4
Audi TT 2006 - 2014 TT Roadster 8J 8J3 8J9 Workshop Manual and Wiring Diagram​
File Size: 191.13 MB
File Format: PDF
Brand: Audi
Manual Type: Repair Manual, Service Manual, Workshop Manual and Wiring Diagram
Model: Audi TT 2006 - 2014 TT Roadster 8J 8J3 8J9
Date: 2006 - 2014
Number of Pages: 8652 Pages
4-cylinder direct injection engine (1.8 2.0 ltr 4-valve TFSI generation II)
4-cylinder direct petrol injection engine (2.0 ltr 4-valve turbo) mechanics
4-cylinder direct petrol injection engine (2.0 ltr 4-valve turbo TTS) mechanics
4-cylinder TDI engine (2.0 ltr 4-valve common rail)
4-cylinder TDI engine (2.0 ltr 4-valve common rail generation II)
5-cylinder direct injection engine (2.5 ltr 4-valve TFSI)
6-cylinder injection engine (3.2 ltr 4-valve)
6-speed dual clutch gearbox 02E four-wheel drive(1)
6-speed dual clutch gearbox 02E front-wheel drive
6-speed manual gearbox 0A6 four-wheel drive
6-speed manual gearbox 02Q four-wheel drive
6-speed manual gearbox 02Q front-wheel drive
6-speed manual gearbox 02S front-wheel drive
7-speed dual clutch gearbox 0AM (S tronic)
7-speed dual clutch gearbox 0BH (S tronic)
Air conditioner with refrigerant R134a
Basic equipment From May 2006
Body Repairs
Body Repairs General Body Repairs
Brake system
Communication
Direct petrol injection and ignition system (4-cyl 1.8 ltr 2.0 ltr 4-valve turbo with timing chain)
Direct petrol injection and ignition system (4-cyl 2.0 ltr 4-valve turbo)
Direct petrol injection and ignition system (5-cyl 2.5 ltr 4-valve turbo)
Electrical system General information
Fitting instructions Filling roof side member with foam material
Fitting instructions radio communication systems
Fitting instructions Retrofitting jump start terminal in engine compartment
Fuel supply system diesel engines
Fuel supply system petrol engines
General body repairs interior
General body repairs exterior
Heating air conditioning
Injection and ignition system (6-cyl 3.2 ltr 4-valve injection engine)
Maintenance (2)
Maintenance
Rear final drive 02D 0AV 0BR 0BY
Running gear front-wheel drive and four-wheel drive
Servicing 6-speed manual gearbox 02Q front-wheel drive and four-wheel drive
Servicing 7-speed dual clutch gearbox 0AM 0CW
Specifications for testing the braking force (according to German legislation)
TDI injection and glow plug system (4-cyl 2.0 ltr 4-valve common rail)
TDI injection and glow plug system (4-cyl 2.0 ltr 4-valve common rail generation II)
Technical data for engines
Trailer Operation Guide
Wheel Tyre Guide
Wheels and tyres
  • Audi TT 2006 - 2014 TT Roadster 8J 8J3 8J9 Workshop Manual and Wiring Diagram.txt
