If you download this document, you will be lost 1105 Beer
Ford Transit Duratorq 2019 Workshop Service Manual
Publication Date: 2019
Number of Pages: 2246 Pages
Model: Ford Transit Duratorq 2019
Brand: Ford
Type of Manual: Workshop Service Manual
100 Service Information
100-00 General Information
100-01 Identification Codes
100-02 Jacking and Lifting
100-04 Noise, Vibration and Harshness
204 Suspension
204-00 Suspension System - General Information
204-01 Front Suspension
204-02 Rear Suspension
204-04A Wheels and Tires
204-04B Tire Pressure Monitoring System TPMS
205 Driveline
205-01 Driveshaft
205-02A Rear Drive Axle.Differential
205-02B Wheel Hubs and Bearings - Full Floating Axle
206 Brake System
206-00 Brake System - General Information
206-03 Front Disc Brake
206-04 Rear Disc Brake
206-05 Parking Brake and Actuation
206-06 Hydraulic Brake Actuation
206-07 Power Brake Actuation
206-09 Anti-Lock Brake System ABS and Stability Control
211 Steering System
211-00 Steering System - General Information
211-02 Power Steering
211-04 Steering Column
211-05 Steering Wheel and Column Electrical Components
303 Engine
303-00B Engine System - General Information
303-01C Engine - 2.2L Duratorq-TDCi 74kW, 100PS - Puma, 2.2L Duratorq-TDCi 92kW, 125PS - Puma, 2.2L Duratorq-TDCi 114kW, 155PS - Puma, LHD FWD,RHD FWD
303-01D Engine - 2.2L Duratorq-TDCi 74kW-100PS - Puma,2.2L Duratorq-TDCi 92kW, 125PS - Puma,2.2L Duratorq-TDCi 99kW, 135PS - Puma-2.2L Duratorq-TDCi 114kW-155PS - Puma, LHD 4WD,LHD RWD,RHD 4WD,RHD RWD
303-03C Engine Cooling - 2.2L Duratorq-TDCi 74kW-100PS - Puma, 2.2L Duratorq-TDCi 92kW-125PS - Puma, 2.2L Duratorq-TDCi 114kW-155PS - Puma, LHD FWD,RHD FWD
303-04C Fuel Charging and Controls - 2.2L Duratorq-TDCi 74kW-100PS - Puma, 2.2L Duratorq-TDCi 92kW-125PS - Puma,2.2L Duratorq-TDCi 114kW-155PS - Puma, LHD FWD,RHD FWD
303-05C Accessory Drive - 2.2L Duratorq-TDCi 74kW-100PS - Puma, 2.2L Duratorq-TDCi 92kW-125PS - Puma, 2.2L Duratorq-TDCi 114kW-155PS - Puma, LHD FWD, RHD FWD
303-06C Starting System - 2.2L Duratorq-TDCi 74kW-100PS - Puma, 2.2L Duratorq-TDCi 92kW-125PS - Puma, 2.2L Duratorq-TDCi 114kW-155PS - Puma, LHD FWD, RHD FWD
303-08E Engine Emission Control
303-12C Intake Air Distribution and Filtering - 2.2L Duratorq-TDCi 74kW-100PS - Puma, 2.2L Duratorq-TDCi 92kW-125PS - Puma, 2.2L Duratorq-TDCi 114kW-155PS - Puma, LHD FWD,RHD FWD
303-14E Electronic Engine Controls
308 Manual Transmission, Clutch and Transfer Case
308-01B Clutch
308-02B Clutch Controls
308-03B Manual Transmission
308-06B Manual Transmission External Controls
309 Exhaust System
309-00E Exhaust System
310 Fuel System - General Information
310-00C Fuel System - General Information - 2.2L Duratorq-TDCi 74kW-100PS - Puma, 2.2L Duratorq-TDCi 92kW-125PS - Puma, 2.2L Duratorq-TDCi 114kW-155PS - Puma, LHD FWD,RHD FWD
310-00D Fuel System - General Information - 2.2L Duratorq-TDCi 74kW100PS - Puma2.2L Duratorq-TDCi 92kW125PS - Puma2.2L Duratorq-TDCi 99kW135PS - Puma2.2L Duratorq-TDCi 114kW155PS - Puma, LHD 4WDLHD RW
310-01D Fuel Tank and Lines - 2.2L Duratorq-TDCi 74kW-100PS - Puma, 2.2L Duratorq-TDCi 92kW-125PS - Puma, 2.2L Duratorq-TDCi 99kW-135PS - Puma-2.2L Duratorq-TDCi 114kW-155PS - Puma, LHD 4WD,LHD RWD,RHD 4WD,RHD RWD
310-02 Acceleration Control
412 Climate Control System
412-00 Climate Control System - General Information
412-02B Rear Climate Control
412-03 Supplemental Climate Control
413 Instrumentation and Warning Systems
413-01A Instrumentation, Message Center and Warning Chimes
413-13A Parking Aid
413-17 Tachograph
414 Battery and Charging System
414-00A Charging System - General Information
414-01 Battery, Mounting and Cables
414-05 Voltage ConverterInverter
415 Information and Entertainment Systems
415-00G Information and Entertainment System - General Information
417 Lighting
417-01 Exterior Lighting
417-02 Interior Lighting
418 Electrical Distribution
418-00 Module Communications Network
418-02 Wiring Harnesses
419 Electronic Feature Group
419-01A Perimeter Anti-Theft Alarm
419-01B Passive Anti-Theft System PATS
419-01C Emergency Call Systems
419-03 Cruise Control
419-07A Lane Departure Warning
419-10 Multifunction Electronic Modules
501 Body and Paint
501-02 Front End Body Panels
501-03 Body Closures
501-05 Interior Trim and Ornamentation
501-08 Exterior Trim and Ornamentation
501-09 Rear View Mirrors
501-10A Front Seats
501-10B Rear Seats
501-10C Second Row Seats
501-10D Third Row Seats
501-10E Additional Row Seats
501-11 Glass, Frames and Mechanisms
501-12 Instrument Panel and Console
501-14 Handles, Locks, Latches and Entry Systems
501-16 Wipers and Washers
501-19 Bumpers
501-20A Seatbelt Systems
501-20B Supplemental Restraint System
502 Frame and Mounting
502-00 Uni-Body, Subframe and Mounting System
Wiring Diagrams
003-1 Introduction
004-1 Symbols
010-1 Grounding
011-1 Fuse and Relay Information
012-1 Charging System
013-1 Power Distribution
014-1 Module Communications Network
020-1 Starting System
023-1 Electronic Engine Controls - 2.2L
024-1 Electronic Engine Controls - 2.0L
029-1 Transmission Controls
031-1 Cruise Control
033-1 Cooling Fan
034-1 All Wheel Drive AWD
037-1 Shift Interlock
040-1 Auto-Start-Stop System
042-1 Vehicle Dynamic Systems
044-1 Horn, Cigar Lighter
046-1 Supplemental Restraint System
052-1 Auxiliary Climate Control
054-1 Manual Climate Control System
056-1 Heated Window
060-1 Instrument Cluster
071-1 Cluster and Panel Illumination
081-1 Wipers and Washers
085-1 Headlamps, Autolamps
086-1 Fog Lamps
089-1 Interior Lamps
090-1 Turn Signal, Stop, Hazard Lamps
092-1 Parking, Rear and License Lamps
093-1 Reversing Lamps
095-1 Trailer, Camper Adapter
100-1 Power Windows
109-1 Retractable Running Boards
112-1 Passive Anti-Theft System
117-1 Remote Keyless Entry and Alarm
118-1 Tire Pressure Monitor System
119-1 Climate Controlled Seats
120-1 Power Seats
124-1 Power Mirrors
130-1 Audio System, Navigation
140-1 Customer Access
145-1 Parking Aid
146-1 Vehicle Emergency Messaging System
150-1 Connector Views
151-1 Component Location Views
152-1 Component Location Charts
160-1 Vehicle Repair Location Charts
