ELSA 5.2 VW - 01.2015 Multilingual | 34.69 GB
Description: Information Base (manual) car repair Concern VW AG. Contains a description of technology of repair and car maintenance, wiring diagrams, bodywork, standard time for work performed, etc.
This program is not designed to work with diagnostic adapters.
A more detailed description can be found in the accompanying documentation (ElsaWin_Primenenie.pdf)
Extras. Information: This distribution contains all the necessary components for installation: 4.0 setup, 4.10 update, 5.0 update, 5.1 update, 5.2 update, the base VW 01.2015, serial numbers, key generator and installation instructions. All the components are easy to install and does not require any additional software.
Installation Procedure
The basic requirement before installing ElsaWin version 4.0 - installed on your system Adobe Reader. The minimum version - 5 or newer.
How to install simple:
1. Install setup 4.0.
2. Install the update 4.1 (optional)
3. Install the update 5.0 (optional)
4. Install the update 5.1 (optional)
5. Install the update 5.2 (optional)
6. Install the base.
IMPORTANT!
Base VW 01.2015 compatible with versions ElsaWin 4.0, 4.1, 5.0, 5.1, 5.2.
Just need to install SVGView.exe - he needed to display elektroskhem.
Name / password to login: admin / admin
Detailed instructions for installing ElsaWin 4.0 and 4.1 from say 2108 - Directory Documentacia
Year / Date of Release: 2015
Version: 01
System requirements: Windows NT4.0 / 2000 / Xp Pro / 2003/7/2008
Support for 64-bit systems: Present
Language: Multilingual
Medicine: Present
IMPORTANT!
Version: 01
Medicine: Present
