Service and Repair Manual for Chevrolet Sonic and Aveo (2012-2017)
Models Covered: Chevrolet Sonic, Aveo (2012-2017)
Type of Manual: Service and Repair Manual, Wiring Diagrams
Number of Pages: 7,126
Abbreviations Commonly Used
Air Wind Noise
Antilock Brake System
Automatic Transmission - 6T30-6T40-6T45-6T50 - Component Locator
Automatic Transmission - 6T30-6T40-6T45-6T50 - Description and Operation
Automatic Transmission - 6T30-6T40-6T45-6T50 - Diagnostic Code Index
Automatic Transmission - 6T30-6T40-6T45-6T50 - Diagnostic Information and Procedures
Automatic Transmission - 6T30-6T40-6T45-6T50 - Repair Instruction - Off Vehicle
Automatic Transmission - 6T30-6T40-6T45-6T50 - Repair Instruction - On Vehicle
Automatic Transmission - 6T30-6T40-6T45-6T50 - Schematic and Routing Diagrams
Automatic Transmission - 6T30-6T40-6T45-6T50 - Special Tools and Equipment
Automatic Transmission - 6T30-6T40-6T45-6T50 - Specifications
Bumpers and Fascias
Cabin Air Filter
Clutch
Collision Repair
Common Specs & Procedures
Data Communications
Disc Brakes
Displays and Gauges
Drum Brakes
DTC Index
Emission Application
Engine ControlsFuel - 1.2L or 1.4L - Diagnostic Code Index
Engine ControlsFuel - 1.2L or 1.4L - DTC P0010 to DTC P0328
Engine ControlsFuel - 1.2L or 1.4L - DTC P0335 to DTC P2635 and Diagnostic Information and Procedures
Engine ControlsFuel - 1.2L or 1.4L - Special Tools and Equipment
Engine ControlsFuel - 1.2L or 1.4L - Specifications
Engine ControlsFuel - 1.2L or 1.4L - Wiring Schematic Diagrams
Engine ControlsFuel - 1.2L or 1.4L - Description and Operation
Engine ControlsFuel - 1.4L (LUV) - Repair Instructions
Engine ControlsFuel - 1.6L or 1.8L - Diagnostic Code Index
Engine ControlsFuel - 1.6L or 1.8L - Diagnostic Information and Procedures
Engine ControlsFuel - 1.6L or 1.8L - Special Tools and Equipment
Engine ControlsFuel - 1.6L or 1.8L - Specifications
Engine ControlsFuel - 1.6L or 1.8L - Wiring Schematic Diagrams
Engine ControlsFuel - 1.6L or 1.8L - Description and Operation
Engine ControlsFuel - 1.8L (LUV) - Repair Instructions
Engine Cooling
Engine Electrical
Engine Exhaust
Engine Mechanical - 1.4L (LUV)
Engine Mechanical - 1.8L (LUW)
Engine Overhaul Procedures
Exterior Trim
Fixed and Moveable Windows
Frame and Underbody
Front Suspension
General Information
Horns
HVAC - Manual
Hydraulic Brakes
Immobilizer
Instrument Panel and Console Trim
Interior Trim and Paneling
Lighting
Maintenance and Lubrication
Manual Transmission - F13-5 F15-5 F17-5
Manual Transmission - M20 M32
Mirrors
Mode 6
Paint and Coatings
Park Brake
Power Outlets
Programming and Setup
Rear Suspension
Remote Functions
Seat Belts
Seat Hardware, Trim, and Upholstery
Seat Heating and Cooling
Shift Lock Control
Squeaks and Rattles
Steering Wheel and Column
Sunroof
Suspension General Diagnosis
System Wiring Diagrams
Theft Deterrent
Tire Pressure Monitoring
Tires and Wheels
Vehicle Access
Waterleaks
Wheel Alignment
Wheel Drive Shafts
Wipers and Washers
Wiring Systems & Power Management - Component Connector End Views - Index
Wiring Systems and Power Management - Component Locator - Component Connector End Views A7 to K17
Wiring Systems and Power Management - Component Locator - Component Connector End Views K20 to X90
Wiring Systems and Power Management - Component Locator - Door Component Views
Wiring Systems and Power Management - Component Locator - Electrical Center Identification Views
Wiring Systems and Power Management - Component Locator - Front of Vehicle Engine
Wiring Systems and Power Management - Component Locator - Ground Views
Wiring Systems and Power Management - Component Locator - Inline Harness Connector End Views
Wiring Systems and Power Management - Component Locator - Instrument Panel Center Console
Wiring Systems and Power Management - Component Locator - Luggage Compartment Rear of Vehicle
Wiring Systems and Power Management - Component Locator - Master Electrical Component List
Wiring Systems and Power Management - Component Locator - Passenger Compartment Roof
Wiring Systems and Power Management - Component Locator - Powertrain Component Views
Wiring Systems and Power Management - Component Locator - Splice Pack Connector End Views
Wiring Systems and Power Management - Component Locator - Wheels Vehicle Underbody
Wiring Systems and Power Management - Description and Operation
Wiring Systems and Power Management - Diagnostic Information and Procedures
Wiring Systems and Power Management - Repair Instructions
Wiring Systems and Power Management - Schematic and Routing Diagrams
Wiring Systems and Power Management - Special Tools and Equipment - Special Tools
Wiring Systems and Power Management - Specifications - Fastener Tightening Specifications
  • Chevrolet Sonic & Aveo 2012-2017 Service and Repair Manual.txt
