DHTAuto Support
265
76
33
Singapore
Detroit DDEC III&IV Troubleshooting Manual
Description: The troubleshooting manual will provide technicians with the process of testing and handling error codes, troubleshooting manuals are indispensable to help technicians fix errors on modern vehicles.
Type of Manual: Troubleshooting Manual
Brand: Detroit
Detail Contents:
0 - Table of Contents
1 - Introduction
2 - Operation
3 - ECM and Sensor Locations
4 - Basic Knowledge Required
5 - Flash Codes vs SAE Codes
6 - Testing-Service Tools-Tips
7 - DDEC ECM Software Features
8 - Connectors, Terminals, and Splicing
9 - Diagnosing a DDEC System Fault
10 - Intermittent Fault
11 - Flash Code 11-VSG Low
12 - Flash Code 12-VSG High
13 - Flash Code 13-CLS Low
14 - Flash Code 14-Temp Sensor High
15 - Flash Code 15-Temp Sensor Low
16 - Flash Code 16-CLS High
17 - Flash Code 17-Throttle Valve High
18 Flash Code 18-Throttle Valve Low
19 - Flash Code 19
20 - Flash Code 20
21 - Flash Code 21-TPS High
22 - Flash Code 22-TPS Low
23 - Flash Code 23-Fuel Temp Sensor High
24 - Flash Code 24-Fuel Temp Sensor Low
25 - Flash Code 25
26 - Flash Code 26-Auxiliary Imput Active
27 - Flash Code 27-Air Temp Sensor High
28 - Flash Code 28-Air Temp Sensor Low
29 - Flash Code 29
30 - Flash Code 30
31 - Flash Code 31-Engine Brake Fault Code
32 - Flash Code 32-Cel Sel Fault
33 - Flash Code 33-TBS High
34 - Flash Code 34-TBS Low
35 - Flash Code 35-OPS High
36 - Flash Code 36-OPS Low
37 Flash Code 37-FPS High
38 - Flash Code 38-FPS Low
39 - Flash Code 39
40 - Flash Code 40
41 - Flash Code 41-Too Many SRS
42 - Flash Code 42-Too Few SRS
43 - Flash Code 43-Coolant Level Low
44 - Flash Code 44-Temp High
45 - Flash Code 45-Oil Pressure Low
46 - Flash Code 46-Battery Voltage Low
47 - Flash Code 47-Air Fuel Pressure High
48 - Flash Code 48-Air Fuel Pressure Low
49 - Flash Code 49
50 - Flash Code 50
51 - Flash Code 51
52 - Flash Code 52-ECM Fault
53 - Flash Code 53-ECM Memory Fault
54 - Flash Code 54-VSS Fault
55 - Flash Code 55-J1939 Data Link Fault
56 - Flash Code 56-J1587 Data Link Fault
57 - Flash Code 57-J1922 Data Link Fault
58 - Flash Code 58
59 - Flash Code 59
60 - Flash Code 60
61 - Flash Code 61-Injector Response Long
62 - Flash Code 62-Output Fault
63 - Flash Code 63-PWM Fault
64 - Flash Code 64
65 - Flash Code 65-Throttle Valve Fault
66 Flash Code 66-Knock Sensor Fault
67 - Flash Code 67-MAP Sensor Fault
68 - Flash Code 68-Idle Validation Fault
69 - Flash Code 69
70 - Flash Code 70
71 - Flash Code 71-Injector Response Short
72 - Flash Code 72-Vehicle Overspeed
73 - Flash Code 73-ESS Fault
74 - Flash Code 74-OI Safety Loop
75 - Flash Code 75-Battery Volt High
76 - Flash Code 76-Engine Overspeed Brake
77 - Flash Code 77-Fuel Temp High
78 - Flash Code 78
79 - Flash Code 79
80 - Flash Code 80
81 - Flash Code 81
82 - Flash Code 82
83 - Flash Code 83
84 - Flash Code 84
85 - Flash Code 85-Engine Overspeed
86 - Flash Code 86-PGS Sensor High
87 - Flash Code 87-PGS Sensor Low
88 - Flash Code 88
89 - Flash Code 89
90 - Engine Sensor Harness
91 - Vehicle Harness
92 - Engine Wiring Schematics
  • Detroit DDEC III&IV Troubleshooting Manual.txt
  • Like
Reactions: Người trông xe
