Audi Q5 2012 Basic Equipment Current Flow Diagram
File Size: 3.72 MBFormat: PDF
Brand: Audi
Manual Type: Basic Equipment Current Flow Diagram
Model: Audi Q5
Date: From May 2012
Number of Pages: 35 Pages
-Entry and start authorisation switch, Fuse 6 on fuse holder D
-Control unit in dash panel insert, Radio controlled clock receiver
-Fuel gauge sender, Fuel system pressurisation pump, Control unit in dash panel insert
-Steering column electronics control unit
-Turn signal switch, Cruise control system switch, Steering column electronics control unit
-Intermittent wiper switch, Steering column electronics control unit,
Control unit for electronic steering column lock
-Switch module for driving mode selection, Start/Stop operation button, Relay for
automatic anti-dazzle interior mirror, Automatic anti-dazzle interior mirror
-Bonnet contact switch, Treble horn, Bass horn, Horn relay
-Rain and light sensor, Wiper motor control unit
-Front left brake pad wear sender, Headlight washer system pump, Left washer jet heater element,
Right washer jet heater element
-Brake fluid level warning contact, Ambient temperature sensor, Coolant shortage
indicator sender, Windscreen washer fluid level sender, Rear window wiper motor
-Light switch, Hazard warning lights button
-Front left headlight
-Front right headlight
-Rear left reading light button, Vanity mirror light bulb, Front interior light, Rear right interior light
-Key operated switch to deactivate front passenger side airbag
-Glove compartment light switch, Front left footwell illumination bulb, Front right
footwell illumination bulb, Glove compartment light
-Relay for power sockets, 12 V socket
-Adaptive cruise control unit
-Button for TCS and electronic stabilisation program, Parking aid button, Hill descent control button
-Entry and start authorisation button, Convenience system central control unit
-Contact sensor for front left exterior door handle, Contact sensor for front right
exterior door handle, Convenience system central control unit, Left aerial for entry and start authorisation
-Convenience system central control unit, Left tail light, Left tail light 2, Luggage compartment light on left
-Convenience system central control unit, Right tail light, Right luggage compartment light, Surround lighting 1 in rear lid
-Convenience system central control unit, Rear lid central locking motor
-Anti-theft alarm sensor, Alarm horn, Convenience system central control unit,Central locking and anti-theft alarm system aerial
-Clutch pedal switch, Convenience system central control unit
-Brake light switch, Convenience system central control unit
-Glass breakage sensor for rear window, Convenience system central control unit, Tank filler flap locking motor, Heated rear window
-Cigarette lighter, 12 V socket 2, 12 V socket3
