lavenue
71
7
6
36
thailand
If you download this document, you will be lost 3225 Beer
CASE SKID STEER LOADER ALPHA SR130, SR150, SR175, SV185, SV300, SV250, SR250, SR220, SR200, TR270, TR320, TV380 OPERATORS & SERVICE MANUAL
Code:
Brand: Case
Product Code: Case
Availability: In Stock
01.2013 / All Regions / 1 CD / Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP / 32 & 64 bit
CASE Skid Steer Loader Alpha Series SR130, SR150, SR175, SV185, SV300, SV250, SR250, SR220, SR200
Alpha Series Compact Track Loader TR270, TR320, TV380
Operators Manual, Service & Repair Manual, Wiring diagrams, Circuits, Technical Data, Maintenance, Troubleshooting, Specifications and other
Languages:  English
Code:
SERVICE MANUAL
INTRODUCTION
HYDRAULIC, PNEUMATIC, ELECTRICAL, ELECTRONIC SYSTEMS
PRIMARY HYDRAULIC POWER SYSTEM
SECONDARY HYDRAULIC POWER SYSTEM
HYDRAULIC COMMAND SYSTEM
HIGH-FLOW HYDRAULIC POWER SYSTEM
ELECTRICAL POWER SYSTEM
LIGHTING SYSTEM
ELECTRONIC SYSTEM
FAULT CODES
ENGINE AND PTO IN
ENGINE
FUEL AND INJECTION SYSTEM
AIR INTAKE SYSTEM
ENGINE COOLANT SYSTEM
STARTING SYSTEM
TRANSMISSION, DRIVE AND PTO OUT
TRANSMISSION Hydrostatic
AXLES, BRAKES AND STEERING
Final drive
Final drive Hydraulic drive
STEERING Mechanical
PARKING BRAKE Hydraulic
WHEELS AND TRACKS Tracks
WHEELS AND TRACKS Wheels
FRAME AND CAB
FRAME Primary frame
SHIELD
USER CONTROLS AND SEAT
USER CONTROLS AND SEAT Operator seat
USER PLATFORM
ENVIRONMENT CONTROL Heating system
ENVIRONMENT CONTROL Air-conditioning system
SAFETY SECURITY ACCESSORIES Safety
FRAME POSITIONING
STABILISING Ballasting
TOOL POSITIONING
LIFTING
TILTING
LEVELLING
SECONDARY FUNCTIONS Hydraulic
HITCH AND WORKING TOOL
BOOM Lift
ARM TOOL ATTACHMENT Tilt
SINGLE ARM Lift
SINGLE ARM TOOL ATTACHMENT Tilt
EXCAVATING AND LANDSCAPING
DIGGING Non-articulated digging tools
CARRYING Unarticulated tools
COUPLING Mechanical coupling
Code:
OPERATORS MANUAL
1 GENERAL INFORMATION
Note to the Owner
Right, left, front and rear of the machine
Identification numbers
Machine components
2 SAFETY INFORMATION
Signal word definition
Safety rules
Decal information
Safety decals
Utility safety
Operator precautions
Proper entry and exit
Starting and stopping precautions
Seat belt precautions
Specific precautions to this machine
Operating precautions
Maintenance precautions
Fuel handling precautions
Burn prevention
Fire extinguisher
Hazardous chemicals
Transporting precautions
Electro-Magnetic Compatibility (EMC)
Roll Over Protective Structure (ROPS)
Welding on the machine
Mechanical lift arm lock procedure - radial lift machines
Mechanical lift arm lock procedure - vertical lift machines
No engine power - lift arm down control
Emergency exit
3 CONTROLS/INSTRUMENTS
ACCESS TO OPERATOR'S PLATFORM
Door latches, cab
Window glass, cab
Windshield wiper and washer controls
Cab air louvers
OPERATOR'S SEAT
Standard seat
Mechanical suspension seat
Air seat
Seat belt
MECHANICAL HYDRAULIC CONTROLS
Steering and travel
Moving the machine
Turning the machine
Lift arm and bucket controls
Hand controls
Foot pedals
ELECTRO HYDRAULIC CONTROLS
Control pattern overview
Standard H control pattern
Standard ISO control pattern
H control pattern steering and travel
Left hand control lever
Right hand control lever
Moving the machine
Turning the machine
H control pattern lift arm and bucket controls
Lift arm raise/lower control
Bucket curl/dump control
ISO control pattern steering and travel
Moving the machine
Turning the machine
CONTROL HANDLES
Switch configurations
Two speed function
AUXILIARY HYDRAULICS
Standard auxiliary hydraulics
High flow auxiliary hydraulics
Enhanced high flow auxiliary hydraulics
INSTRUMENT CLUSTER
Electronic instrument cluster (EIC)
Advanced instrument cluster (AIC)
Instrument cluster
Left column switch identification
ISO or H pattern control switch
Machine lights
Telematics
4 OPERATING INSTRUCTIONS
COMMISSIONING THE UNIT
Operating Instructions
STARTING THE UNIT
Engine operation
Throttle
STOPPING THE UNIT
Parking the machine and stopping the engine
Operating in extreme temperatures
Booster battery procedure
MOVING THE UNIT
Machine operation
5 TRANSPORT OPERATIONS
SHIPPING TRANSPORT
Transporting the machine
RECOVERY TRANSPORT
Moving a disabled machine
6 WORKING OPERATIONS
GENERAL INFORMATION
Mechanical attachment mounting systems
Hydraulic attachment mounting systems
Field operation
7 MAINTENANCE
GENERAL INFORMATION
General safety before you service
Lubrication analysis program
Plastic and resin parts
Ecology and the environment
Tilting operator's compartment forward
Machine cleaning
Window removal and cleaning
Cab door removal and installation
Battery safety - check and cleaning
Fire extinguisher
Biodiesel fuel
Engine hourmeter
Wheels and tires
Fluids and lubricants
Lubrication and maintenance access
Fuses and relays
MAINTENANCE CHART
Maintenance Chart
Maintenance procedures
Clean tracks and components
Engine and hydraulic coolers
Engine coolant reservoir level check
Engine oil
Lift arm, pivot points, coupler pins and cylinder pins
Hydraulic system
Seat belt, lap bar and seat interlock operation check
Alternator and air conditioning compressor (if equipped) belt tension
Cab intake filter
Roll Over Protective Structure (ROPS) mechanism and hardware check
Engine oil and filter
Final drive - Drain fluid
Radiator coolant level check
Fuel filter
In line fuel filter
Drive chain tension check
Primary fuel filter
Hydraulic oil filter
Final drive chain tank oil
Air cleaner elements
Hardware - loose or damaged
Hydraulic fluid
Radiator drain and flush
STORAGE
Storing the machine
8 TROUBLESHOOTING
FAULT CODE RESOLUTION
Error code index
9 SPECIFICATIONS
General specification
OTHER
  • CASE MANUAL DOWNLOAD LINK.txt
