Service & Repair Manual for Chevrolet CK Pickup (1988-1993)
Manual Type: Service and Repair Manual, including Wiring Diagram
Model: Chevrolet CK Pickup
Model Years: 1988-1993
Total Pages: 1,953 Pages
ABBREVIATIONS COMMONLY USED
ABBREVIATIONS EMISSION CONTROL
AC COMPRESSOR APPLICATION
AC COMPRESSOR SERVICING
AC HEATER MANUAL C & K SERIES
AC HEATER MANUAL R & V SERIES
AC REFRIGERANT OIL AND R-12 CAPACITIES
AC SYSTEM DIAGNOSIS - MANUAL
AC SYSTEM GENERAL SERVICING
AC SYSTEM PRECAUTIONS
ALTERNATOR AND REGULATOR
ANTI-LOCK BRAKE 4-WHEEL
ANTI-LOCK BRAKE REAR WHEEL
AUTOMATIC TRANSMISSION DIAGNOSIS - TORQUE CONVERTER CLUTCH
AUTOMATIC TRANSMISSION OVERHAUL 3L80 & 3L80HD
AUTOMATIC TRANSMISSION OVERHAUL AND TESTING - 700-R4-4L60
BASIC TROUBLE SHOOTING GENERAL INFORMATION
CLUTCHES
COMPONENT LOCATIONS SYSTEM
COOLING SPECIFICATIONS
CRUISE CONTROL ELECTRIC MOTOR SERVO
CRUISE CONTROL VACUUM SERVO
DEFOGGER - REAR WINDOW
DIFFERENTIAL EATON POSITIVE TRACTION
DISC AND DRUM
DLC
DOOR LOCKS - POWER
DRIVE AXLE - FRONT
DRIVE AXLE - FULL FLOATING
DRIVE AXLE 7.5, 7.625, 8.5 AND 9.5 INCHES
DRIVE AXLE 10.5 INCHES
DRIVE AXLE RATIO IDENTIFICATION
DRIVE BELT ROUTING
DRIVE SHAFT
EGR FUNCTION TESTING
ELECTRICAL COMPONENT LOCATOR CK SERIES
ELECTRICAL COMPONENT LOCATOR RV SERIES
EMISSION CONTROL VISUAL INSPECTION PROCEDURES
ENGINE 4.3L V6
ENGINE 5.0L V8
ENGINE 5.7L V8
ENGINE 6.2L V8 DIESEL
ENGINE 7.4L V8
ENGINE CONTROLS - ADJUSTMENTS
ENGINE CONTROLS - BASIC TESTING
ENGINE CONTROLS - COMPONENT TESTS
ENGINE CONTROLS - PIN VOLTAGE CHARTS
ENGINE CONTROLS - REMOVAL INSTALL OVERHAUL
ENGINE CONTROLS - SENSOR OPERATING RANGE CHARTS
ENGINE CONTROLS - SPECIFICATIONS
ENGINE CONTROLS - TESTS W-CODES DIESEL
ENGINE CONTROLS - TESTS W-CODES TBI
ENGINE CONTROLS - TESTS WO-CODES
ENGINE CONTROLS - THEORY AND OPERATION
ENGINE COOLING FAN - ELECTRICAL
ENGINE COOLING FAN - MECHANICAL
ENGINE OIL PAN REMOVAL
ENGINE OVERHAUL PROCEDURES
ENGINE REMOVAL
ENGINE VIN ID
FUSES AND CIRCUIT BREAKERS R-V SERIES
HEATER SYSTEM
HEATER TROUBLE SHOOTING
HYDRAULIC DIAGRAMS 3L80, 3L80-HD, 400, 475 & M400
HYDRAULIC DIAGRAMS 4L60
HYDRAULIC DIAGRAMS 700R4
IGNITION SWITCH AND LOCK CYLINDER
INSTRUMENT PANEL
JACKING AND HOISTING
LOCKING HUBS AUTOMATIC
LOCKING HUBS MANUAL
MAINTENANCE INFORMATION C & K SERIES
MAINTENANCE INFORMATION R & V SERIES
MAINTENANCE REMINDER LIGHT RESET PROCEDURES
MANUAL TRANSMISSION OVERHAUL - GM 117 4-SPEED
MANUAL TRANSMISSION OVERHAUL - NV3500-5LM60 5-SPEED (2-SHAFT)
MANUAL TRANSMISSION REMOVAL AND INSTALL
MANUAL TRANSMISSION SERVICING
POWER MIRRORS R-V SERIES
POWER STEERING GENERAL SERVICING
POWER STEERING PUMP
POWER WINDOWS
PRE-ALIGNMENT CHECKS
SERVICE INDICATOR AND WARNING LIGHTS
STARTER
STARTING REMOVAL AND INSTALL
STEERING COLUMN SWITCHES
STEERING GEAR - POWER
STEERING KNUCKLES - 4WD
STEERING LINKAGE
STEERING WHEEL REMOVAL
SUSPENSION - FRONT 4WD - LEAF SPRING
SUSPENSION - FRONT 4WD - TORSION BAR
SUSPENSION - FRONT C SERIES 2WD
SUSPENSION - FRONT R SERIES 2WD
SUSPENSION - REAR C & K SERIES
SUSPENSION - REAR R & V SERIES
TRANSFER CASE DIAGNOSIS & OVERHAUL 1370, 4401 AND 4470
TRANSFER CASE OVERHAUL - NEW PROCESS 205
TRANSFER CASE OVERHAUL NEW VENTURE 241 AND 243
TRANSMISSION APPLICATION
TRANSMISSION OIL PAN GASKET ID
TRANSMISSION REMOVAL & INSTALLATION
TRANSMISSION SERVICING AT
TURN SIGNALS AND HAZARD FLASHERS
UNIVERSAL JOINTS
VACUUM DIAGRAMS
VACUUM PUMP
WARNING BUZZER CHIME
WAVEFORM INJECTION NON TURBO
WHEEL ALIGNMENT SPECIFICATIONS & PROCEDURES
WIPER WASHER C-K SERIES
WIPER WASHER R-V SERIES
WIRING C1500
WIRING C2500
WIRING C3500
WIRING DIAGRAMS C-K PICKUPS
WIRING DIAGRAMS R-V SERIES
WIRING K1500
WIRING K2500
WIRING K3500
WIRING V3500
WIRING R3500
  • Chevrolet CK Pickup 1988-1993 Service and Repair Manual.txt
