Ford Maverick XLT Version 2022 2.0L EcoBoost Workshop Manual and Wiring Diagram
Date: 2022
Type of Manual: Workshop Manual and Wiring Diagram
Brand: Ford
Number of Pages: 13586 Pages
Model: Ford Maverick XLT Version 2.0L EcoBoost
VEHICLE INFORMATION 3FTTW8F96NRA01872
Workshop Manual
Index
Master DTC Chart (All-Inclusive)
100 Service Information
204 Suspension
205 Driveline
206 Brake System
211 Steering System
303 Engine
307 Automatic Transmission
309 Exhaust System
310 Fuel System - General Information
412 Climate Control System - General Information
413 Instrumentation and Warning Systems
414 Battery and Charging System
415 Information and Entertainment Systems
417 Lighting
418 Electrical Distribution
419 Electronic Feature Group
501 Body and Paint
502 Frame and Mounting
Wiring Diagrams
Index
003Introduction
004Symbols
005Connector Repair Procedures
010Grounds
011Fuse and Relay Information
012Charging System
013Power Distribution/BCM
014Module Communications Network
020Starting System
024Electronic Engine Controls - 2.0L
029Transmission Controls - 8F35
031Cruise Control
033Cooling Fan
034All Wheel Drive (AWD)
037Shift Interlock
040Auto-Start-Stop System
042Vehicle Dynamic Systems
043Power Steering Controls
044Horn/Cigar Lighter
046Supplemental Restraint System
055Automatic Climate Control System
056Heated Window
060Instrument Cluster
066Warning Devices
071Cluster and Panel Illumination
081Wipers and Washers
085Headlamps/Autolamps
089Interior Lamps
090Turn Signal/Stop/Hazard Lamps
092Parking, Rear and License Lamps
093Reversing Lamps
095Trailer/Camper Adapter
100Power Windows
101Roof Opening Panel
110Power Door Locks
112Passive Anti-Theft System
117Remote Keyless Entry and Alarm
118Tire Pressure Monitor System
119Heated/Vented Seats
120Power Seats
124Power Mirrors
128Adjustable Steering Column
130Audio System
145Parking Aid
146Vehicle Emergency Messaging System
149Component Testing
150Connector Views
152Component Location Charts
160Vehicle Repair Location Charts
C100 (AIR CONDITIONING (A_C) CLUTCH AND AIR CONDITIONING (A_C) CLUTCH FIELD COIL)
C101 (CRANKSHAFT POSITION (CKP) SENSOR)
C105 (INLINE)
C107 (CYLINDER HEAD TEMPERATURE (CHT) SENSOR)
C109 (KNOCK SENSOR 1 (KS1))
C110 (INLINE)
C111 (IGNITION COIL-ON-PLUG 1)
C112 (IGNITION COIL-ON-PLUG 2)
C113 (IGNITION COIL-ON-PLUG 3)
C114 (IGNITION COIL-ON-PLUG 4)
C120 (INLINE)
C121 (INLINE)
C122 (INLINE)
C123 (EVAPORATIVE EMISSION (EVAP) CANISTER PURGE VALVE)
C124 (LOW BRAKE FLUID WARNING INDICATOR SWITCH)
C125 (WINDSHIELD WIPER MOTOR)
C126 (INLINE)
C127 (ANTI-THEFT HOOD SWITCH)
C129 (AMBIENT AIR TEMPERATURE (AAT) SENSOR)
C132 (AMBIENT AIR TEMPERATURE (AAT) SENSOR)
C134 (INLINE)
C135A (ANTI-LOCK BRAKE SYSTEM (ABS) MODULE)
C135B (ANTI-LOCK BRAKE SYSTEM (ABS) MODULE)
C137 (WASHER PUMP MOTOR)
C138 (LOW WASHER FLUID WARNING INDICATOR SWITCH)
C148 (AUTO-START-STOP ACCUMULATOR)
C149 (BRAKE BOOSTER VACUUM SENSOR)
C150 (FRONT WHEEL SPEED SENSOR LH)
C151 (FRONT SIDE MARKER LAMP LH)
C155 (ANTI-LOCK BRAKE SYSTEM (ABS) MODULE)
C160 (FRONT WHEEL SPEED SENSOR LH)
C161 (FRONT SIDE MARKER LAMP RH)
C167 (TRANSMISSION RANGE (TR) SENSOR)
C174 (IGNITION TRANSFORMER CAPACITOR)
C177 (PARK LOCK PAWL SOLENOID)
C180 (CAMSHAFT POSITION BANK 1 SENSOR 1 (CMP11))
C181 (FUEL INJECTOR 1)
C182 (FUEL INJECTOR 2)
C183 (FUEL INJECTOR 3)
C184 (FUEL INJECTOR 4)
C197A (STARTER MOTOR)
C197B (STARTER MOTOR)
C199A (SECONDARY ON-BOARD DIAGNOSTIC CONTROL MODULE C (SOBDMC))
C199B (SECONDARY ON-BOARD DIAGNOSTIC CONTROL MODULE C (SOBDMC))
C199C (SECONDARY ON-BOARD DIAGNOSTIC CONTROL MODULE C (SOBDMC))
C200 (INLINE)
C201 (INLINE)
C203 (INLINE)
C205 (HEADLAMP SWITCH)
C206 (INLINE)
C207 (INLINE)
C209 (FOOTWELL LAMP LH)
C210 (INLINE)
C212 (INLINE)
C216A (DRIVER AIRBAG)
C216B (DRIVER AIRBAG)
C217 (HORN SWITCH)
C218A (CLOCKSPRING)
C218B (CLOCKSPRING)
C218D (CLOCKSPRING)
C219 (INLINE)
C220 (INSTRUMENT PANEL CLUSTER (IPC))
C222 (INLINE)
C225A (POWER STEERING CONTROL MODULE (PSCM))
C225B (POWER STEERING CONTROL MODULE (PSCM))
C226A (STEERING COLUMN CONTROL MODULE (SCCM))
C226B (STEERING COLUMN CONTROL MODULE (SCCM))
C228A (HEATING, VENTILATION AND AIR CONDITIONING (HVAC) CONTROL MODULE)
C228B (HEATING, VENTILATION AND AIR CONDITIONING (HVAC) CONTROL MODULE)
C230 (INSTRUMENT PANEL SPEAKER RH)
C231 (INSTRUMENT PANEL SPEAKER LH)
C236 (AIR DISTRIBUTION DOOR ACTUATOR)
C240A (AUDIO CONTROL MODULE (ACM))
C240B (AUDIO CONTROL MODULE (ACM))
C240E (AUDIO CONTROL MODULE (ACM))
C240F (AUDIO CONTROL MODULE (ACM))
C241 (PASSENGER AIRBAG DEACTIVATION (PAD) INDICATOR)
C250 (IGNITION SWITCH)
C251 (DATA LINK CONNECTOR (DLC))
C252 (PASSIVE ANTI-THEFT SYSTEM (PATS) TRANSCEIVER)
C256 (PASSENGER AIRBAG DEACTIVATION (PAD) INDICATOR)
C266 (FOOTWELL LAMP RH)
C278 (BRAKE PEDAL POSITION (BPP) SWITCH)
C286 (AUTOLAMP_SUNLOAD SENSOR)
C289 (AIR INLET DOOR ACTUATOR)
C296 (EVAPORATOR TEMPERATURE SENSOR)
C297 (BLOWER MOTOR CONTROL MODULE)
C301 (ALTERNATING CURRENT (AC) POWER OUTLET SOCKET)
C302 (INLINE)
C303A (SEATBELT PRETENSIONER RH)
C303B (SEATBELT PRETENSIONER RH)
C303C (SEATBELT PRETENSIONER RH)
C305 (INLINE)
C306 (PARKING BRAKE SWITCH)
C310A (RESTRAINTS CONTROL MODULE (RCM))
C310B (RESTRAINTS CONTROL MODULE (RCM))
C317 (INLINE)
C325 (PASSIVE ANTI-THEFT SYSTEM (PATS) CENTER ANTENNA)
C331 (INLINE)
C334 (FRONT SEAT CUSHION HEATER MAT RH)
C335 (FRONT SEAT BACKREST HEATER MAT RH)
C337 (SIDE AIRBAG RH)
C339 (INLINE)
C356 (SEAT TRACK POSITION SENSOR LH)
C360 (FRONT SEAT CONTROL SWITCH LH)
C362 (FRONT SEAT TRACK MOTOR LH)
C363 (FRONT SEAT LIFT MOTOR LH)
C364 (FRONT SEAT CUSHION HEATER MAT LH)
C365 (FRONT SEAT BACKREST HEATER MAT LH)
C367 (SIDE AIRBAG LH)
C377 (EVAPORATIVE EMISSION (EVAP) CANISTER VENT VALVE)
C390 (WIRELESS ACCESSORY CHARGING MODULE)
C400 (INLINE)
C401 (INLINE)
C403 (INLINE)
C404 (INLINE)
C405 (INLINE)
C408 (INLINE)
C409 (FUEL FILLER DOOR LOCK SOLENOID)
C410 (INLINE)
C411 (INLINE)
C413 (INLINE)
C421 (INLINE)
C422 (REAR LAMP ASSEMBLY RH)
C423 (REAR LAMP ASSEMBLY LH)
C426 (REAR WHEEL SPEED SENSOR RH)
C431 (INLINE)
C435 (FUEL TANK PRESSURE (FTP) TRANSDUCER)
C439 (TRAILER TOW CONNECTOR)
C440 (REAR WHEEL SPEED SENSOR LH)
C441 (FUEL VAPOR VENT VALVE (FVVV))
C442 (FUEL TANK ISOLATION VALVE (FTIV))
C448 (INLINE)
C452 (LICENSE PLATE LAMP)
C462 (LICENSE PLATE LAMP)
C466 (SUBWOOFER SPEAKER)
C475 (HIGH MOUNTED STOPLAMP)
C500A (INLINE)
C500B (INLINE)
C501A (DRIVER DOOR MODULE (DDM))
C501B (DRIVER DOOR MODULE (DDM))
C521 (EXTERIOR MIRROR LH)
C524 (DRIVER DOOR WINDOW REGULATOR MOTOR)
C526A (FRONT DOOR LATCH LH)
C526B (FRONT DOOR LATCH LH)
C530 (KEYPAD SWITCH ASSEMBLY)
C535A (DRIVER DOOR WINDOW CONTROL SWITCH)
C535B (DRIVER DOOR WINDOW CONTROL SWITCH)
C536 (FRONT DOOR WOOFER SPEAKER LH)
C540 (DRIVER DOOR WINDOW REGULATOR MOTOR)
C541 (FRONT DOOR LOCK SWITCH LH)
C566 (DRIVER DOOR WINDOW CONTROL SWITCH)
C567 (DRIVER DOOR SIDE IMPACT SENSOR)
C573 (KEYLESS ENTRY DOOR ANTENNA LH)
C574 (INTERIOR FRONT DOOR HANDLE AMBIENT LIGHTING LAMP LH)
C600A (INLINE)
C600B (INLINE)
C601 (EXTERIOR MIRROR RH)
C608 (PASSENGER DOOR WINDOW REGULATOR MOTOR)
C609 (FRONT DOOR LATCH RH)
C624 (PASSENGER DOOR WINDOW CONTROL SWITCH)
C634 (KEYLESS ENTRY DOOR ANTENNA LH)
C641 (FRONT DOOR LOCK SWITCH RH)
C642 (FRONT DOOR WOOFER SPEAKER RH)
C644 (PASSENGER DOOR SIDE IMPACT SENSOR)
C646 (PASSENGER DOOR WINDOW REGULATOR MOTOR)
C648 (PASSENGER DOOR WINDOW CONTROL SWITCH)
C649 (INTERIOR FRONT DOOR HANDLE AMBIENT LIGHTING LAMP RH)
C652A (PASSENGER DOOR MODULE (PDM))
C652B (PASSENGER DOOR MODULE (PDM))
C700 (INLINE)
C703 (REAR DOOR WINDOW REGULATOR MOTOR LH)
C717 (REAR WINDOW CONTROL SWITCH LH)
C719 (REAR WINDOW CONTROL SWITCH LH)
C726 (REAR DOOR WINDOW REGULATOR MOTOR LH)
C750 (REAR DOOR LATCH LH)
C800 (INLINE)
C801 (REAR WINDOW CONTROL SWITCH RH)
C803 (REAR DOOR WINDOW REGULATOR MOTOR RH)
C819 (REAR WINDOW CONTROL SWITCH RH)
C828 (REAR DOOR WINDOW REGULATOR MOTOR RH)
C850 (REAR DOOR LATCH RH)
C906 (VANITY MIRROR LAMP RH)
C907 (VANITY MIRROR LAMP LH)
C910 (IN-VEHICLE TEMPERATURE_HUMIDITY SENSOR)
C921 (ROOF OPENING PANEL MOTOR ASSEMBLIES)
C928 (FRONT INTERIOR LAMP)
C965 (REAR INTERIOR LAMP)
C1001 (LOW VOLTAGE SERVICE DISCONNECT (LVSD))
C1002 (BATTERY JUNCTION BOX [BCMC])
C1010 (INLINE)
C1011 (INLINE)
C1012 (EGR PRESSURE SENSOR)
C1015A (PARK LOCK ACTUATOR)
C1015B (PARK LOCK ACTUATOR)
C1019 (INLINE)
C1026 (EVAC AND FILL)
C1029 (EVAPORATIVE EMISSION (EVAP) CANISTER PURGE VALVE)
C1030 (CABIN HEATER COOLANT PUMP)
C1032 (TRANSMISSION FLUID TEMPERATURE SENSOR)
C1033 (INLINE)
C1035A (BATTERY JUNCTION BOX (BJB))
C1035B (BATTERY JUNCTION BOX (BJB))
C1038 (MOTOR THERMISTOR)
C1039 (INDUCTOR THERMISTOR)
C1040 (GENERATOR THERMISTOR)
C1048 (COOLING FAN MOTOR)
C1050 (INLINE)
C1052 (ELECTRIC WATER PUMP)
C1061 (ENGINE COOLANT TEMPERATURE (ECT) SENSOR)
C1068 (DIFFERENTIAL PRESSURE FEEDBACK EXHAUST GAS RECIRCULATION (EGR) SENSOR)
C1073 (FUEL RAIL PRESSURE (FRP) SENSOR)
C1100A (BATTERY)
C1100B (BATTERY)
C1100C (BATTERY)
C1101 (HORN LH)
C1102 (HORN RH)
C1107 (OUTPUT SHAFT SPEED (OSS) SENSOR)
C1110 (EXTERNALLY CONTROLLED VARIABLE DISPLACEMENT COMPRESSOR (EVDC))
C1111 (HF45 TRANSMISSION)
C1114 (TURBINE SHAFT SPEED (TSS) SENSOR)
C1139 (FUEL METERING VALVE)
C1140 (MANIFOLD ABSOLUTE PRESSURE (MAP) SENSOR)
C1141 (FUEL INJECTOR 1)
C1142 (FUEL INJECTOR 2)
C1143 (FUEL INJECTOR 3)
C1144 (FUEL INJECTOR 4)
C1149 (ENGINE OIL PRESSURE AND TEMPERATURE (EOPT) SENSOR)
C1160 (EXHAUST GAS RECIRCULATION (EGR) VALVE)
C1222 (INLINE)
C1260 (AIR CONDITIONING (A_C) PRESSURE TRANSDUCER)
C1271 (EXHAUST PRESSURE (EP) SENSOR)
C1284A (HEADLAMP ASSEMBLY LH)
C1284B (HEADLAMP ASSEMBLY LH)
C1285A (HEADLAMP ASSEMBLY RH)
C1285B (HEADLAMP ASSEMBLY RH)
C1366 (CAMSHAFT POSITION BANK 1 SENSOR 1 (CMP11))
C1367 (CAMSHAFT POSITION BANK 2 SENSOR 1 (CMP21))
C1368 (ELECTRONIC THROTTLE CONTROL (ETC))
C1381B (POWERTRAIN CONTROL MODULE (PCM))
C1381E (POWERTRAIN CONTROL MODULE (PCM))
C1389 (ELECTRIC EXHAUST GAS RECIRCULATION (EEGR) ASSEMBLY)
C1427 (MANIFOLD ABSOLUTE PRESSURE AND TEMPERATURE (MAPT) SENSOR)
C1457A (DIRECT CURRENT_DIRECT CURRENT (DC_DC) CONVERTER CONTROL MODULE)
C1457B (DIRECT CURRENT_DIRECT CURRENT (DC_DC) CONVERTER CONTROL MODULE)
C1457C (DIRECT CURRENT_DIRECT CURRENT (DC_DC) CONVERTER CONTROL MODULE)
C1465 (FRONT IMPACT SEVERITY SENSOR LH)
C1466 (FRONT IMPACT SEVERITY SENSOR RH)
C1520 (8F35 TRANSMISSION)
C1538 (IGNITION COIL-ON-PLUG 1)
C1539 (IGNITION COIL-ON-PLUG 2)
C1540 (IGNITION COIL-ON-PLUG 3)
C1541 (IGNITION COIL-ON-PLUG 4)
C1551B (POWERTRAIN CONTROL MODULE (PCM))
C1551E (POWERTRAIN CONTROL MODULE (PCM))
C1558A (GENERATOR)
C1558B (GENERATOR)
C1582 (CRUISE CONTROL MODULE (CCM))
C1584 (TURBOCHARGER BYPASS (TCBY) VALVE)
C1615 (KNOCK SENSOR 2 (KS2))
C1617A (HIGH CURRENT BATTERY JUNCTION BOX (BJB))
C1617B (HIGH CURRENT BATTERY JUNCTION BOX (BJB))
C1617C (HIGH CURRENT BATTERY JUNCTION BOX (BJB))
C1617D (HIGH CURRENT BATTERY JUNCTION BOX (BJB))
C1617E (HIGH CURRENT BATTERY JUNCTION BOX (BJB))
C1621 (EGR TEMPERATURE (EGRT) SENSOR)
C1636 (ENGINE OIL PRESSURE (EOP) SENSOR)
C1648 (VARIABLE CAMSHAFT TIMING BANK 1 SOLENOID 1 (VCT11))
C1649 (VARIABLE CAMSHAFT TIMING BANK 1 SOLENOID 2 (VCT12))
C1651 (ACTIVE GRILLE SHUTTER)
C1672 (WASTEGATE CONTROL SOLENOID)
C1689 (BATTERY MONITORING SENSOR)
C1721 (TRACTION BATTERY COOLANT PUMP)
C1748 (VARIABLE OIL PUMP)
C1788 (HEATED WIPER PARK)
C1792 (A CLUTCH_B CLUTCH FLUID PRESSURE SENSOR)
C1795 (VACUUM SOLENOID VALVE (VSV))
C1803A (AIR CONDITIONING CONTROL MODULE (ACCM))
C1803B (AIR CONDITIONING CONTROL MODULE (ACCM))
C1812 (MOTOR ELECTRONICS COOLANT SYSTEM PUMP (MECSP))
C1840 (LINE PRESSURE CONTROL (LPC) SOLENOID)
C1841 (TORQUE CONVERTER CLUTCH (TCC) SOLENOID)
C1842 (TRANSMISSION FLUID TEMPERATURE SENSOR)
C1843 (SHIFT SOLENOID A)
C1844 (SHIFT SOLENOID B)
C1845 (SHIFT SOLENOID C)
C1846 (SHIFT SOLENOID D)
C1847 (SHIFT SOLENOID E)
C1848 (SHIFT SOLENOID F)
C1898A (POWER TRANSFER UNIT (PTU))
C1898B (POWER TRANSFER UNIT (PTU))
C1898C (POWER TRANSFER UNIT (PTU))
C1913 (ENGINE COOLANT BYPASS VALVE)
C1945 (PEDESTRIAN ALERT AUDIBLE WARNING SPEAKER, FRONT)
C2010 (AUDIO CONTROL PANEL)
C2011 (MEDIA BIN AMBIENT LED)
C2012 (POWER SLIDING WINDOW SWITCH)
C2033 (POWER POINT, FRONT)
C2040 (ACCELERATOR PEDAL POSITION (APP) SENSOR)
C2091 (TEMPERATURE DOOR ACTUATOR LH)
C2092 (TEMPERATURE DOOR ACTUATOR RH)
C2195 (IGNITION SWITCH-PUSH BUTTON START)
C2253 (DISPLAY UNIT)
C2280A (BODY CONTROL MODULE (BCM))
C2280B (BODY CONTROL MODULE (BCM))
C2280C (BODY CONTROL MODULE (BCM))
C2280D (BODY CONTROL MODULE (BCM))
C2280E (BODY CONTROL MODULE (BCM))
C2280F (BODY CONTROL MODULE (BCM))
C2280G (BODY CONTROL MODULE (BCM))
C2356 (INSTRUMENT PANEL CENTER SPEAKER)
C2383A (SYNC MODULE [APIM])
C2383D (SYNC MODULE [APIM])
C2383E (SYNC MODULE [APIM])
C2431 (GATEWAY MODULE (GWM))
C2432 (DRIVER LOWER AIRBAG)
C2434 (STEERING COLUMN LOCK MODULE)
C2436 (FOOTWELL AIR DISCHARGE TEMPERATURE SENSOR LH)
C2437 (FOOTWELL AIR DISCHARGE TEMPERATURE SENSOR RH)
C2438 (CENTER REGISTER AIR DISCHARGE TEMPERATURE SENSOR LH)
C2439 (CENTER REGISTER AIR DISCHARGE TEMPERATURE SENSOR RH)
C2490 (STEERING WHEEL SWITCH LH)
C2491 (STEERING WHEEL SWITCH RH)
C2494A (TELEMATICS CONTROL UNIT (TCU))
C2494B (TELEMATICS CONTROL UNIT (TCU) MODULE)
C2494C (TELEMATICS CONTROL UNIT (TCU) MODULE)
C2518 (BATTERY ENERGY CONTROL MODULE B (BECMB))
C2603 (ELECTRIC BOOSTER HEATER)
C2830 (TRAILER BRAKE CONTROL SWITCH)
C3009 (INLINE)
C3010 (INSTRUMENT PANEL CONSOLE SWITCH ASSEMBLY)
C3051 (INLINE)
C3123 (FUEL TANK PRESSURE (FTP) TRANSDUCER)
C3145 (REAR SLIDING WINDOW MOTOR)
C3154A (AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE)
C3154B (AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE)
C3154D (AUDIO DIGITAL SIGNAL PROCESSING (DSP) MODULE)
C3159 (OCCUPANT CLASSIFICATION SYSTEM MODULE (OCSM))
C3187 (FRONT SEAT RECLINE MOTOR LH)
C3200 (SEAT BELT BUCKLE SWITCH RH)
C3201A (SEATBELT PRETENSIONER LH)
C3201B (SEATBELT PRETENSIONER LH)
C3210 (SECOND ROW SIDE IMPACT SENSOR LH)
C3211 (SECOND ROW SIDE IMPACT SENSOR RH)
C3215 (LUMBAR MOTOR LH)
C3233 (EGHR OUTLET TEMPERATURE SENSOR)
C3235 (EGHR INLET TEMPERATURE SENSOR)
C3236 (EXHAUST HEAT EXCHANGER BYPASS VALVE)
C3240 (SEAT TRACK POSITION SENSOR RH)
C3247 (SEAT BELT BUCKLE SWITCH LH)
C3323 (REAR POWER OUTLET SOCKET)
C3429 (ALTERNATING CURRENT (AC) POWER OUTLET SOCKET)
C3502A (DIRECT CURRENT_ALTERNATING CURRENT (DC_AC) INVERTER)
C3502B (DIRECT CURRENT_ALTERNATING CURRENT (DC_AC) INVERTER)
C3512 (MEDIA HUB)
C3522 (USB CHARGE PORT)
C3532 (GEAR SHIFT MODULE (GSM))
C3557 (SECOND ROW SEATBELT BUCKLE SWITCH LH)
C3558 (SECOND ROW SEATBELT BUCKLE SWITCH RH)
C3559 (SECOND ROW SEATBELT BUCKLE SWITCH, CENTER)
C3686 (SECOND ROW SEATBELT PRETENSIONER RH)
C3687 (SECOND ROW SEATBELT PRETENSIONER LH)
C3733 (INLINE)
C3809 (EVAP LEAK DETECTION CONTROL MODULE)
C3841 (ALL WHEEL DRIVE (AWD) MODULE)
C4029 (KEYLESS ENTRY REAR ANTENNA)
C4033 (FUEL PUMP CONTROL MODULE)
C4046 (LICENSE PLATE LAMP)
C4049 (CARGO LAMP)
C4070A (BATTERY)
C4070B (BATTERY)
C4099 (TRAILER TOW CONNECTOR)
C4140 (FUEL LOW PRESSURE (FLP) SENSOR)
C4226A (PARKING AID MODULE (PAM))
C4234 (INLINE)
C4235 (INLINE)
C4236A (HIGH VOLTAGE BATTERY JUNCTION BOX)
C4236B (HIGH VOLTAGE BATTERY JUNCTION BOX)
C4236C (HIGH VOLTAGE BATTERY JUNCTION BOX)
C4236D (HIGH VOLTAGE BATTERY JUNCTION BOX)
C4236E (HIGH VOLTAGE BATTERY JUNCTION BOX)
C4236F (HIGH VOLTAGE BATTERY JUNCTION BOX)
C4237A (BATTERY ENERGY CONTROL MODULE (BECM))
C4237B (BATTERY ENERGY CONTROL MODULE (BECM))
C4237C (BATTERY ENERGY CONTROL MODULE (BECM))
C4237D (BATTERY ENERGY CONTROL MODULE (BECM))
C4238 (INLINE)
C4330 (FUEL PUMP AND SENDER UNIT)
C4347A (ACTIVE TORQUE CONTROL COUPLING (ATCC) SOLENOID)
C4347B (ACTIVE TORQUE CONTROL COUPLING (ATCC) SOLENOID)
C4347C (ACTIVE TORQUE CONTROL COUPLING (ATCC) SOLENOID)
C4357 (REAR PARKING AID CAMERA)
C4369 (SIDE OBSTACLE DETECTION CONTROL MODULE LH (SODL))
C4370 (SIDE OBSTACLE DETECTION CONTROL MODULE RH (SODR))
C4397A (TRAILER TOW MODULE)
C4397B (TRAILER TOW MODULE)
C4433 (BATTERY MONITORING SENSOR)
C4456 (TRACTION BATTERY COOLANT TEMPERATURE SENSOR)
C4478 (PARKING BRAKE ACTUATOR MOTOR LH)
C4479 (PARKING BRAKE ACTUATOR MOTOR RH)
C4494 (TRUCK BED LAMP LH)
C4495 (TRUCK BED LAMP RH)
C4496 (TRUCK BED LAMP SWITCH)
C4498 (TAILGATE LOCK ACTUATOR)
C4525 (PEDESTRIAN ALERT CONTROL MODULE (PACM))
C4544 (REAR OUTER PARKING AID SENSOR LH)
C4545 (REAR INNER PARKING AID SENSOR LH)
C4546 (REAR INNER PARKING AID SENSOR RH)
C4547 (REAR OUTER PARKING AID SENSOR RH)
C9001 (ROOF OPENING PANEL SWITCH)
C9026 (RADIO TRANSCEIVER MODULE (RTM))
C9039 (IMAGE PROCESSING MODULE A (IPMA))
C9064 (REAR SPEAKER LH)
C9066 (REAR SPEAKER RH)
C9094 (SIDE CURTAIN AIRBAG RH)
C9096 (SIDE CURTAIN AIRBAG LH)
C9221 (MICROPHONE)
C9440 (WINDOW PATCH LANE DEPARTURE WARNING HEATER)
components
connectors
splices
grounds
harnesses
A clutch_B clutch fluid pressure sensor (8F35)
AC outlet Rear of center console
AC outlet Left rear side of bed
Accelerator pedal position (APP) sensor Inside vehicle, driver side - on the accelerator pedal
Active grille shutter Engine compartment, front
Active Torque Control Coupling (ATCC) solenoid Rear axle, center
Air Conditioning (A_C) clutch and Air Conditioning (A_C) clutch field coil Engine compartment, right front
Air Conditioning (A_C) Pressure Transducer Engine compartment, right front
Air conditioning (A_C) pressure transducer Under the hood - near right front headlamp
Air Conditioning Control Module (ACCM) Engine compartment, right front
Air distribution door actuator Behind dash panel, right side
Air inlet door actuator Behind dash panel, RH side
Air Conditioning Control Module (ACCM) Engine compartment, front RH side
All Wheel Drive (AWD) module Under passenger seat
Ambient Air Temperature (AAT) sensor Front bumper, inner RH side
Antenna Rear of vehicle, roof
Anti-lock brake system (ABS) module Left rear of engine compartment - near left strut tower
Anti-lock brake system (ABS) module Right rear engine compartment - near right strut tower
Anti-theft hood switch Engine compartment, front
Audio control module (ACM) Behind dash panel, center
Audio control panel Behind dash panel, center
Audio digital signal processing (DSP) module Inside cab center - behind rear seat
Autolamp_ sunload sensor Top center of instrument panel
Auto-start-stop accumulator Engine compartment, rear
Battery Energy Control Module (BECM) Internal to HV battery pack
Battery Junction Box [BCMC] Under hood - left front
Battery energy control module B (BECMB) Front lower instrument panel - in front of center console
Battery Junction Box (BJB) Engine compartment, LH side
Battery monitoring sensor Engine compartment- left side near negative battery post
Battery monitoring sensor Left front side of battery pack
Battery Engine compartment, on positive battery terminal
Battery Under vehicle - in front of fuel tank
Blower motor control module Behind dash panel, right center
Body Control Module (BCM) Behind dash panel, right footwell
Body Control Module (BCM) Under right side of instrument panel
Brake booster vacuum sensor Left rear of engine compartment - near left strut tower
Brake pedal position (BPP) switch Inside vehicle, driver side - on the brake pedal shaft
Cabin heater coolant pump Engine compartment, front
Cargo lamp Left rear side of bed
Center register air discharge temperature sensor LH Left center vent area
Center register air discharge temperature sensor RH Right center vent area
Clockspring Steering wheel
Clockspring (heated steering wheel)
Clockspring Under steering wheel
Cooling fan motor Engine compartment, left side front
Crankshaft Position (CKP) sensor Engine, lower rear RH side
Crankshaft Position (CKP) sensor (2.0L)
Cruise Control Module (CCM) Engine compartment, front center
Cylinder Head Temperature (CHT) sensor Engine compartment, top of engine
Cylinder Head Temperature (CHT) sensor (2.0L)
Data Link Connector (DLC) Behind dash panel, left side
Differential pressure feedback Exhaust Gas Recirculation (EGR) sensor (2.0L)
Direct Current_ Alternating Current (DC_AC) inverter Under rear of center console - center of passenger compartment
Direct Current_ Direct Current (DC_DC) converter control module
Direct Current_ Direct Current (DC_DC) Converter control module Engine compartment, LH side
Direct Current_ Direct Current (DC_DC) converter control module Engine compartment, rear LH side
Display unit Dash panel, center
Downshift paddle switch Steering wheel
Driver door side impact sensor driver door
Driver door window control switch Driver door
Driver door window regulator motor Driver door
Driver Door Module (DDM) Driver door
Driver lower airbag Behind dash panel, left side
Driver air bag module Steering wheel
EGHR inlet temperature sensor Rear center of battery pack
EGHR outlet temperature sensor Rear left of battery pack
EGR Temperature (EGRT) sensor (2.0L)
EGR Temperature (EGRT) sensor Engine, LH side
EGR pressure sensor Engine, top LH side
Electric booster heater Behind dash panel, center
Electric Exhaust Gas Recirculation (EEGR) assembly Engine, top LH side
Electric water pump Engine compartment, right front
Electronic Throttle Control (ETC) Engine, upper front LH side
Electronic Throttle Control (ETC) (2.0L)
Engine coolant bypass valve Engine compartment, rear
Engine Oil Pressure and Temperature (EOPT) sensor (2.0L)
Engine Oil Pressure (EOP) sensor (2.5L)
Engine Coolant Temperature (ECT) sensor (2.0L)
EVAC and fill Engine compartment, LH side
EVAP leak detection control module
Evaporative emission (EVAP) canister purge valve (2.0L)
Evaporative emission (EVAP) canister purge valve Engine, upper rear
Evaporative emission (EVAP) canister vent valve
Evaporator temperature sensor Behind dash panel, center
Exhaust Gas Recirculation (EGR) valve (2.0L)
Exhaust heat exchanger bypass valve Rear right of battery pack
Exhaust Pressure (EP) sensor (2.0L)
Exhaust Pressure (EP) sensor Engine, top LH side
Exterior mirror LH
Exterior front door handle LH Driver door
Exterior front door handle RH Passenger door
Exterior mirror RH Passenger door
Externally controlled variable displacement compressor (EVDC) On A_C compressor
Footwell air discharge temperature sensor LH Behind dash panel, left center
Footwell air discharge temperature sensor RH Behind dash panel, right center
Footwell lamp LH Behind dash panel, left center
Footwell lamp RH Behind dash panel, right center
Front door latch LH Driver door
Front door latch RH Passenger door
Front door lock switch RH Passenger door
Front door lock switch LH Driver door
Front door woofer speaker LH Driver door
Front door woofer speaker RH Passenger door
Front seat backrest heater mat LH (heated seat)
Front seat backrest heater mat RH (heated seat)
Front seat control switch LH (power seat)
Front seat cushion heater mat LH (heated seat)
Front seat cushion heater mat RH (heated seat)
Front seat recliner motor LH (power seat)
Front side marker lamp LH Front of vehicle, LH side
Front side marker lamp RH Front of vehicle, RH side
Front impact severity sensor RH Engine compartment, front RH side
Front impact severity sensor LH Engine compartment, front LH side
Front interior lamp Overhead console
Front seat lift motor LH (power seat)
Front seat track motor LH (power seat)
Front wheel speed sensor LH Behind left front wheel
Front wheel speed sensor RH Behind right front wheel
Fuel filler door lock solenoid Left front of truck bed - near fuel filler
Fuel low pressure (FLP) sensor Under vehicle
Fuel metering valve (2.0L)
Fuel pump and sender unit Fuel tank
Fuel pump control module Top left of fuel tank
Fuel Rail Pressure (FRP) sensor (2.0L)
Fuel tank isolation valve (FTIV)
Fuel Tank Pressure (FTP) transducer Under left rear side of vehicle
Fuel Tank Pressure (FTP) transducer Under vehicle
Fuel vapor vent valve (FVVV) Under left rear side of vehicle
Gateway Module (GWM) Behind dash panel, left side
Gear Shift Module (GSM) Under center console
Generator thermistor (HF45)
Generator On generator
Headlamp assembly LH Engine compartment, front LH side
Headlamp assembly RH Right front bumper
Headlamp switch Behind dash panel, left side
Heated wiper park Right rear of engine compartment - near right strut tower
Heating, Ventilation and Air Conditioning (HVAC) control module Behind dash panel, center
High current Battery Junction Box (BJB) Engine compartment, left side
High current Battery Junction Box (BJB) Engine compartment, LH side
High current battery junction box (BJB)
high mounted stoplamp Rear of cab - top center
High voltage battery junction box Internal to HV battery pack
High voltage battery junction box On bottom left of battery pack
Horn switch Steering wheel
Horn Under hood - left front
Ignition switch- push button start Behind dash panel, left center
Ignition switch Right side of steering column
Ignition transformer capacitor Engine compartment, top of engine
Image Processing module A (IPMA)
Inductor thermistor (HF45)
Instrument panel console switch assembly Center console
Instrument panel speaker RH Behind dash panel, RH side
Instrument Panel Cluster (IPC) Behind dash panel, left side
Instrument panel center speaker Top center of instrument panel
Instrument panel speaker LH Behind dash panel, LH side
Intake Air Temperature (IAT) sensor Engine compartment, left side
Interior front door handle ambient lighting lamp LH Driver door
Interior front door handle ambient lighting lamp RH Passenger door
In-vehicle temperature_ humidity sensor Center of headliner - near rear view mirror
Keyless vehicle rear antenna Inside cab center - behind rear seat
Keypad switch assembly Driver door
License plate lamp LH Left side of license plate
License plate lamp RH Right side of license plate
License plate lamp Above license plate
Line Pressure Control (LPC) solenoid (8F35)
Low brake fluid warning indicator switch Left rear of engine compartment - near left strut tower
Low voltage service disconnect (LVSD) Under hood - left front
Low washer fluid warning indicator switch Engine compartment, rear RH side
Lumbar motor LH (power seat)
Manifold Absolute Pressure (MAP) sensor Engine compartment, front
Manifold Absolute Pressure and Temperature (MAPT) sensor Engine, front center
Manifold Absolute Pressure and Temperature (MAPT) sensor (2.0L)
Media bin ambient LED Lower center of instrument panel
Media hub Lower center of instrument panel
Microphone Left front side of headliner
Motor electronics coolant system pump (MECSP) Near C432
Motor thermistor (HF45)
Occupant Classification System Module (OCSM) Under passenger seat cushion
Output Shaft Speed (OSS) sensor (8F35)
Park lock actuator (HF45)
Park lock pawl solenoid (8F35)
Parking aid module (PAM) Inside cab center - behind rear seat
Parking brake actuator motor LH Left rear wheel well
Parking brake actuator motor LH Under left rear of vehicle - near left rear brake caliper
Parking brake actuator motor RH Right rear wheel well
Parking brake actuator motor RH Under right rear of vehicle - near right rear brake caliper
Parking brake switch Center console
Passenger airbag Behind dash panel, right side
Passenger Airbag Deactivation (PAD) indicator Behind dash panel, center
Passenger door side impact sensor Passenger door
Passenger door window control switch Passenger door
Passenger door window regulator motor Passenger door
Passenger Door Module (PDM) Passenger door
passive anti-theft system (PATS) center antenna (keyless entry)
Passive Anti-Theft System (PATS) transceiver
Pedestrian alert audible warning speaker, front Engine compartment, front LH side
Pedestrian alert control module (PACM) Left front side of battery pack
Power Steering Control Module (PSCM) Behind dash panel, left side
Power point, front Lower center of instrument panel
Power sliding window switch Lower center of instrument panel
Power transfer unit (PTU) Under body - front right
Powertrain Control Module (PCM) Engine compartment, front LH side
Powertrain Control Module (PCM) Engine compartment, LH side
Powertrain Control Module (PCM) (2.0L)
Radio Transceiver Module (RTM) Overhead console
Rear door latch LH Left rear door
Rear door latch RH Right rear door
Rear door window regulator motor RH Right rear door
Rear door window regulator motor LH Left rear door
Rear inner parking aid sensor LH Rear bumper - left center
Rear inner parking aid sensor RH Rear bumper - right center
Rear outer parking aid sensor LH Rear bumper - left outer
Rear outer parking aid sensor RH Rear bumper - right outer
Rear power outlet socket Rear of center console
Rear wheel speed sensor LH Under left rear of vehicle - near left rear wheel hub
Rear wheel speed sensor RH Under right rear of vehicle - near right rear wheel hub
Rear window control switch LH Left rear door
Rear window control switch RH Right rear door
Rear interior lamp Rear side of headliner
Rear lamp assembly LH Left rear side of bed
Rear lamp assembly RH Right rear side of bed
Rear parking aid camera tailgate, center
Rear sliding window motor Inside cab center - behind rear seat
Rear speaker LH Above left c-pillar
Rear speaker RH C-pillar - above right rear door
Rear wheel speed sensor LH Left rear wheel well
Rear wheel speed sensor RH Right rear wheel well
Restraints Control Module (RCM) Under center console
Roof opening panel motor assemblies C-pillar - above right rear door
Roof opening panel switch Front center of headliner
Seat belt buckle switch LH Under right side of driver seat cushion
Seat belt buckle switch RH Under left side of passenger seat cushion
Seat belt pretensioner RH Lower right B-pillar
Seat belt pretensioner LH Left B-pillar
Seat track position sensor LH Under driver seat cushion
Seat track position sensor RH Under passenger seat cushion
Second row seat belt pretensioner LH Rear of vehicle left side
Second row seat belt pretensioner RH Behind right rear door in C-pillar
Second row seatbelt buckle switch LH Under rear seat cushion - near left seatbelt buckle
Second row seatbelt buckle switch RH Under rear seat cushion - near right seatbelt buckle
Second row seatbelt buckle switch, center Under rear seat cushion - near center seatbelt buckle
Second row side impact sensor LH Behind left rear door in C-pillar
Second row side impact sensor RH Behind right rear door in C-pillar
Secondary On-Board Diagnostic Control Module C (SOBDMC) Engine compartment, LH side
Shift solenoid A (8F35)
Shift solenoid B (8F35)
Shift solenoid C (8F35)
Shift solenoid D (8F35)
Shift solenoid E (8F35)
Shift solenoid F (8F35)
Side curtain airbag LH Roof, above left c-pillar
Side curtain airbag RH Roof, above right rear door
Side airbag LH Upper LH side of driver seat back
Side airbag RH Upper RH side of passenger seat back
Side obstacle detection control module LH (SODL) Left rear side of bed
Side obstacle detection control module RH (SODR) Right rear side of bed
Starter motor On starter
Starter On starter
Steering Column Control Module (SCCM) Left side of steering column
Steering column lock module Right side of steering column
Steering wheel switch LH Steering wheel
Steering wheel switch RH Steering wheel
Subwoofer speaker Inside cab center - behind rear seat
SYNC module [APIM] Behind dash panel, center
Tailgate latch actuator Tailgate - near latch handle
Telematics Control Unit (TCU) module Under front of center console
Temperature door actuator RH Behind dash panel, right side
Temperature door actuator LH Behind dash panel, center
Torque Converter Clutch (TCC) solenoid (8F35)
Traction battery coolant temperature sensor Right front side of battery pack
Traction battery coolant pump
Traction battery coolant temperature sensor Right rear side of battery pack
Trailer tow module Inside cab center - behind rear seat
Trailer brake control switch Behind dash panel, left side
Trailer tow connector Rear bumper
Transmission fluid temperature sensor (8F35)
Transmission fluid temperature sensor (HF45)
Transmission Range (TR) sensor (8F35)
Truck bed lamp LH Inside rear of bed - left
Truck bed lamp RH Inside rear of bed - right
Truck bed lamp switch Left rear side of bed
Turbine Shaft Speed (TSS) sensor Engine compartment, left side
Turbocharger Bypass (TCBY) valve (2.0L)
Upshift paddle switch Steering wheel
USB charge port (dual rear power outlets)
Vacuum Solenoid Valve (VSV) Engine compartment, rear center
Vanity mirror lamp LH
