / Coolants
SPECIFICATIONS
Troubleshooting procedures for ECM control system
Terminology list
Preparation items
Engine control
Engine mechanical
Fuel
Emission control
Intake / exhaust
Cooling
Lubrication
Starting
Cruise control
Automatic transmission / transaxle
Clutch
Manual transmission / transaxle
Drive shaft / propeller shaft
Axle / differential
Wheel alignment
Front suspension
Rear suspension
TIRE PRESSURE MONITORING
Wheel & tire
Brake control
Brake system / pedal / brake booster device
Front brake
Rear brake
Parking brake
Power assisted system
Steering column
Steering gear / linkage
Audio system / visual system
Battery / charging
Power supply & wire harness
Network / communication system
Door lock
Anti-theft system / smart entry & start system
Lighting (interior)
Meter
SRS airbag
Seat
Seat belt
Air conditioner
Instrument panel / body interior
Glass & window
Door / trunk
Outer mirror
Wipers & washers
Lighting (exterior)
Body exterior
Engine control
EFI system (FA20)
Ignition system (FA20)
Cam timing oil control valve ASSY (FA20)
Throttle body ASSY (FA20)
Engine control computer (FA20)
Accelerator pedal rod ASSY (FA20)
Intake air flow meter S/A (FA20)
Camshaft position sensor (FA20)
Crankshaft position sensor (FA20)
Ignition coil and spark plug (FA20)
Engine coolant temperature sensor (FA20)
Engine oil temperature sensor (FA20)
Knock control sensor (FA20)
Vacuum sensor ASSY (FA20)
Air / fuel ratio sensor (FA20)
Oxygen sensor (FA20)
Relay
Engine mechanical
Engine (FA20)
V-belt (FA20)
Cam clearance (FA20)
Timing chain (FA20)
Camshaft (FA20)
Cylinder head gasket (FA20)
Chain cover oil seal (FA20)
Engine rear oil seal (FA20)
Partial engine ASSY (FA20)
Fuel
Fuel system (FA20)
Injector ASSY (FA20 / port fuel injection)
Injector ASSY (FA20 / direct fuel injection)
Fuel pressure sensor (FA20)
Injector driver (FA20)
Fuel pump ASSY (FA20)
Fuel pump ASSY (FA20 / high fuel pressure)
Fuel pump control computer (FA20)
Fuel tank ASSY (FA20)
Fuel sender gauge ASSY (FA20)
Filler pipe (FA20)
Emission control
Emission control system (FA20)
CANISTER
Purge control solenoid valve (FA20)
Fuel tank cap ASSY (FA20)
PCV valve (FA20)
Intake / exhaust
Intake system (FA20)
Intake manifold ASSY (FA20)
Chamber (FA20)
Exhaust manifold (FA20)
Exhaust pipe ASSY (FA20)
Cooling
Cooling system (FA20)
Cooling fan system (FA20)
Coolant (FA20)
Water pump (FA20)
Radiator ASSY (FA20)
Thermostat (FA20 / transmission AT)
Thermostat (FA20 / for engine coolant)
Cooling fan motor (FA20)
Relay (FA20)
Lubrication
Lubrication system (FA20)
Oil & oil filter (FA20)
Engine oil pressure switch ASSY (FA20)
Oil pump ASSY (FA20)
Starting
Starting system (FA20)
Key interlock system
Starter ASSY (FA20)
Engine switch
Ignition (starter) switch ASSY
Key lock unit
Relay
Cruise control
Cruise Control System
CRUISE CONTROL MAIN SWITCH
Automatic transmission system
Automatic transmission fluid
Speed sensor
Transmission wire
Transmission valve body ASSY
Neutral start switch ASSY
Oil cooler ASSY
Select lever
Transmission shift switch
Pattern select switch ASSY
Extension housing rear oil seal
Automatic transmission ASSY
Automatic transmission unit
Torque converter & drive plate
Transmission control computer ASSY
Clutch
Clutch system
Clutch fluid
Clutch pedal
Clutch master cylinder ASSY
Clutch release cylinder ASSY
Clutch
Clutch pedal switch
Manual transmission system
Manual transmission oil
Manual transmission extension housing oil seal
Neutral position switch
Back-up light switch
Floor shift, shift lever ASSY
Manual transmission ASSY
Transmission unit ASSY
Input shaft ASSY
Output shaft ASSY
Counter gear ASSY
Drive shaft system
Rear drive shaft ASSY
Propeller shaft system
Propeller shaft ASSY
Axle / differential
Axle system
Front axle hub bolt
Front axle hub
Steering knuckle
Rear axle hub bolt
Rear axle hub
Rear axle carrier
Differential system
Differential oil
Rear differential carrier oil seal
Rear differential side gear shaft oil seal
Rear differential carrier ASSY
Rear differential mount cushion
Wheel alignment
Front wheel alignment
Rear wheel alignment
Front suspension
Front suspension system
Front strut tower bar
Front shock absorber
Front suspension lower arm
Front stabilizer bar
Front suspension member
Flexible draw stiffener (tS model)
Rear suspension
Rear suspension system
Rear shock absorber
Rear upper arm
Rear lower arm
Toe control link
Rear stabilizer bar
Rear suspension member
Tire pressure monitoring
Tire pressure warning system
TIRE PRESSURE WARNING RECEIVER
TIRE PRESSURE WARNING VALVE
Wheel & tire
Wheel and tire system
Temporary tire
Brake control
Vehicle stability control system
Brake actuator ASSY
Front speed sensor
Rear speed sensor
Steering sensor
VSC (VDC) OFF switch
Brake system
Brake line
Brake fluid
Brake pedal (AT model)
Brake pedal (MT model)
Brake master cylinder ASSY
Brake booster ASSY
Vacuum pump ASSY
Front brake
Front brake
Front brake flexible hose
Rear brake
Rear brake
Rear brake flexible hose
Parking brake
Parking brake system
Parking brake lever ASSY
Parking brake cable ASSY
Parking brake ASSY
Parking brake switch ASSY
Power steering system
Power steering computer
Steering column
Steering lock system
Steering system
Steering column ASSY
Steering wheel
Steering pad switch
Steering linkage
Audio & visual system
Radio receiver ASSY
Navigation receiver ASSY
Front door speaker
Quarter trim speaker
Instrument panel speaker
Amplifier
Amplifier antenna
Navigation antenna
Antenna cord
Antenna cord No. 2
AUX unit
Stereo jack adapter
Microphone
Noise filter
Rear view camera ASSY
Battery / charging
Charging system (FA20)
Alternator (FA20)
Power control system
Battery sensor
Main body ECM
Large-scale multiplex communication system for vehicle body [LIN]
CAN communication system
Door lock
Power door lock control system
Wireless door lock control system (with entry & start system)
Wireless door lock control system (without entry & start system)
Key warning system
Transmitter battery (with smart entry)
Transmitter battery (without smart entry)
Door control transmitter (without smart entry)
Unlock warning switch ASSY
Front door lock ASSY
Trunk panel lock ASSY
Door control receiver
Wireless door lock buzzer
Entry & start system (entry function)
Entry & start system (start function)
Engine immobilizer system (with entry & start system)
Engine immobilizer system (without entry & start system)
Auto alarm system
Electrical oscillator key (for front floor)
Electrical oscillator key (for rear floor)
Electrical oscillator key (for the trunk room)
Electrical oscillator key (for outside of the trunk room)
Transponder key amplifier
Lighting (interior)
Lighting system
Vanity light
Personal map light
Trunk room light
Door courtesy light (installed to the front side)
Ignition key cylinder light
Front door courtesy switch
Meter
Meter & gauge system
Clock system
Combination meter ASSY
Clock ASSY
Light control rheostat
Trip switch
Inner mirror
Inner rearview mirror
SRS airbag
SRS airbag system
Occupant detection system
Driver side air bag module
Steering roll connector
Passenger's airbag module
Curtain airbag module
Side airbag module
Front sub sensor
Front door impact sensor
Side airbag sensor
Curtain airbag sensor
Satellite safing sensor
Airbag control module
Passenger's airbag ON / OFF indicator light
Seat
Seat heater system
Front seat ASSY
Rear seat ASSY
Seat heater switch
Seat cushion heater
Seat backrest heater
Seat belt
Seat belt warning system
Passenger's seat belt warning light
Front seat inner belt ASSY
Front seat outer belt ASSY
Rear seat inner belt ASSY
Rear seat outer belt ASSY
Child seat restraining device (ISO-FIX)
Child seat fixing device (ISO-FIX)
Air conditioner
Heater & air conditioner system (for automatic air conditioning system)
Heater & air conditioner system (for manual air conditioning system)
Refrigerant HFC-134a [R134a]
Cooler piping
Air conditioner radiator ASSY
FRESH / RECIRC door actuator
Mode door actuator
Air mix door actuator
Front blower motor (with fan)
Blower resistor
Blower motor control
Cooler expansion valve
Compressor ASSY
Cooler condenser ASSY
Cooler thermistor (in-vehicle sensor)
Cooler thermistor (ambient sensor)
Cooler thermistor (sunload sensor)
Cooler thermistor (evaporator sensor)
Air conditioner pressure switch
Air conditioner panel (for automatic air conditioning system)
Air conditioner panel (for manual air conditioning system)
Relay
Cigarette lighter/accessory socket (interior)
Power supply outlet socket (installed to the front side)
Power supply outlet socket (installed to the rear side)
Instrument panel UPR
Instrument panel LWR
Front console box
Roof head lining
Glass & window
Power window system
Power window regulator master switch ASSY
Power window regulator switch ASSY (installed to the front side)
Power window regulator motor ASSY (installed to the front side)
Windshield glass
Back window glass
Window defogger system
Quarter window
Relay
Door / trunk
Trunk opener system
Front hood
Cable ASSY front hood
Front door
Trunk panel
Stay ASSY trunk
Trunk opening switch ASSY
Trunk electrical key switch
Trunk opener main switch
Cable ASSY fuel
Outer mirror
Electric mirror system
Outer rear-view mirror
Outer rear-view mirror glass
Outer mirror switch
Relay
Wipers & washers
Wiper & washer system
Front wiper motor
Front wiper rubber
Wiper switch
Washer motor
Washer tank
Washer nozzle
Lighting (exterior)
Lighting system
Auto leveling system
Headlights
Fog light
Front side marker lights
Rear combination light
Back-up light
License plate light
High-mounted stop light
Headlight dimmer switch
Hazard warning switch
Stop light switch
Automatic light control sensor
Height control sensor
Headlight leveling computer
Turn signal flasher
Relay
Horn system
Body exterior
Front bumper
Front bumper molding
Rear bumper
Rear bumper stripe
Rear spoiler
Name plate
Front door weather strip
Roof drip side finish molding
Front fender garnish
Trunk garnish
