BLACK SMOKE FROM EXHAUST
If your car is running as it should, you are seeing a thin layer of water vapor coming out of the exhaust. That’s why it is so alarming to see black smoke from the exhaust. However, you don’t need to worry if you understand what is causing it.
Clogged Air Filter
Malfunctioning Fuel Injector
Failed EGR Valve
Bad MAF Sensor
Bad Glow Plugs (Diesel)
Engine Deposits
