Chevrolet Equinox Pontiac Torrent 2006-2009 Service and Repair Manual
Model: Chevrolet Equinox, Pontiac Torrent
Years: 2006-2009
Number of Pages: 6733 Pages
Abbreviations
Air Wind Noise
Antilock Brake System
Automatic transaxle service and diagnostics
Automatic transaxle DTC
Automatic transaxle intro 1 of 2
Automatic transaxle intro 2 of 2
Basic Troubleshooting
Battery Charging and Starting
Bumpers and Fascias
Cabin air filter
Cellular, Entertainment and Navigation
Collision Repair
Common Specs & Procedures
Data Communications
Disc Brakes
Displays and Gages
DTC Index
Electrical Component Locator
Engine Controls and Fuel 3.4l Diagnostics and Troubleshooting
Engine Controls and Fuel 3.4l Dtc 1
Engine Controls and Fuel 3.4l Dtc 2
Engine Controls and Fuel 3.4l Intro 1 of 2
Engine Controls and Fuel 3.4l Intro 2 of 2
Engine Cooling
Engine Electrical
Engine Exhaust
Engine Mechanical - 3.4L
Engine Overhaul Gen info
Exterior Trim
Firing Order
Fixed and Moveable Windows
Frame and Underbody
Front suspension
Fuses & Circuit Breakers
General info
Horns
Hvac system manual
Hvac
Hydraulic Brakes
Immobilizer
Instrument Panel and Console Trim
Interior Trim and Paneling
Lighting system
Luggage Rack and Roof Trim
Maintenance and lube
Maintenance and Lubrication
Maintenance reminder light reset
Mirrors
Mode 6
Paint and Coatings
Park Brake
Power Outlets
Power Seats
Power steering
Programming and Setup
Propeller Shaft
Rear Drive Axle
Rear suspension system
Remote Functions
Seat belts
Seat Hardware, Trim, and Upholstery
Seat Heating and Cooling
Shift interlock
SIR
Squeaks and Rattles
Steering wheel and column (2)
Steering Wheel and Column
Sunroof
Suspension general diagnosis
System Wiring Diagrams
Theft Deterrent
Tire Pressure Monitoring
Tires and wheels
Tpms
Transfer case
Vehicle Access
Waterleaks
Wheel alignment
Wheel Drive Shafts
Wipers and Washers
Wiring Systems and Power Management Component Locator & Power, Ground & Splice Pack Connector End Views
Wiring Systems and Power Management Diagnostic Starting Point & In-Line Harness Connector End Views
Wiring Systems and Power Management DTC B1370 to DTC1475
Wiring Systems and Power Management Introduction
Wiring Systems and Power Management Service & Troubleshooting
