Cadillac Eldorado 1985 Service Repair Manual and Wiring Diagram
Brand: CadillacModel: Cadillac Eldorado 1985
Date: 1985
Number of Pages: 1520 Pages
4.1L V8 Engine
5.7L V8 Engnie Diesel
AC Compressor General Specification R-4
AC Compressor Oil Checking
AC Compressor Overhaul DAV5
AC Compressor Overhaul R-4 with 6-Pole Clutch
AC Heater System Automatic Except Fleetwood FWD
AC Orifice Tube Removal and Installation
AC System General Servicing
AC System Precautions
Air Cleaner Thermostatic
Air Injection Reactor System
Alternator and Regulator
Antenna Power
Anti Lock Brake Safety General Information
Anti-Theft System
Automatic Transmission Overhaul 325-4L Final Drive
Automatic Transmission Removal and Installation
Automatic Transmission Servicing
Axle Shafts Front
Basic Trouble Shooting
Brake System Bleeding
Catalytic Converter
Commonly Used Abbreviations
Convertible Top Power
Cooling System Specifications
Cruise Control System
Defogger Rear Window
DFI Components 4.1L
DFI ECM Tests w-Codes Expect Fleetwood FWD
DFI ECM Tests without Codes
DFI Theory Operation 4.1L V8
Diagnostic Connector FWD
Diesel CEC System W-External EGR
Disc
Door Locks Automatic
Door Locks Power
Drive Axles FWD
EGR Function Testing Diesel
EGR Function Testing Diesel1
EGR Function Testing Diesel2
Electrical Component Locator
Emission Applications Diesel
Emission Component Identification
Emission Control Visual Inspection Procedures
Engine Cooling Fan
Engine Oil Pan Removal
Engine Overhaul Procedures
Engine Removal
Engine VIN ID
Final Drive Unit
Fuel Evaporation System
Fuel Injection System Diesel
Fuel Injection System Digital
Fuse Block and Flasher Locations
Fuses and Circuit Breakers
Headlight Dimmer Automatic
Ignition System Hei Est
Instrument Panel Electronic
Jacking and Hoisting
Maintenance Information
Mirrors Power
Model Identification
PCV System Gasoline
Power Steering General Servicing
Power Steering Pump
Power Windows Side
Pre-Alignment Checks
Riding Height Adjustment
Seats Power
Service Indicator and Warning Lights
Starter Removal
Starter
Steering Column Switches
Steering Column
Steering Gear - Power
Steering Linkage
Steering Wheel and Horn Removal
Sun Roof and Moon Roof Power
Suspension Electronic Level Control
Suspension Front
Suspension Rear
Tailgate and Trunk Release
TBI Design Specifications
Towing Procedures
Tune Up 4.1L V8
Tune Up 5.7L V8 Diesel
Vacuum Pump
Warning System Seat Belt & Key
Wheel Alignment Specifications and Procedures
Wiper Washer System Front Multiplex Pulse Wipes
Wiring Diagrams Except Fleetwood FWD
Wiring Diagrams
